Topic: OggVorbis Daily Binaries are back! (Read 2678 times) previous topic - next topic
There were some library changes over night to the CVS, a new set of Daily Binaries - oggenc, version 2 vorbis.dll and oggdrop will soon be at: http://www.inf.ufpr.br/~rja00/ . I don't know how significant the changes are yet, but things are on the move again!
I also discovered a small bug in oggdrop!! The stored encoding options weren't getting sent to the encoder unless you accessed the options menu. This has been fixed and new versions sent to Roberto.
All the above should be there sometime soon, after Roberto wakes up in Brazil!
john33
could someone compile the new oggenc with ICL ? It was definitively faster then this one
Note that one of the commits contains the following comment:
experimental, test it well.
This particular commit reduces memory usage during decode, so OggDrop isn't affected. The other commits mainly fix a few bugs.
