Topic: OggEnc 2.86 (libVorbis 1.3.1) crashing in foobar2000 1.0.1 (Read 7078 times) previous topic - next topic
OggEnc 2.86 (libVorbis 1.3.1) from http://www.rarewares.org isn't working in foobar2000 1.0.1! Both compiles (P4 and generic) crash. OggEnc 2.85 is working fine!
Crashes each time I try to convert to a q6.0 quality ogg file:
1 out of 1 tracks converted with major problems.
Source: "D:\Music\4 Red Eyes - Oblivion [Hard Edged]\01. 4 Red Eyes - Oblivion.wv"
  An error occurred while writing to file (The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters) : "D:\Music\4 Red Eyes - Oblivion [Hard Edged]\01. 4 Red Eyes - Oblivion.ogg"
Additional information:
Encoder stream format: 48000Hz / 2ch / 32bps
Command line: "C:\WINDOWS\system32\oggenc2.exe" -s 262801399 -Q -q6,000000 - -o "01. 4 Red Eyes - Oblivion.ogg"
Working folder: D:\Music\4 Red Eyes - Oblivion [Hard Edged]\
  Conversion failed: The encoder has terminated prematurely with code -1073741819 (0xC0000005); please re-check parameters
Microsoft (R) DrWtsn32
Copyright (C) 1985-2001 Microsoft Corp. Alle Rechte vorbehalten.
Anwendungsausnahme aufgetreten:
        Anwendung: C:\WINDOWS\system32\oggenc2.exe (pid=1888)
        Wann: 04.04.2010 @ 20:49:20.218
        Ausnahmenummer: c0000005 (Zugriffsverletzung)
*----> Systeminformationen <----*
        Terminalsitzungskennung: 0
        Prozessoranzahl: 2
        Prozessortyp: x86 Family 6 Model 15 Stepping 6
        Windows-Version: 5.1
        Aktuelles Build: 2600
        Service Pack: 3
        Aktueller Typ: Multiprocessor Free
*----> Taskliste <----*
   0 System Process
   4 System
316 smss.exe
372 csrss.exe
396 winlogon.exe
440 services.exe
452 lsass.exe
604 svchost.exe
664 svchost.exe
720 svchost.exe
792 spoolsv.exe
1092 Explorer.EXE
1328 hdsp32.exe
1344 hdspmix.exe
1784 totalcmd.exe
1848 firefox.exe
524 foobar2000.exe
1888 oggenc2.exe
1876 drwtsn32.exe
*----> Modulliste <----*
(0000000000400000 - 000000000078a000: C:\WINDOWS\system32\oggenc2.exe
(000000005d450000 - 000000005d4ea000: C:\WINDOWS\system32\comctl32.dll
(0000000076330000 - 000000007634d000: C:\WINDOWS\system32\IMM32.DLL
(00000000773a0000 - 00000000774a3000: C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
(0000000077b10000 - 0000000077b32000: C:\WINDOWS\system32\Apphelp.dll
(0000000077bd0000 - 0000000077bd8000: C:\WINDOWS\system32\VERSION.dll
(0000000077be0000 - 0000000077c38000: C:\WINDOWS\system32\msvcrt.dll
(0000000077da0000 - 0000000077e4a000: C:\WINDOWS\system32\ADVAPI32.dll
(0000000077e50000 - 0000000077ee2000: C:\WINDOWS\system32\RPCRT4.dll
(0000000077ef0000 - 0000000077f39000: C:\WINDOWS\system32\GDI32.dll
(0000000077f40000 - 0000000077fb6000: C:\WINDOWS\system32\SHLWAPI.dll
(0000000077fc0000 - 0000000077fd1000: C:\WINDOWS\system32\Secur32.dll
(000000007c800000 - 000000007c908000: C:\WINDOWS\system32\kernel32.dll
(000000007c910000 - 000000007c9c9000: C:\WINDOWS\system32\ntdll.dll
(000000007e360000 - 000000007e3f1000: C:\WINDOWS\system32\USER32.dll
*----> Statusabbild für Threadkennung 0x5b4 <----*
eax=0012fdec ebx=00000000 ecx=00345050 edx=00343dc4 esi=00000000 edi=00000000
eip=00418478 esp=0012fadc ebp=0012ff78 iopl=0         nv up ei pl nz na po nc
cs=001b  ss=0023  ds=0023  es=0023  fs=003b  gs=0000             efl=00000206
*** ERROR: Module load completed but symbols could not be loaded for C:\WINDOWS\system32\oggenc2.exe
Funktion: oggenc2
        00418466 d9660f           fldenv  [esi+0xf]
        00418469 1f               pop     ds
        0041846a 8400             test    [eax],al
        0041846c 0000             add     [eax],al
        0041846e 0000             add     [eax],al
        00418470 57               push    edi
        00418471 56               push    esi
        00418472 55               push    ebp
        00418473 53               push    ebx
        00418474 8b742414         mov     esi,[esp+0x14]
FEHLER ->00418478 0fb616           movzx   edx,byte ptr [esi]      ds:0023:00000000=??
        0041847b 33c9             xor     ecx,ecx
        0041847d 33db             xor     ebx,ebx
        0041847f 85d2             test    edx,edx
        00418481 742b             jz      oggenc2+0x184ae (004184ae)
        00418483 b801000000       mov     eax,0x1
        00418488 f7c280000000     test    edx,0x80
        0041848e 7414             jz      oggenc2+0x184a4 (004184a4)
        00418490 81e2e0000000     and     edx,0xe0
        00418496 8d6802           lea     ebp,[eax+0x2]
        00418499 40               inc     eax
*----> Stack Back Trace <----*
WARNING: Stack unwind information not available. Following frames may be wrong.
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\kernel32.dll -
ChildEBP RetAddr  Args to Child
0012ff78 0045bf6c 00000008 00343da8 00342f50 oggenc2+0x18478
0012ffc0 7c817077 02007265 00000000 7ffdf000 oggenc2+0x5bf6c
0012fff0 00000000 0045bfc3 00000000 78746341 kernel32!RegisterWaitForInputIdle+0x49
*----> Raw Stack Dump <----*
000000000012fadc  00 00 00 00 78 ff 12 00 - 30 7b 47 00 00 00 00 00  ....x...0{G.....
000000000012faec  1a 1e 41 00 00 00 00 00 - ec fd 12 00 c0 4f 34 00  ..A..........O4.
000000000012fafc  e8 fd 12 00 01 00 00 00 - c4 97 46 00 80 57 88 7c  ..........F..W.|
000000000012fb0c  88 fe 12 00 8c fe 12 00 - 90 fe 12 00 94 fe 12 00  ................
000000000012fb1c  98 fe 12 00 9c fe 12 00 - 10 02 10 02 10 02 10 02  ................
000000000012fb2c  10 02 10 02 10 02 10 02 - 12 03 10 02 10 02 10 02  ................
000000000012fb3c  10 02 10 02 10 02 10 02 - 14 02 14 02 10 02 12 03  ................
000000000012fb4c  10 02 10 02 10 02 14 02 - 12 03 10 02 10 02 10 02  ................
000000000012fb5c  10 02 10 02 01 03 01 03 - 01 03 01 03 01 03 01 03  ................
000000000012fb6c  01 03 01 03 01 03 01 03 - 01 03 01 03 01 03 01 03  ................
000000000012fb7c  01 03 01 03 c0 9f 00 00 - 01 03 01 03 01 03 01 03  ................
000000000012fb8c  00 00 00 00 01 03 01 03 - 01 03 01 03 40 06 15 00  ............@...
000000000012fb9c  01 03 02 03 02 03 02 03 - 02 03 02 03 02 03 02 03  ................
000000000012fbac  02 03 02 03 02 03 02 03 - 78 01 15 00 02 03 02 03  ........x.......
000000000012fbbc  02 03 02 03 02 03 02 03 - 02 00 00 00 02 03 02 03  ................
000000000012fbcc  02 03 10 02 02 03 02 03 - 02 03 02 03 02 03 02 03  ................
000000000012fbdc  a0 32 15 00 20 01 02 03 - 04 05 06 07 08 09 0a 0b  .2.. ...........
000000000012fbec  0c 0d 0e 0f 10 11 12 13 - 14 15 16 17 18 19 1a 1b  ................
000000000012fbfc  0c 00 00 00 20 21 22 23 - 24 25 26 27 28 29 2a 2b  .... !"#$%&'()*+
000000000012fc0c  78 01 15 00 30 31 32 33 - 88 30 15 00 38 39 3a 3b  x...0123.0..89:;
*----> Symboltabelle <----*
I've also wrote to the rarewares guys about this ...
quite a few people reporting the same issues in this thread....
http://www.hydrogenaudio.org/forums/index....showtopic=79762
and the rarewares guy is on holiday until 11th april so i guess you'll have to wait, revert to an old version or find another compile.
Alright. Thank you!
o.O
Sorry, but what changes 2.86 contains? (from 2.85)
🇺🇦 Glory to Ukraine!
o.O
These:
libvorbis 1.3.1 (2010-02-26) -- "Xiph.Org libVorbis I 20100325 (Everywhere)"
* tweak + minor arithmetic fix in floor1 fit
* revert noise norm to conservative 1.2.3 behavior pending more listening testing
Is there any news about fixing this problem???
I get the same error (OggEnc 2.86 on Windows XP Pro SP3, Pentium 4 HT 3 Ghz)
The bug has nothing to do with foobar2000. You will see that oggenc2.exe crashes when using pipes even on command prompt. For example try with command "oggenc2 - -o outfile.ogg < infile.wav".
Really... Works fine with temporary file (e.g. -s %r -Q -q5,000000 %s -o %d)
Thank you. But I'm still waiting for pipe encoding fix:)
FIXED (OggEnc 2.87)
Many thanks
oggenc2-87-1.3.1
foobar2000 v1.0.2.1
windowsXP
Source: "D:\track2.ac3"
An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "D:\track2.ogg"
Encoder stream format: 48000Hz / 6ch / 32bps
Command line: "E:\Soft\oggenc2.87-1.3.1-generic\oggenc2.exe" -s 1445268101 -Q -q5,000000 - -o "track2.ogg"
Working folder: D:\
Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
the same error with flac
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\track2.flac"
Encoder stream format: 48000Hz / 6ch / 24bps
Command line: "C:\Program Files\FLAC\flac.exe" -s --ignore-chunk-sizes -8 - -o "track2.flac"
Working folder: D:\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
Maybe you should start a new thread with this problem ...
