Topic: lame 3.98.4, 3.99 alpha (Read 203903 times) previous topic - next topic
Reply #125
I tried the x64 ACM codec as it includes an INF file this time but it crashes Vegas Pro so it seems it is not working.
Does anyone have any idea?
Well, still no luck here, but I found an interim solution as described here:
http://www.hydrogenaudio.org/forums/index....showtopic=87076
But I would very much prefer using an ACM codec based on LAME, should one be available and usable. I don't have the skills to create one myself, but I can test an already built one if need be.
Reply #126
Alpha 14 bundles are now at Rarewares.
Reply #127
Just checked john33's compiled binary, the header is there.
Do you do anything special? How do you call LAME? How do you determine the existence of the header?
Both with Foobar2000 "-S --noreplaygain -V 2 - %d" and command line "lame.exe --noreplaygain -V 2 test.wav test.mp3"
In Foobar2000, it's not showing the ver of Lame used to encoder and EncSpot is showing Gogo 3.0 as encoder with the Lame Header showing just Xing Tag
I noticed this too. In prior versions of lame, prior versions of foobar would show the version of lame under the field "tool" in properties.
I don't know whether it's the version of lame (3.99 alpha 13 & 14) or the version of foobar (1.1.4 &  1.1.5) that's the problem.
Perhaps someone should notify the foobar people.
Reply #128
It's not all Foobar... in alpha 13 and 14 the encoder short VersionString, which Foobar reads to show the ver used, was changed... older ver's of Lame were something like "LAME3.98r" now in Alpha 13 and 14 it's "L3.99a14". And it seems if Foobar doesn't see "LAME" it's doesn't think it Lame.
It seems, Foobar2000 assumes the "Encoder short VersionString" has to start with LAME.
Reply #129
Where can I find an up to date ChangeLog for Lame?
Reply #131
Sorry, I'll update the changelog later.
Reply #133
Is there a v3.98.4 modified lame_enc.dll to use .ini settings? The latest I see on rarewares is v3.98.2. Thanks.
Reply #134
Not currently, but I'll have a look at producing one. Given personal commitments, it will probably be some time next week, I'm afraid.
Reply #136
Lame 3.99a16 is available.
Reply #137
Now available at Rarewares.
Reply #140
Hi Guys!
What is the change list?
Reply #141
I've tried 3.98.4 and 3.99a16 on EIG sample.  V0
3.99 has higher bitrate for V0 but it's ok because it's highest VBR mode.
3.99a16 - 295 kbps
3.98.4 - 249 kbps.
And those extra bits were useful
ABC/HR for Java, Version 0.53a, 08 April 2011
Testname:
Tester: IgorC
1L = D:\Public test\Sample12\LAME 3.99a16 V0 VBR NEW sample12.wav
2R = D:\Public test\Sample12\LAME 3.98.4 V0 sample12.wav
Ratings on a scale from 1.0 to 5.0
General Comments:
1L File: D:\Public test\Sample12\LAME 3.99a16 V0 VBR NEW sample12.wav
1L Rating: 4.5
1L Comment: distortion in the form of flat/soft pulses during 2.75-3.15 seconds. But it's still better than sample 2.
2R File: D:\Public test\Sample12\LAME 3.98.4 V0 sample12.wav
2R Rating: 3.0
2R Comment: more pronounceable/ stronger  pre-echo
ABX Results:
Original vs D:\Public test\Sample12\LAME 3.98.4 V0 sample12.wav
   5 out of 5, pval = 0.031
Original vs D:\Public test\Sample12\LAME 3.99a16 V0 VBR NEW sample12.wav
---- Detailed ABX results ----
Playback Range: 00.000 to 15.000
   2:35:03 PM p 1/1 pval = 0.5
   2:35:06 PM p 2/2 pval = 0.25
   2:35:10 PM p 3/3 pval = 0.125
   2:35:12 PM p 4/4 pval = 0.062
   2:35:16 PM p 5/5 pval = 0.031
   2:38:32 PM p 1/1 pval = 0.5
   2:38:38 PM p 2/2 pval = 0.25
   2:38:43 PM p 3/3 pval = 0.125
   2:38:50 PM p 4/4 pval = 0.062
   2:38:57 PM p 5/5 pval = 0.031
Reply #143
Beta 0 compiles now at Rarewares.
Reply #145
LAME 3.99b0 produces more obvious warbling on hi-hat and voice (or flanging?) than 3.98.4  does on this sample
http://www.hydrogenaudio.org/forums/index....showtopic=88321
ABC/HR for Java, Version 0.53a, 23 April 2011
Testname:
Tester: IgorC
1R = D:\Artifacts_Training\A matter of time\3.99b0 V5.wav
2R = D:\Artifacts_Training\A matter of time\3.98.4 V5.7 original.wav
General Comments:
1R File: D:\Artifacts_Training\A matter of time\3.99b0 V5.wav
1R Rating: 3.5
1R Comment:
2R File: D:\Artifacts_Training\A matter of time\3.98.4 V5.7 original.wav
2R Rating: 4.0
2R Comment:
ABX Results:
Properties of Setup test: Additional offset 2000ms,  gain is calculated.
Though V2 is pretty good and it's difficult to say the difference between two versions of LAME.
Reply #146
IS V0 getting so high bit-rates to the point we can forget it ad just use 320 cbr
Reply #147
Testname:
Tester: IgorC
General Comments:
1R Rating: 3.5
1R Comment:
2R Rating: 4.0
2R Comment:
ABX Results:
IgorC, if you could, could you please repeat the test but with -V 5 --vbr-old for 3.99 b0... I found on a few samples/test I've done that when 3.99b0 -V # fails against 3.98.4... 3.99b0 -V # --vbr-old seemed better
Reply #148
Yes, 3.99b0 VBR OLD was better than default VBR mode and was on par with 3.98.4.
It's very easy to spot the difference of Original vs Lossy. But the mind starts to play tricky games when it is Lossy A vs Lossy B. Especially when  it's the same encoder and artifacts are very similar.
To avoid such tricky mind games I have done blind test in two passes.
1.Exclusively ABC/HR + training mode. During this pass I put the mark to encoders (1.0 - 5.0).
2. Exclusively ABXY of Lossy A vs Lossy B. ABXY works better than ABX for similar artifacts.
ABC/HR log:
ABC/HR for Java, Version 0.53a, 28 April 2011
Testname:
Tester: IgorC
2L = D:\Artifacts_Training\A matter of time\3.99b0 V5 VBR OLD.wav
General Comments:
1R Rating: 2.8
1R Comment:
2L File: D:\Artifacts_Training\A matter of time\3.99b0 V5 VBR OLD.wav
2L Rating: 3.3
2L Comment:
ABX Results:
ABX log:
foo_abx 1.3.4 report
foobar2000 v1.1.6
2011/04/28 22:26:02
File A: D:\Artifacts_Training\A matter of time\3.99b0 V5 VBR OLD.mp3
File B: D:\Artifacts_Training\A matter of time\3.99b0 V5.mp3
22:26:02 : Test started.
22:28:28 : 01/01  50.0%
22:28:34 : 02/02  25.0%
22:29:00 : 03/03  12.5%
22:29:04 : 04/04  6.3%
22:29:16 : 05/05  3.1%
22:29:35 : Test finished.
Total: 5/5 (3.1%)
Reply #149
Where can I find a source tarball for 3.99b0?
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
