Topic: foo_quicksearch (Read 234285 times) previous topic - next topic
foo_quicksearch
Reply #250
Hi ~NEMO
Both your answers did not resolve anything for me; I am still in the position I expressed in my previous post.
The "Standard" Tagz string is all I really bother using day-to-day because it searches for words everywhere in all tags and fields at once,
I want your component to always pass display of the whole album (all tracks) to "NG Playlist" even if there is a remote search match.
Occasionally, I may use a single "Tagz string" for searching. But even in this case, I want the whole album displayed in "NG Playlist".
In other words, always display search results as Full Albums in "NG Playlist" no matter what type of search was conducted in "Quick Search".
I don't believe your component allows this at this time.
Unticking "Append search string to playlist name" in preferences did nothing more than remove the search words in the "Autosearch" playlist.
It does not allow me to rename this playlist --as I said before-- unless I jump through the extra hoop of "click on magnifying glass > also check "New Playlist" before I start the search. I don't believe your component allows this at this time.
foo_quicksearch
Reply #251
Well ... both behaviors are by design anyway. You can rename the results playlist on the preferences page.
foo_quicksearch
Reply #252
Hi ~NEMO,
Is there any chance you can please add a checkbox in preferences page so a user such as me can force your component
to map the output to "Album presentation for all searches" ?
Is there any chance you can also add another checkbox in preferences for "Allow renaming of any Playlist" ?
As it stands now, I feel restricted using your component, please add those checkboxes.
foo_quicksearch
Reply #253
Hi. Id like to know if its possible for quicksearch to parse certain characters from the search string like the hyphens etc. I often copy and paste songs (artist - title) to it and it returns all the files in the library as result. I want it to ignore the "-" character. Thanks
foo_quicksearch
Reply #254
No, but you can add %artist% %title% as a tagz string and enable it in "Search for same ...."
foo_quicksearch
Reply #255
How do I make a new vertical splitter which will show only the playlist QuickSearch creates?
foo_quicksearch
Reply #256
forgive if i sound stupid but this is my first post to the forum
is there a way to search for a text string in whole of the tag or metadata through a single keyword?
like %anywhere% HAS "some name"
i know i can edit the standard query in the preferences, but somehow
%artist% %album% %title% $directory(%_path%,1) %genre%
put in a single line don't give me result, specially from the path field
moreover it would  have been really nice if there was a single keyword to search for all kind of text fields?
dr subodh
foo_quicksearch
Reply #257
First of all, thanks for this component.  I'm using it and it's very helpful.
One dislike is the issue that you can't rename the results playlist but I've read previous posts and you're saying that we're stuck with that behavior (great pity in my opinion).  Anyway, I wanted to try to describe a search feature that I've seen used in another player that I would simply love to see in Foobar...  It's a super easy to use search facility but very powerful at the same time.  Granted, it might not be easy to develop but here goes anyway...
I want to be able to search for tracks using my own custom classifications to very quickly and easily identify a few tracks that fit the bill at a particular time and place when DJing.  What I'll be doing is figuring out the next few tracks to throw into the playback queue.  The type of classifications could be things like, 'sos' (repair the dancefloor), 'rude' (don't play at a Church event), 'gf' (girlfriend approved) and so on.  Yes, I know I could create custom meta tags and search on them but the point is that means writing queries on the fly and, in the heat of the moment, I just don't like that idea.  What I want to do is just enter the words against a single tag (without even needing to specify that single tag because I want a predefined search dialogue).  I guess this could be called a multiple value tag?  So, in the search field, I would just enter some key words separated by commas:-
  hot, rude
or
  girlie, gf
etc.
In the way QuickSearch works, I would be happy to see  the results pop up in new tag or whatever.  I dont' mind because I can just drag what I want into the playback queue at that point.  When I saw this super easy search feature in use in another player, it also had super easy in-line tag editing too because the whole point is that you are always refining these tags as you getter better feel for what people like at different times and so on.
Please tell me it can be done?  :-)
Zarty
foo_quicksearch
Reply #258
There is even a more easy way:
use tagbox or quicktagger to tag a special field in a convenient way, tagbox has the advantage to tag multiple values inside a field. This field has to be declared as one with multiple tags in the advanced prerences before you do the tagging.
Then create a facet panel in dui or filter panel in cui with that tag -  be sure to use %<tag>% (with the triangles brackets) as pattern: you will get a list with all values of your tag. Now you simply can choose by clicking what you would like to add to queue. Note that facets has the feature to set if a multiple selection of values are combined by OR or AND.
foo_quicksearch
Reply #259
[quote name='q-stankovic' date='Oct 25 2011, 15:39' post='773222']
Thank you very much for the suggested solution.  Much appreciated.  I used Facets and QuickTag.  It all works apart from what is literally a 'show-stopper'... Using 'Queue Contents Editor', even with 'Keep Queue' addon, if I have a list of tracks in the playback queue, the current playing track is restarted every time I do operations in a facets panel like, click on 'ALL' (in the Genre panel or in my Custom panel relating my custom tag.  Changing the search selections should not affect the playback queue of course.  I wonder if you or anyone else has a way of fixing this behavior?
[Update: It's a 'double click' on any panel item such as Genre | All that restars the currently playing track.  A single click doesn't restart the currently playing track.  It's still an issue because if I am using Foobar to DJ, it would be very easy to double-click instea of single-click]
[Another update: It's ok, I fixed it.  I found the options in preferences for Facets that turn off double-click behavior.  Job done]
Zarty
foo_quicksearch
Reply #260
A request:
Would be useful if we could apply the "quicksearch for same" on playlist: f.e. i click a track with a certain artist and do the quicksearch for artist -> all tracks with that artist get selected in the playlist.
foo_quicksearch
Reply #261
Hello
I've been having a small problem with foo_quicksearch.
While using a previous version (2.xx, don't remember exactly), I was able to use the up/down arrow keys to cycle through results in the current playlist while doing an inline search.
Since I updated to version 3.x, the up and down arrows won't work anymore, no matter "Set focus to search results" being set or not.
I've been looking for a solution for some while and still have to find a clue.
Thanks,
Fernando D'Andrea.
foo_quicksearch
Reply #262
If you are using the default ui: as nemo mentioned here it is a limitation of the sdk
Edit
not sure if my answer is correct since you told that you could cycle in older versions
foo_quicksearch
Reply #263
Edit
Indeed, I could cycle perfectly with the older versions. Actually, I tried to find V2.14 for a downgrade yesterday, to no avail.
Fernando.
foo_quicksearch
Reply #264
That arrow key functionality is something I've been sorely missing as well.
foo_quicksearch
Reply #266
i dunno why but foo_quicksearch has been causing my foobar setup to crash alot lately.
all the crash reports have:
Crash location:
Module: foo_quicksearch
Offset: 30ABh
i don't know what's causing the crash and i haven't been able to replicate it but... i have noticed the pattern before the crash is same every time.
foobar2000 v1.1.7
columnsUI v0.3.8.8
foo_quicksearch v 3.2
foo_quicksearch
Reply #267
Crash location:
Offset: 30ABh
Can you provide more information ? (usage pattern, minidump). Then I will have a look. Thanks.
foo_quicksearch
Reply #268
a recent dump assigned to foo_quicksearch recently too, if it could help too:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 74C2270Ch
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop=>contextmenu_item_node::execute
Code bytes (74C2270Ch):
74C226CCh:  5D FC 89 85 60 FF FF FF 89 9D 64 FF FF FF 89 9D
74C226DCh:  68 FF FF FF 89 9D 6C FF FF FF 89 9D 70 FF FF FF
74C226ECh:  8D 4D B0 C6 45 FC 01 51 89 5D B0 E8 E4 21 00 00
74C226FCh:  83 C4 04 89 5D AC C6 45 FC 03 8B 0D B8 75 C6 74
74C2270Ch:  8B 11 8B 02 FF D0 39 46 0C 0F 86 80 00 00 00 BE
74C2271Ch:  50 77 C5 74 89 5D 8C 89 5D 90 89 5D 94 89 5D 98
74C2272Ch:  89 75 88 68 6C 83 C5 74 8D 45 88 C6 45 FC 04 E8
74C2273Ch:  70 1F 00 00 68 74 83 C5 74 8D 45 88 E8 63 1F 00
Stack (002DDED4h):
002DDEB4h:  00000000 FFFFFD34 000002E4 FFFFFD34
002DDEC4h:  000002CC 00000019 00000000 002DDF34
002DDED4h:  55298F85 002DE030 08866190 74994618
002DDEE4h:  74C56F34 00000000 00000000 00000000
002DDEF4h:  00000000 74C56F34 00000000 00000000
002DDF04h:  00000000 00000000 772943CD 00000002
002DDF14h:  00000076 00000000 002DDF50 00000000
002DDF24h:  035AF240 00000003 088CD1A0 00000000
002DDF34h:  014E7BC8 00000000 00DBCB58 00000000
002DDF44h:  772A40C1 00000013 00000000 002DDFF8
002DDF54h:  0037D9F0 0000001E 002DDF78 74F227D8
002DDF64h:  0037DA0D 014B23E4 0000001E 002DE030
002DDF74h:  55298F85 002DDF98 74C4CC1A 00000003
002DDF84h:  002DDFA4 01379E30 088CD1A0 088CD1F0
002DDF94h:  00000013 002DDFC0 0148B419 00000000
002DDFA4h:  002DDFD0 01379DB4 002DE030 002DE040
002DDFB4h:  74994618 002DDFAC 002DDAA8 002DE440
002DDFC4h:  01489EF8 014C3B30 00000000 002DDFDC
002DDFD4h:  7490B0BA 0A316DD4 002DDFFC 772A3E75
002DDFE4h:  0A0CB7E8 00000024 002DE040 0A316DB4
Registers:
EAX: 00000001, EBX: 00000000, ECX: 00000000, EDX: 0140FD00
ESI: 035AF240, EDI: 002DE030, EBP: 002DDF84, ESP: 002DDED4
Crash location:
Offset: 270Ch
Loaded modules:
foobar2000                      loaded at 01340000h - 01532000h
ntdll                            loaded at 77CF0000h - 77E70000h
kernel32                        loaded at 75C30000h - 75D30000h
KERNELBASE                      loaded at 773B0000h - 773F6000h
COMCTL32                        loaded at 72900000h - 72A9E000h
msvcrt                          loaded at 75450000h - 754FC000h
GDI32                            loaded at 76C00000h - 76C90000h
USER32                          loaded at 76E00000h - 76F00000h
ADVAPI32                        loaded at 75670000h - 75710000h
sechost                          loaded at 76DE0000h - 76DF9000h
RPCRT4                          loaded at 76AD0000h - 76BC0000h
SspiCli                          loaded at 753F0000h - 75450000h
CRYPTBASE                        loaded at 753E0000h - 753EC000h
LPK                              loaded at 75DE0000h - 75DEA000h
USP10                            loaded at 75880000h - 7591D000h
SHLWAPI                          loaded at 76F60000h - 76FB7000h
DSOUND                          loaded at 74E80000h - 74EF2000h
ole32                            loaded at 75AD0000h - 75C2C000h
WINMM                            loaded at 73670000h - 736A2000h
POWRPROF                        loaded at 74F50000h - 74F75000h
SETUPAPI                        loaded at 75930000h - 75ACD000h
CFGMGR32                        loaded at 75DF0000h - 75E17000h
OLEAUT32                        loaded at 77290000h - 7731F000h
DEVOBJ                          loaded at 75650000h - 75662000h
UxTheme                          loaded at 72AA0000h - 72B20000h
SHELL32                          loaded at 75E20000h - 76A69000h
zlib1                            loaded at 5A4C0000h - 5A4D3000h
shared                          loaded at 74F20000h - 74F4B000h
imagehlp                        loaded at 77400000h - 7742A000h
dbghelp                          loaded at 74D90000h - 74E7B000h
COMDLG32                        loaded at 75500000h - 7557B000h
Secur32                          loaded at 74F10000h - 74F18000h
CRYPT32                          loaded at 75760000h - 7587C000h
MSASN1                          loaded at 77CC0000h - 77CCC000h
gdiplus                          loaded at 71F50000h - 720E0000h
IMM32                            loaded at 76F00000h - 76F60000h
MSCTF                            loaded at 75580000h - 7564C000h
rpchrome14browserrecordhelper    loaded at 64910000h - 6491E000h
MSVCR90                          loaded at 73BA0000h - 73C43000h
MSVCP90                          loaded at 73C50000h - 73CDE000h
tiptsf                          loaded at 72BB0000h - 72C08000h
version                          loaded at 75310000h - 75319000h
CLBCatQ                          loaded at 77320000h - 773A3000h
MMDevApi                        loaded at 74D50000h - 74D89000h
PROPSYS                          loaded at 6F480000h - 6F575000h
dwmapi                          loaded at 72110000h - 72123000h
foo_fileops                      loaded at 74D00000h - 74D47000h
foo_converter                    loaded at 74C80000h - 74CFB000h
foo_quicksearch                  loaded at 74C20000h - 74C77000h
WindowsCodecs                    loaded at 73DA0000h - 73E9B000h
foo_uie_sql_tree                loaded at 10000000h - 10127000h
foo_dsp_std                      loaded at 74BD0000h - 74C18000h
foo_input_std                    loaded at 74A60000h - 74BC3000h
foo_uie_panel_splitter          loaded at 00C90000h - 00CE9000h
foo_uie_biography                loaded at 74A00000h - 74A58000h
foo_unpack                      loaded at 749D0000h - 749FE000h
foo_uie_wsh_panel_mod            loaded at 748F0000h - 749C4000h
Msimg32                          loaded at 721D0000h - 721D5000h
foo_vis_shpeck                  loaded at 74400000h - 74441000h
foo_cdda                        loaded at 743B0000h - 743FE000h
foo_uie_lyrics3                  loaded at 03D40000h - 03E40000h
WININET                          loaded at 76CC0000h - 76DDA000h
Normaliz                        loaded at 75920000h - 75923000h
iertutil                        loaded at 770D0000h - 77288000h
urlmon                          loaded at 76FC0000h - 770D0000h
foo_freedb2                      loaded at 74370000h - 743B0000h
foo_rgscan                      loaded at 74320000h - 7436A000h
foo_albumlist                    loaded at 742C0000h - 7431D000h
foo_dsp_xgeq                    loaded at 74280000h - 742B4000h
foo_uie_elplaylist              loaded at 74200000h - 74273000h
foo_uie_vis_channel_spectrum    loaded at 00FB0000h - 00FED000h
foo_covers2                      loaded at 744D0000h - 744F7000h
foo_ui_std                      loaded at 73FD0000h - 740E8000h
foo_ui_columns                  loaded at 049B0000h - 04B40000h
AUDIOSES                        loaded at 741C0000h - 741F6000h
apphelp                          loaded at 75200000h - 7524B000h
TortoiseOverlays                loaded at 02EE0000h - 02EF3000h
ThgShellx86                      loaded at 02F60000h - 02FB3000h
msi                              loaded at 71800000h - 71A40000h
EhStorShell                      loaded at 74140000h - 74171000h
GrooveShellExtensions            loaded at 71A60000h - 71C7F000h
GrooveUtil                      loaded at 73ED0000h - 73FC2000h
MSVCR80                          loaded at 73910000h - 739AB000h
GrooveNew                        loaded at 74F00000h - 74F07000h
ATL80                            loaded at 748D0000h - 748EB000h
CRYPTSP                          loaded at 73AE0000h - 73AF6000h
rsaenh                          loaded at 73AA0000h - 73ADB000h
SXS                              loaded at 6EC70000h - 6ECCF000h
jscript                          loaded at 71740000h - 717F2000h
RpcRtRemote                      loaded at 72130000h - 7213E000h
scrrun                          loaded at 74190000h - 741BA000h
oleacc                          loaded at 6ED30000h - 6ED6C000h
wshom                            loaded at 73D50000h - 73D71000h
MPR                              loaded at 72140000h - 72152000h
explorerframe                    loaded at 715D0000h - 7173F000h
DUser                            loaded at 73D20000h - 73D4F000h
DUI70                            loaded at 71510000h - 715C2000h
msls31                          loaded at 71410000h - 7143B000h
profapi                          loaded at 732D0000h - 732DB000h
xmllite                          loaded at 713E0000h - 7140F000h
UIAutomationCore                loaded at 71350000h - 713DC000h
PSAPI                            loaded at 75D30000h - 75D35000h
StructuredQuery                  loaded at 712F0000h - 7134C000h
actxprxy                        loaded at 712A0000h - 712EE000h
ieproxy                          loaded at 71260000h - 71292000h
ntmarta                          loaded at 75280000h - 752A1000h
WLDAP32                          loaded at 75710000h - 75755000h
thumbcache                      loaded at 744A0000h - 744B6000h
SHDOCVW                          loaded at 714E0000h - 7150E000h
ieframe                          loaded at 6D650000h - 6DF95000h
SearchFolder                    loaded at 711C0000h - 7125F000h
ntshrui                          loaded at 71150000h - 711BF000h
srvcli                          loaded at 732F0000h - 73309000h
cscapi                          loaded at 74510000h - 7451B000h
slc                              loaded at 74180000h - 7418A000h
LINKINFO                        loaded at 74130000h - 74139000h
samcli                          loaded at 74110000h - 7411F000h
SAMLIB                          loaded at 71A40000h - 71A52000h
netutils                        loaded at 73310000h - 73319000h
GrooveSystemServices            loaded at 71120000h - 7114D000h
msxml3                          loaded at 70FE0000h - 71113000h
NetworkExplorer                  loaded at 70CA0000h - 70E38000h
drprov                          loaded at 74120000h - 74128000h
WINSTA                          loaded at 72C10000h - 72C39000h
ntlanman                        loaded at 70FC0000h - 70FD4000h
davclnt                          loaded at 70FA0000h - 70FB7000h
DAVHLPR                          loaded at 73D10000h - 73D18000h
zipfldr                          loaded at 70F40000h - 70F92000h
avrt                            loaded at 728F0000h - 728F7000h
Stack dump analysis:
Address: 74994618h (foo_uie_wsh_panel_mod+A4618h), symbol: "foobar2000_get_interface" (+5EF98h)
Address: 74C56F34h (foo_quicksearch+36F34h), symbol: "foobar2000_get_interface" (+1AB84h)
Address: 772943CDh (OLEAUT32+43CDh), symbol: "GetErrorInfo" (+4ACh)
Address: 014E7BC8h (foobar2000+1A7BC8h)
Address: 772A40C1h (OLEAUT32+140C1h), symbol: "DispCallFunc" (+2F2h)
Address: 74F227D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 014B23E4h (foobar2000+1723E4h)
Address: 74C4CC1Ah (foo_quicksearch+2CC1Ah), symbol: "foobar2000_get_interface" (+1086Ah)
Address: 01379E30h (foobar2000+39E30h)
Address: 0148B419h (foobar2000+14B419h)
Address: 01379DB4h (foobar2000+39DB4h)
Address: 01489EF8h (foobar2000+149EF8h)
Address: 014C3B30h (foobar2000+183B30h)
Address: 7490B0BAh (foo_uie_wsh_panel_mod+1B0BAh)
Address: 772A3E75h (OLEAUT32+13E75h), symbol: "DispCallFunc" (+A6h)
Address: 772A3CEFh (OLEAUT32+13CEFh), symbol: "LoadRegTypeLib" (+AC1h)
Address: 7729F958h (OLEAUT32+F958h), symbol: "VarBstrCmp" (+A0h)
Address: 772AC945h (OLEAUT32+1C945h), symbol: "LHashValOfNameSys" (+55h)
Address: 772AC94Fh (OLEAUT32+1C94Fh), symbol: "LHashValOfNameSys" (+5Fh)
Address: 772A0000h (OLEAUT32+10000h), symbol: "CreateErrorInfo" (+295h)
Address: 7490E82Dh (foo_uie_wsh_panel_mod+1E82Dh)
Address: 7175DDEEh (jscript+1DDEEh), symbol: "DllGetClassObject" (+1838Dh)
Address: 717463D4h (jscript+63D4h), symbol: "DllGetClassObject" (+973h)
Address: 7175DD1Eh (jscript+1DD1Eh), symbol: "DllGetClassObject" (+182BDh)
Address: 7175DED8h (jscript+1DED8h), symbol: "DllGetClassObject" (+18477h)
Address: 7175DE2Ch (jscript+1DE2Ch), symbol: "DllGetClassObject" (+183CBh)
Address: 717464FBh (jscript+64FBh), symbol: "DllGetClassObject" (+A9Ah)
Address: 71746531h (jscript+6531h), symbol: "DllGetClassObject" (+AD0h)
Address: 71782328h (jscript+42328h), symbol: "DllGetClassObject" (+3C8C7h)
Address: 71789A00h (jscript+49A00h), symbol: "DllGetClassObject" (+43F9Fh)
Address: 7175E1F6h (jscript+1E1F6h), symbol: "DllGetClassObject" (+18795h)
Address: 7175D825h (jscript+1D825h), symbol: "DllGetClassObject" (+17DC4h)
Address: 7175E2FAh (jscript+1E2FAh), symbol: "DllGetClassObject" (+18899h)
Address: 717899A9h (jscript+499A9h), symbol: "DllGetClassObject" (+43F48h)
Address: 74992CC8h (foo_uie_wsh_panel_mod+A2CC8h), symbol: "foobar2000_get_interface" (+5D648h)
Address: 0136E2B8h (foobar2000+2E2B8h)
Address: 014EA4F3h (foobar2000+1AA4F3h)
Address: 014AFFE4h (foobar2000+16FFE4h)
Address: 0148E968h (foobar2000+14E968h)
Address: 013F2576h (foobar2000+B2576h)
Address: 74911D5Fh (foo_uie_wsh_panel_mod+21D5Fh)
Address: 74911D6Fh (foo_uie_wsh_panel_mod+21D6Fh)
Address: 75B11145h (ole32+41145h), symbol: "CoSetState" (+280h)
Address: 7729443Ah (OLEAUT32+443Ah), symbol: "GetErrorInfo" (+519h)
Address: 75C166BCh (ole32+1466BCh), symbol: "WdtpInterfacePointer_UserFree" (+1B80h)
Address: 77293EA3h (OLEAUT32+3EA3h), symbol: "SysFreeString" (+4Ah)
Address: 772A4037h (OLEAUT32+14037h), symbol: "DispCallFunc" (+268h)
Address: 772A3D76h (OLEAUT32+13D76h), symbol: "LoadRegTypeLib" (+B48h)
Address: 7175C9FDh (jscript+1C9FDh), symbol: "DllGetClassObject" (+16F9Ch)
Address: 717D9D84h (jscript+99D84h), symbol: "DllRegisterServer" (+2058Bh)
Address: 71759D8Fh (jscript+19D8Fh), symbol: "DllGetClassObject" (+1432Eh)
Address: 71740080h (jscript+80h)
Address: 71759C84h (jscript+19C84h), symbol: "DllGetClassObject" (+14223h)
Address: 7175CD18h (jscript+1CD18h), symbol: "DllGetClassObject" (+172B7h)
Address: 7175D094h (jscript+1D094h), symbol: "DllGetClassObject" (+17633h)
Address: 71750000h (jscript+10000h), symbol: "DllGetClassObject" (+A59Fh)
Address: 7175C691h (jscript+1C691h), symbol: "DllGetClassObject" (+16C30h)
Address: 76E16EF4h (USER32+16EF4h), symbol: "GetClassNameW" (+3F0h)
Address: 76E16EC0h (USER32+16EC0h), symbol: "GetClassNameW" (+3BCh)
Address: 76E30155h (USER32+30155h), symbol: "DdeQueryStringW" (+6D7h)
Address: 00CC928Fh (foo_uie_panel_splitter+3928Fh), symbol: "foobar2000_get_interface" (+2647Fh)
Address: 00CC92AFh (foo_uie_panel_splitter+392AFh), symbol: "foobar2000_get_interface" (+2649Fh)
Address: 75B24102h (ole32+54102h), symbol: "DcomChannelSetHResult" (+1DB8h)
Address: 76E16F8Fh (USER32+16F8Fh), symbol: "IsThreadDesktopComposited" (+95h)
Address: 717A10B6h (jscript+610B6h), symbol: "DllCanUnloadNow" (+17694h)
Address: 00CCF466h (foo_uie_panel_splitter+3F466h), symbol: "foobar2000_get_interface" (+2C656h)
Address: 76E17177h (USER32+17177h), symbol: "GetWindowLongW" (+18Ah)
Address: 76E172F1h (USER32+172F1h), symbol: "GetDC" (+ABh)
Address: 77D0F87Ah (ntdll+1F87Ah), symbol: "NtCallbackReturn" (+12h)
Address: 76E17304h (USER32+17304h), symbol: "GetDC" (+BEh)
Address: 7175E253h (jscript+1E253h), symbol: "DllGetClassObject" (+187F2h)
Address: 00CA1CD0h (foo_uie_panel_splitter+11CD0h)
Address: 76E10000h (USER32+10000h), symbol: "Ordinal2434" (+10000h)
Address: 7175D216h (jscript+1D216h), symbol: "DllGetClassObject" (+177B5h)
Address: 71750196h (jscript+10196h), symbol: "DllGetClassObject" (+A735h)
Address: 71750001h (jscript+10001h), symbol: "DllGetClassObject" (+A5A0h)
Address: 76E1701Bh (USER32+1701Bh), symbol: "GetWindowLongW" (+2Eh)
Address: 76E17027h (USER32+17027h), symbol: "GetWindowLongW" (+3Ah)
Address: 00CA1E68h (foo_uie_panel_splitter+11E68h)
Address: 76E80230h (USER32+80230h), symbol: "ShutdownBlockReasonDestroy" (+596Ah)
Address: 7175C7C9h (jscript+1C7C9h), symbol: "DllGetClassObject" (+16D68h)
Address: 76E30080h (USER32+30080h), symbol: "DdeQueryStringW" (+602h)
Address: 76E17182h (USER32+17182h), symbol: "GetWindowLongW" (+195h)
Address: 75B18863h (ole32+48863h), symbol: "CoRevokeInitializeSpy" (+5C9h)
Address: 75B1393Eh (ole32+4393Eh), symbol: "CoGetComCatalog" (+5BDh)
Address: 71746593h (jscript+6593h), symbol: "DllGetClassObject" (+B32h)
Address: 7175D66Ch (jscript+1D66Ch), symbol: "DllGetClassObject" (+17C0Bh)
Address: 7175F0E0h (jscript+1F0E0h), symbol: "DllGetClassObject" (+1967Fh)
Address: 76C1B65Ah (GDI32+1B65Ah), symbol: "GdiDrawStream" (+63h)
Environment:
App: foobar2000 v1.1.7
OS: Windows 6.1.7600 x64
CPU: Intel® Core™2 Duo CPU    E6850  @ 3.00GHz, features: MMX SSE SSE2 SSE3
Audio: Haut-parleurs (Périphérique High Definition Audio); Audio numérique (SPDIF) (Périphérique High Definition Audio)
UI: Columns UI 0.3.8.8
Components:
Core (2011-06-05 09:16:20 UTC)
    foobar2000 core 1.1.7
foo_albumlist.dll (2011-06-05 09:14:24 UTC)
    Album List 4.5
foo_cdda.dll (2011-06-05 09:14:20 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2011-06-05 09:13:50 UTC)
    Converter 1.5
foo_covers2.dll (2011-08-21 20:18:37 UTC)
    Locate Covers 0.06
foo_dsp_std.dll (2011-06-05 09:14:22 UTC)
    Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-10-09 17:22:17 UTC)
    Graphic Equalizer 0.2.1
foo_fileops.dll (2011-06-05 09:13:12 UTC)
    File Operations 2.1.3
foo_freedb2.dll (2011-06-05 09:13:14 UTC)
    freedb Tagger 0.6.4
foo_input_std.dll (2011-06-05 09:13:58 UTC)
    Standard Input Array 1.0
foo_quicksearch.dll (2011-09-01 10:48:12 UTC)
    Quick Search Toolbar 3.2
foo_rgscan.dll (2011-06-05 09:13:54 UTC)
    ReplayGain Scanner 2.1.2
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2011-06-05 09:14:24 UTC)
    Default User Interface 0.9.5
foo_uie_biography.dll (2011-07-25 14:27:40 UTC)
    Biography View 0.4.2.4
foo_uie_elplaylist.dll (2010-10-26 20:38:46 UTC)
    ELPlaylist 0.6.9.1.1(beta)
foo_uie_lyrics3.dll (2011-08-22 20:14:44 UTC)
    Lyric Show Panel 3 0.1.4
foo_uie_panel_splitter.dll (2010-10-17 09:12:44 UTC)
    Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_sql_tree.dll (2011-09-28 20:19:10 UTC)
    SQL Tree 1.0
foo_uie_vis_channel_spectrum.dll (2011-08-20 19:04:54 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2011-10-30 10:19:51 UTC)
    WSH Panel Mod 1.5.0 Beta 5
foo_unpack.dll (2011-06-05 09:13:24 UTC)
    ZIP/GZIP/RAR Reader 1.6
foo_vis_shpeck.dll (2011-08-22 19:53:05 UTC)
    Shpeck - Winamp vis plugins wrapper 0.3.7
foo_quicksearch
Reply #269
Can you provide the minidump ? (a file named failure_xxxxxx.dmp should have been created in your foobar directory/crash report)
foo_quicksearch
Reply #271
Thanks .... but I cannot reproduce the problem.
Is there any particular sequence of events/actions that is causing the crash?
foo_quicksearch
Reply #272
Sorry to ask such a super basic question here.  Can someone tell me how to perform this simple search with foo_quickserach.  I want to find my insecure rips in the <ACCURATERIPRESULT> field.  Typically the contents of that field would look something like this: "AccurateRip: Not in database  Secure: No  [00000000]"
In Preferences I've added this Tagz strings entry:
Name                          Value
Accurate                      %ACCURATERIPRESULT%
I want to search for this exact string "Secure: No" but I can't figure out how to do that.  Typing "Secure: No" (without quotes) doesn't work for me as it treats them as two separate words.  Putting it in quotes doesn't work at all.  Changing to exact search doesn't work even if I add wildcards before and after "*Secure: No*".  Searching for "No" brings up every result with the word "Not" in that field, which isn't what I want.  I guess I don't have a clue.  Please help.
foo_quicksearch
Reply #273
Exact with *Secure: No* (without quotes)
