Topic: EAC Drive Options > C2 Error Info (Read 2150 times) previous topic - next topic
Unless you know that you can use this setting reliably, disable it. If you choose to enable it, make sure you also use Test & Copy.
Maybe this could be updated, regarding the use of AccurateRip ?
edit: link
Done.
