Topic: foo_quicksearch (Read 235266 times) previous topic - next topic
Re: foo_quicksearch
Reply #426
NEMO7538, reg. CUI Reply #7911 and CUI Reply #7918
I want to to change the font size used in the Quick Search Toolbar.
Can you add it in Options like Custom Colors, or make Quick Search Toolbar available as item in the CUI fonts settings, see picture ?
X
Re: foo_quicksearch
Reply #427
I'm thinking about a port to 2.0 / 64 bits ... when I have time and courage.
Thanks for your patience.
If you ever update this, would you consider allowing larger custom bitmap? Currently it's limited to 40x16px which does not scale well for 2160p resolution.
Re: foo_quicksearch
Reply #428
Hi NEMO,
Quicksearch is (was) a great tool for all foobar user. Now I'm missing it desperately for 64-bit. How can we encourage you to port it to 64-bit?
Antares
Re: foo_quicksearch
Reply #429
@ NEMO7538,
Any news about this Plugin?
Re: foo_quicksearch
Reply #431
please let me know when the 64 bit version is out
Re: foo_quicksearch
Reply #432
Hello,
With the very kind help from rtldg the quicksearch toolbar has been ported for compatibility with foobar version 2.0 and newer.
It can be downloaded as usual from foobar components repository and now contains 32 bits and 64 bits version.
As it is a new build, please report any issue or comment.
In particular we would appreciate a test with column UI if anyone is using it with the component.
Re: foo_quicksearch
Reply #433
Thank you very much for the update. It's working as expected on default UI x64.
Re: foo_quicksearch
Reply #434
thx a lot for this :-)
2 little bugs found: 1) after open and close: pointed (with mouse/keys) items in a fat font
                              2) properties are not in dark mode
and a little request: is it possible to place quicksearch in toolbar?
Re: foo_quicksearch
Reply #435
The font issue is a bug already reported in this thread. I guessed at what the cause is. Only the developer knows for sure...
https://hydrogenaud.io/index.php/topic,125362.0.html
And Default UI does not allow 3rd party toolbars.
Re: foo_quicksearch
Reply #436
thanks Marc for the information - I overlooked the font bug :-(
Re: foo_quicksearch
Reply #437
I'll be looking into that at some point. Thank you for the thread link btw marc2k3.
Unfortunately. I messed around with the SDK's new dark-mode helper hook stuff but some window elements didn't want to be colored so I disabled it and left it for another time.
If marc2k3 says it's not possible (with Default UI) then I guess not haha
Re: foo_quicksearch
Reply #438
The font issue is fixed for the next release.
Columns UI returns an HFONT from CreateFontIndirect() which is deleted with DeleteObject() but foobar's query_font_ex(ui_font_default) apparently returns the HFONT used by foobar, which was being passed to DeleteObject() when the Quicksearch window is closed.
I made it create a duplicate HFONT so it no longer clobbers foobar's.
Re: foo_quicksearch
Reply #439
The repository is now updated with the latest version : V3.8, incl.
Re: foo_quicksearch
Reply #440
thx for updating :-)
Re: foo_quicksearch
Reply #441
Hi NEMO:
Thank you for creating the 64.bit version. I used it for a long time on my old 32.bit version.
I installed it and noticed that a bug that the 32.bit version already had is still present in the 64.bit version. It would be very favorable for me if it could be corrected.
It is that when applying to a button the Quicksearch for same/Album property it does not find the album if in the %album% metadata there is any double quotation mark.
Re: foo_quicksearch
Reply #442
Hi NEMO:
Yeah the search query builder doesn't seem to like double quotes at all. I'll try to figure out a good way to fix this.
Re: foo_quicksearch
Reply #443
Hello! After updating the component (x86), the player began to start approximately one time out of five. It just hangs in the task manager. However, there is no crash report.
Windows 10 x64
Re: foo_quicksearch
Reply #444
^ I have the same player behavior. Attached is the crash report.
It looks like there is a conflict with the foo_multisource (by @veksha) and foo_quicksearch plugins.
Re: foo_quicksearch
Reply #446
Yes, that is right. After removing "foo_multisource" the player starts as expected.
@veksha , @NEMO7538
I experienced the same issue with QuickSearch and and MultiSource Plugins in Foobar2000 2.installed. Foobar2000 v2.1.5 x64 crashes every 2nd or 3rd startup and occurs seemingly randomly. A screenshot of the crash window and error logs are attached.
Re: foo_quicksearch
Reply #447
Hi. I'm a newbie user of the Quicksearch component.  May I ask if I am using Autosearch with Inline Playlist Option,  how can i Jump to the next matched result?
Re: foo_quicksearch
Reply #448
@veksha , @NEMO7538
Is the plugin incompatibility due to QuickSearch or MultiLyrics? I am leaning toward QuickSearch since the incompatibility didn't pop up until QS was updated.
