foo_dsp_lowpass plugin 2010-04-09 16:02:42 Lowpass filter.Can be used before lossy encoding, if your encoder of choice doesn't have lowpass filter with arbitrary frequency.[attachment=5844:foo_dsp_...ss_0.0.2.7z]Sources (LGPL):[attachment=5845:foo_dsp_....0.2_src.7z]
foo_dsp_lowpass plugin Reply #1 – 2010-04-09 20:50:32 This is what I was looking for. Many thanks Last Edit: 2010-04-09 20:54:33 by Steve Forte Rio
foo_dsp_lowpass plugin Reply #2 – 2010-05-25 01:52:10 Can u PLEASE implement a -24dB Subsonic Filter (HighPass) too?! I would be VERY pleased, cause thats what i miss "right from beginning"
foo_dsp_lowpass plugin Reply #3 – 2010-05-28 19:20:43 Quote from: klez on 2010-05-25 01:52:10Can u PLEASE implement a -24dB Subsonic Filter (HighPass) too?! I would be VERY pleased, cause thats what i miss "right from beginning"This lowpass filter is just a part of SoX resampler. This plugin is just truncated resampler plugin.I don't know how to properly implement subsonic highpass filter.
foo_dsp_lowpass plugin Reply #4 – 2011-02-18 17:35:37 [attachment=6366:foo_dsp_...ss_0.0.4.zip][attachment=6367:foo_dsp_....0.4_src.7z]
foo_dsp_lowpass plugin Reply #5 – 2011-02-19 10:22:59 So far this has been a sort of week-end fun-time a plugin in for me. I load my playlist with sufficiently percussive material, then I set freq to 3500 and width to 1%. The chirpy ringing is really amusing. From here on tweaking phase lets you hear the difference between pre-ringing and post-ringing very clearly.I suppose the default width of 5% is reasonable when used prior to lossy encoding?
Re: foo_dsp_lowpass plugin Reply #6 – 2019-08-30 22:48:19 Plugin messes up channel mask for non-standard channels layouts. For example 5.0 becomes 4.1 when passing through plugin. Last Edit: 2019-08-30 22:51:29 by Rollin
Re: foo_dsp_lowpass plugin Reply #7 – 2020-06-06 17:01:10 lvqclfoobar2000 1.5.4, foo_dsp_lowpass.dll 0.0.4“default” button inside plugin’s settings does not reset settings
