Topic: Windows Media Player Plus! - Various enhancements for WMP (Read 270194 times) previous topic - next topic
Re: Windows Media Player Plus! - Various enhancements for WMP
Reply #300
Thank you so much! Ticking the playlists option fixed it :D
I also second the request to turn party shuffle off. Mainly because i like to keep my WMP library empty, but that causes an error (party shuffle playlist cannot be created...) to pop up every time i run WMP.
Reply #301
Do you mean that you're applying some specific tricks to keep your library empty? If so, which ones?
Could you also provide the full text of that error message, so I can take a look? Note that you can press Ctrl+C while the error dialog is in focus to copy its contents.
Reply #302
I go to File -> Manage libraries -> Music, and make sure the locations included don't have any music files (by default, Users\%USERNAME%\Music is included, and i don't keep any files there, so no problem with that).
I also go to Options, then under Player i untick the option "Add local media files to library when played".
This keeps my library empty.
Now i went to the device that was showing the error (it's a new laptop) and opened WMP (first time in over a week). I found 2 songs in my library. Turns out i hadn't unticked that option, so i must've played the 2 songs and that's why they were added to the library. I deleted them from the library, deleted the party shuffle playlist, and basically reset everything. Now when i open wmp, i don't get that error anymore (that said something like party shuffle playlist cannot be created). Instead, an empty party shuffle playlist gets created. I have no clue how this happened! If i ever manage to reproduce the error, i'll post back here.
Reply #303
Have a weird problem after upgrading to win10: after installing wmpp 2.10 and playing a file on wmp, then closing wmp, the plugin disappears. I need to reinstall wmpp after every use of wmp
Reply #304
When the plug-in doesn't appear then that probably means that you're running the 64-bit version of WMP's executable file (wmplayer.exe), because the plug-in only supports the 32-bit version.
You should be able to resolve this by making sure that you're running C:\Program Files (x86)\Windows Media Player\wmplayer.exe (and *not* wmplayer.exe in C:\Program Files\Windows Media Player, which is 64-bit).
Reply #305
Im running the 32bit version. An observation after some fiddling around: i had a shortcut to close media player via the closeProcess system command. That's equivalent to going in task manager and force closing wmp
Turns out in win10 if that happens all Plugins are uninstalled
Reply #306
Sorry to pester you, but is there a way I can make Hotkeys only work when Windows Media Player is in focus. I wanted to use space bar to Play/Pause, but now it'll do it even if I'm just trying to listen to something whilst I'm in another program. Thanks for your time. (Made account to write this.)
Reply #307
Then I assume that you added the space bar as a global (system-wide) hotkey in the plug-in's settings? That's indeed not such a good idea :) Instead of adding it on the Global Hotkeys tab in settings, go to the Local Hotkeys tab and tick the checkbox there to use the space bar to play/pause while WMP is in focus.
