Re: [Not My Release] EsPlaylist Reply #675 – 2016-04-14 22:28:49 Quote from: marc2003 on 2016-04-14 22:25:39Not possible... Well it is if you implement it in your own playlist viewer that isn't restricted by simple title formatting.You mean a WSH or JScript panel?
Re: [Not My Release] EsPlaylist Reply #677 – 2016-06-03 21:57:30 Can someone tell me how to get EsPlaylist to display multiple disc titles like this SimPlaylist layout? Thanks!
Re: [Not My Release] EsPlaylist Reply #678 – 2016-11-19 02:59:10 Is there a way to set it so that after i click on an album and then select an artist on the filter the playlist shows the albums like it was instead of like i'd already clicked an album?
Re: [Not My Release] EsPlaylist Reply #679 – 2016-11-20 23:07:59 Is there a way to change the grouping in the layered view without changing the grouping in flat view?
Re: [Not My Release] EsPlaylist Reply #680 – 2016-11-21 18:32:37 Quote from: xiaNaix on 2016-06-03 21:57:30Can someone tell me how to get EsPlaylist to display multiple disc titles like this SimPlaylist layout? Thanks!You can get close by adding a new grouping level grouped by discnumber and with a title such as Code: [Select][Disc %discnumber%]$repeat( ,1000) The spaces added with the repeat function are to get rid of the horizontal line on the right of the group title, but in turn you will get a small ellipsis punctuation at the right end of the column.
Re: [Not My Release] EsPlaylist Reply #681 – 2017-05-23 17:04:24 Clicking the link in the OP no longer displays the components page. Since I can't remember if there were any other links does anyone know what the current download page is?
Re: [Not My Release] EsPlaylist Reply #682 – 2017-05-23 19:34:11 Here's a link to the component if you still need it.esplaylist
Re: [Not My Release] EsPlaylist Reply #683 – 2017-05-24 11:04:43 Quote from: MachineHead on 2017-05-23 19:34:11Here's a link to the component if you still need it.esplaylistThanks. It's actually for when linking to others. Found that archive.org has the page and zip files archived so I think I'll use that for now.
Re: [Not My Release] EsPlaylist Reply #684 – 2017-11-30 22:53:25 Hey guys, I have installed Esplaylist plugin but am having issues with rating songs. I am double clicking stars but nothing happens. How do I actually make it work?Any tips much appreciated Max
Re: [Not My Release] EsPlaylist Reply #685 – 2017-12-01 12:31:27 Quote from: mwasilewko on 2017-11-30 22:53:25Hey guys, I have installed Esplaylist plugin but am having issues with rating songs. I am double clicking stars but nothing happens. How do I actually make it work?Any tips much appreciated MaxI found a solution for this, in case anyone has the same issue you need to click right mouse button on stars, choose OPTIONS and select INLINE TAG EDITING. Then click right mouse button on RATING column -> COLUMN OPTIONS -> unselect ENABLE RATING EDITING. To rate a song double click on stars and typ number from 0 to 5. Done
Re: [Not My Release] EsPlaylist Reply #686 – 2017-12-01 15:04:20 Or....you could just bind a numpad key to a keyboard shortcut.
Re: [Not My Release] EsPlaylist Reply #687 – 2018-01-11 00:51:52 Hi, I have a question about cover display.I can't make EsPlaylist display my album covers on the left side.EsPlayist is configured to display the "cover front".foobar's standard artwork display component displays it perfectly.The covers are not in the music folders (no "folder.jpg" naming), but in different folders.Any hints ?
Re: [Not My Release] EsPlaylist Reply #688 – 2018-01-11 15:23:32 Quote from: wcs13 on 2018-01-11 00:51:52...foobar's standard artwork display component displays it perfectly.Perhaps you set up the correct artwork source in the columns ui artwork preferences, but not in the built-in artwork reader?
Re: [Not My Release] EsPlaylist Reply #689 – 2018-01-11 17:49:19 Nope, I'm using DUI and the artwork sources have been set in Prefs > Display > Album art (I have 13 different artwork sources, see here : https://hydrogenaud.io/index.php/topic,115275.msg950994.html#info_950994 )The standard display component displays perfectly the artwork for all my albums, but I can't get EsPlaylist to do the same.
Re: [Not My Release] EsPlaylist Reply #690 – 2018-01-12 13:56:52 Quote from: wcs13 on 2018-01-11 17:49:19Nope, I'm using DUIRight, I'm so used to columns UI that I forgot EsPlaylist works on both interfaces. Unfortunately I'm not very familiar with the DUI artwork panel, but I massively use EsPlaylist and I never have such issues. Both components rely on the search patterns set in the album art preferences, therefore they should both work or none of them should, unless they are set to display different kinds of album art. That's why I'm inclined to think there is some flaw in your front cover search pattern and the reason the DUI artwork panel works is because it is set to show something else, such as the embedded icon.
Re: [Not My Release] EsPlaylist Reply #691 – 2018-12-02 12:33:49 Hello. The problem has been discussed since 2010 - when I increase the size of a column, my covers are reduced but not increased by more than 314px
Re: [Not My Release] EsPlaylist Reply #692 – 2018-12-02 12:35:14 2 more questions, when adding a rating, it hangs for 3 seconds and how to clear the base of dead tracks that are not there
Re: [Not My Release] EsPlaylist Reply #693 – 2019-12-17 09:35:29 I would like to know if from the Esplaylist component I can know the active playlist (For example: %playlist%)
Re: [Not My Release] EsPlaylist Reply #694 – 2019-12-17 13:58:41 Quote from: josemescud on 2019-12-17 09:35:29I would like to know if from the Esplaylist component I can know the active playlist (For example: %playlist%)Unfortunately you can't.
Re: [Not My Release] EsPlaylist Reply #696 – 2019-12-19 10:08:19 Quote from: ZevenMortem on 2019-12-17 19:18:04Sorry no, use playlist managerThanks for the reply. I don't quite understand what "Playlist Manager" is. Is it a component ?. It does not appear with that name in the repository. If possible, I would be grateful if you would extend your answer a bit.What I need is to be able to ask from the Esplaylist for the name of the active playlist.Soy español. Dejo la pregunta en español por si la lee algún latino:Gracias por la respuesta. No entiendo bien qué es "Playlist Manager". ¿Se trata de un componente?. No figura con ese nombre en el repositorio. Si es posible agradecería que ampliase un poco su respuesta.Lo que yo necesito es poder preguntar desde la Esplaylist por el nombre de la playlist activa.
Re: [Not My Release] EsPlaylist Reply #697 – 2019-12-19 16:47:06 ^ I think they meant the panel included with foobar - View menu > Playlist Manager. (Not what you wanted)As mentioned, getting the %playlist% name is not possible with ESPlaylist. The only custom fields are the ones mentioned in the documentation (included TXT file) - %es_subgroup_count% , etc
Re: [Not My Release] EsPlaylist Reply #698 – 2019-12-26 15:17:15 Quote from: josemescud on 2019-12-17 09:35:29I would like to know if from the Esplaylist component I can know the active playlist (For example: %playlist%)may be, this will help for you. If you dubbleklick in foobar at the bottom, on "Playing: (***your active Song***)" it jumps to the just played Song in the just active playlist.
