Topic: Pause Noise Bug in 0.586 (Read 4263 times) previous topic - next topic
If you play a song and press pause button several times, foobar will bring a noise in the speaker, instead of resume playing the mp3.
Foobar 0.91, Windows XP SP2
Perhaps you could reveal a little more info.
Windows version?
DSP plugins?
Output plugin?
Type of file?
Any other info?
Sorry
Windows 2000 Sp3
DSP -> just Volume Control
Output -> Direct Sound
Typ of File -> Mp3
Can you reproduce it?
Can't reproduce here... Same setup as above with a SBlive card.  I even tried holding down 'x' to autofire pause  Looks like a sound card issue.
same here...
foobar 'ckicks' on pause/depause and not always starts CBR 128 kbps MP3z - just click and no sound (progressbar moving silently)
Win2k SP3 Russian
foobar .586
kernel streaming
AC97 on MSI Via KT133A m/b
equalizer + simple bass DSP
latest Via 4in1 - 4.46
latest Via sound drivers
Edit: EncSpot info follows
128    ||||||||||||||||||||||||||||||||||||||||      100.0%
Type                  : mpeg 1 layer III
Bitrate                : 128
Mode                  : joint stereo
Frequency          : 44100 Hz
Frames              : 18207
Length                : 00:07:55
Av. Reservoir      : 407
Scalefac              : 23.5%
Bad Last Frame    : no
Encoder              : FhG (l3enc)
--[ EncSpot 2.0 ]--[ http://www.guerillasoft.com ]--
who | grep -i blonde | date; cd ~; unzip; touch; strip; finger; mount; gasp; yes; uptime; umount; sleep
I had this same problem using DirectSound also.
I'd get a loud buzzer sound when I paused and another sound was playing.
I'm guessing it occurs when 2 independent DS calls are made.
I'm using KS now, so I don't get that problem anymore.
I think its a bug though, since I never got problem with Winamp.
The same thing happens to me.
Windows 2000 SP3
SB Live Soundcard
foobar 0.586
DSP -> only the resampler
The bug also happens with
Waveout plugin
Kernel Streaming
Windows 2000 SP3
SB Live Soundcard
foobar 0.586
unable to reproduce with an identical config save for using kernel streaming instead of ds.
edit: just tried directsound and waveout and they work ok too.
I tested it again, it seems so that you have to restart foobar until the output plugin settings will take effect. After testing all 3 output plugins, I think Gemini was right.
Waveout and Kernel Streaming works flawlessly.
Just DirectSound still has this feature.
At the moment I have switched to WaveOut and have no problems.
