Topic: lame 3.98.4, 3.99 alpha (Read 203841 times) previous topic - next topic
Reply #75
How much of a speed difference is there between 3.98.4 and 3.99.a10 ?
Reply #76
On Q6600 systems @ 3.2GHz, 3.98.4 64bit runs at approx 37x and 32bit at approx 41x. With 3.99a10 the numbers are similar only reversed.
Reply #77
john33,
I have a performance issue with 3.99a10 build from rarewares. It runs at half of speed comparing to 3.98.4 rarewares's build.
PC: AMD Turion II P540 http://www.cpu-world.com/CPUs/K10/AMD-Turi...540SGR23GM.html
Windows 7 32 bits.
Both build run equally fast at Intel PC.
tsnr's build 3.99a10 directly doesn't run.
Reply #78
john33,
Windows 7 32 bits.
I'll take a look at this when I return home - I'm away at the moment, but it will probably not be until next week.
Reply #81
Have tried with different versions of iccpatch (GUIed one too). Didn't work.
Reply #83
Has anybody conducted any tests comparing the recent 3.99 alphas with 3.98.4? I'm lacking a proper equipment to test at the moment.
Infrasonic Quartet + Sennheiser HD650 + Microlab Solo 2 mk3.
Reply #84
I've run several test with Lame 3.98.4 and 3.99a10... as of right now both seem to produce the same file. I built both build with the same settings.
Here's a pic from both on the same file.
Reply #85
3.99a contains the new VBR mode which enables with --vbr-new key. In other modes the result will be the same as for lame 3.98.4
🇺🇦 Glory to Ukraine!
Reply #86
Sorry, yes, my bad... I don't use vbr-new because it make larger file using -V4 with 3.98.4 and 3.99a10.
Here are some shot of 3.97, 3.98.4 and 3.99a10 on the same file.
Reply #88
Hm, I see that bitrate distribution is different for two compiles:
Alpha 10 from here:
http://lame.bakerweb.biz/
and
lvqcl's build http://filekeeper.org/download/shared/lame_a10.rar
--silent -V 2 --vbr-new --noreplaygain
bakerweb.biz - 216kbps avg
lvqcl's - 208 kbps avg
Yes, different compiles produce different file.
My MVS VC9 Build
My MinGW Build
Bakerweb Build
Rareware Build
Reply #89
4 Different builds. Same file using "lame.exe --noreplaygain -V 4 test.wav test.mp3"
Rareware Build
My MVS VC9 Build
Bakerweb Build
My MinGW Build
Reply #90
Same file using -V2.
Rareware, My MSV VC9, Bakerweb, My MinGW build
Reply #91
But why??
Reply #92
But why??
Different Libraries used in compilers, diff settings used when compiling, diff compilers... which boils down to in the end, different rounding of numbers.
Though not sure why vbr-old doesn't differ so much(same bitrate size, a few different bitrates here and there) as where vbr-new differs alot in bitrate size between compiles with 3.99a10
Reply #93
So, now I must ask: which is the best? Of course, in terms of quality
Reply #94
That I can't answer... All of them I guess... I don't think there really is a BAD compiler for Final ver's of Lame.
Maybe robert or john33 could answer that better.
Reply #95
That question has been asked many times before and to the best of my knowledge no one has yet been able reliably to differentiate between the outputs from the encoders compiled with different compilers. So it's safe to say that you can use whichever takes your fancy.
Reply #96
Having an issue compiling Lame 3.98.4 or 3.99a10 with MSVS 2010... Lame 3.91-3.97 compiles fine.
Can compile Lame 3.98.4 and 3.99a10 fine with MSVS 2008.
Seems to be a linker option that is no longer valid but don't know where to start... any help would be appreciated.
Setting environment for using Microsoft Visual Studio 2010 x86 tools.
C:\Program Files\Microsoft Visual Studio 10.0\VC>cd lame3984
C:\Program Files\Microsoft Visual Studio 10.0\VC\lame3984>nmake -f Makefile.MSVC
Microsoft ® Program Maintenance Utility Version 10.00.30319.01
Copyright © Microsoft Corporation.  All rights reserved.
building LAME featuring RH
+ ASM
+ MMX
using MS COMPILER
+ optimizing for Pentium II/III
+ using Single precision
Pass GTK=YES to build the frame analyzer. (requires installed GTK)
main.c
LINK : fatal error LNK1117: syntax error in option 'opt:NOWIN98'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 10.0\VC\BI
N\link.EXE"' : return code '0x45d'
Stop.
Reply #97
Edit Makefile.MSVC and remove /opt:NOWIN98 around line 236.
Reply #99
I asked the same question about different bitstream of 320 CBR encoded with two compiles. The difference between them was a small digital 1-bit noise. These could be the results of some processing optimizations.
But here we have different bitrates, and I think this is very strange and must affect quality.
Again:
john33 build - 191 kbps
tsnr (bakerweb.biz) - 185 kbps
lvqcl - 185 kbps
