Topic: [Not My Release] EsPlaylist (Read 339830 times) previous topic - next topic
Reply #425
My album covers wont show in EsPlaylist (I use the setting that cover.jpg in the same map as the file shall be the cover). Can this be fixed?
EDIT: Wait... What? It suddenly showed... Maybe it didn't had time to update, nevermind.
Reply #426
Try this and lets say Thank you very much
Reply #427
Hello
What is the purpose of checkboxes next to items on Preset settings list in Preferences?
TIA
Reply #428
This has been answered a couple of pages back:
* AFAIK, the crossed item is the default grouping level when you select a preset grouping: for example if you have a preset with 2 grouping level: the upper one for the artist and the lower for the album. The latter is the one checked. Then the first time you select this grouping, the EsPlaylist will show the album grouping level
Reply #429
Is there any way of putting the information next to the album art UNDER the album art instead?
Reply #431
Darn. OK thanks anyway. What would be the best way to go around getting it underneath. Obviously not using ESplaylist, is there another method?
Reply #432
Crash raport
[code]Illegal operation:
Code: AA67913Ch, flags: 00000001h, address: 768CB727h
Bug check
Call path:
entry=>app_mainloop=>main_thread_callback::callback_run=>on_items_removed
Code bytes (768CB727h):
768CB6E7h: C0 89 45 B8 C7 45 BC CF B6 8C 76 39 45 14 74 23
768CB6F7h: 8B 45 10 83 F8 0F 76 03 6A 0F 58 89 45 C0 C1 E0
768CB707h: 02 50 FF 75 14 8D 45 C4 50 E8 0D A9 02 00 83 C4
768CB717h: 0C EB 03 89 45 C0 8D 45 B0 50 FF 15 6C 11 8C 76
768CB727h: C9 C2 10 00 CC CC CC CC CC 8B FF 55 8B EC 56 8B
768CB737h: 75 08 83 FE F4 72 18 83 FE F6 77 13 8D 45 08 50
768CB747h: 6A 00 56 E8 DD 02 00 00 85 C0 74 03 8B 75 08 56
768CB757h: FF 15 3C 10 8C 76 5E 85 C0 7C 05 33 C0 40 EB 08
Stack (0035E5DCh):
0035E5BCh: 00000000 FFFFFD34 000002E4 FFFFFD34
0035E5CCh: 000002CC 00000019 00000000 0035E5DC
0035E5DCh: AA67913C 00000001 00000000 768CB727
0035E5ECh: 00000000 0DC6444F FFFFFFFE 76F9E1CC
0035E5FCh: 76F9DF32 01535C14 049A8028 00000018
0035E60Ch: 00000001 0035E6D8 01535C38 00000001
0035E61Ch: 01535C58 00000000 0035E6D8 00000000
0035E62Ch: 0035E668 73F5270F AA67913C 00000001
0035E63Ch: 00000000 00000000 053324F0 053324E8
0035E64Ch: 00000001 0035E644 0035E1B0 0035E698
0035E65Ch: 73F68068 73F6E5D8 00000000 0035E67C
0035E66Ch: 01440774 014C8B3D 01250000 00000000
0035E67Ch: 0035E6A4 0147CB15 053324F0 0000591B
0035E68Ch: 01535C14 053324E8 01534F94 0035E6BC
0035E69Ch: 014DC8E0 00000001 0035E6C8 0147D195
0035E6ACh: 053324E8 00000001 049A8028 053324E8
0035E6BCh: 0035E6E8 014DF8DB 00000000 0035E6F4
0035E6CCh: 72DE9FC3 0035E6D8 00000001 01535C14
0035E6DCh: 049A8018 00000000 01535C14 0035E7C4
0035E6ECh: 72E17855 00000000 0035E7D0 72E148D6
Registers:
EAX: 0035E5DC, EBX: 00000001, ECX: 01534F94, EDX: 01440720
ESI: 053324E8, EDI: 053324F0, EBP: 0035E62C, ESP: 0035E5DC
Crash location:
Module: KERNELBASE
Offset: B727h
Symbol: "RaiseException" (+58h)
Loaded modules:
foobar2000 loaded at 01390000h - 01580000h
ntdll loaded at 76F70000h - 770F0000h
kernel32 loaded at 756E0000h - 757E0000h
KERNELBASE loaded at 768C0000h - 76906000h
COMCTL32 loaded at 72B70000h - 72D0E000h
msvcrt loaded at 76430000h - 764DC000h
GDI32 loaded at 75550000h - 755E0000h
USER32 loaded at 755E0000h - 756E0000h
ADVAPI32 loaded at 75450000h - 754F0000h
sechost loaded at 751F0000h - 75209000h
RPCRT4 loaded at 76A80000h - 76B70000h
SspiCli loaded at 74AE0000h - 74B40000h
CRYPTBASE loaded at 74AD0000h - 74ADC000h
LPK loaded at 767E0000h - 767EA000h
USP10 loaded at 76740000h - 767DD000h
SHLWAPI loaded at 76910000h - 76967000h
DSOUND loaded at 73EB0000h - 73F22000h
ole32 loaded at 74F20000h - 7507C000h
WINMM loaded at 72B30000h - 72B62000h
POWRPROF loaded at 73F80000h - 73FA5000h
SETUPAPI loaded at 765A0000h - 7673D000h
CFGMGR32 loaded at 751C0000h - 751E7000h
OLEAUT32 loaded at 769F0000h - 76A7F000h
DEVOBJ loaded at 76850000h - 76862000h
UxTheme loaded at 720E0000h - 72160000h
SHELL32 loaded at 757E0000h - 76429000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 73F50000h - 73F7B000h
imagehlp loaded at 75210000h - 7523A000h
dbghelp loaded at 73560000h - 7364B000h
COMDLG32 loaded at 76970000h - 769EB000h
Secur32 loaded at 74430000h - 74438000h
CRYPT32 loaded at 74CA0000h - 74DBC000h
MSASN1 loaded at 74DD0000h - 74DDC000h
gdiplus loaded at 733D0000h - 73560000h
IMM32 loaded at 767F0000h - 76850000h
MSCTF loaded at 74B40000h - 74C0C000h
CLBCatQ loaded at 76510000h - 76593000h
MMDevApi loaded at 73E70000h - 73EA9000h
PROPSYS loaded at 732D0000h - 733C5000h
dwmapi loaded at 729B0000h - 729C3000h
foo_burninate loaded at 10000000h - 10040000h
foo_freedb2 loaded at 73E30000h - 73E70000h
foo_input_alac loaded at 00240000h - 0025D000h
foo_input_ofr loaded at 00370000h - 003AD000h
OptimFROG loaded at 00460000h - 00492000h
foo_input_monkey loaded at 00F30000h - 00F78000h
foo_run loaded at 01040000h - 0109F000h
foo_vst loaded at 73DE0000h - 73E0E000h
MSVCP90 loaded at 73D00000h - 73D8E000h
MSVCR90 loaded at 73690000h - 73733000h
foo_converter loaded at 73250000h - 732CB000h
foo_input_tak loaded at 73200000h - 73244000h
tak_deco_lib loaded at 00FE0000h - 01000000h
foo_cdda loaded at 731B0000h - 731FE000h
foo_fileops loaded at 73160000h - 731A7000h
foo_input_tta loaded at 03110000h - 03152000h
foo_playcount loaded at 73120000h - 7315C000h
foo_uie_wsh_panel_mod loaded at 73050000h - 73112000h
Msimg32 loaded at 72A60000h - 72A65000h
foo_chacon loaded at 73660000h - 73684000h
foo_input_std loaded at 72EF0000h - 73045000h
foo_albumlist loaded at 72E90000h - 72EED000h
foo_rgscan loaded at 72E40000h - 72E8D000h
foo_uie_esplaylist loaded at 72DD0000h - 72E38000h
foo_r128scan loaded at 71CE0000h - 71D22000h
foo_ui_std loaded at 718F0000h - 71A08000h
AUDIOSES loaded at 72D80000h - 72DB6000h
SXS loaded at 74270000h - 742CF000h
WindowsCodecs loaded at 71A10000h - 71B0B000h
jscript loaded at 717B0000h - 71862000h
VERSION loaded at 72750000h - 72759000h
CRYPTSP loaded at 718B0000h - 718C6000h
rsaenh loaded at 71870000h - 718AB000h
RpcRtRemote loaded at 71D80000h - 71D8E000h
wshom loaded at 72D50000h - 72D71000h
MPR loaded at 729D0000h - 729E2000h
ScrRun loaded at 71D50000h - 71D7A000h
sud loaded at 71270000h - 7132B000h
ADVPACK loaded at 71B90000h - 71BBE000h
DUI70 loaded at 71480000h - 71532000h
avrt loaded at 740B0000h - 740B7000h
msxml3 loaded at 74130000h - 74262000h
mshtml loaded at 6FAF0000h - 700A7000h
PSAPI loaded at 75440000h - 75445000h
urlmon loaded at 75080000h - 751B5000h
iertutil loaded at 75240000h - 7543A000h
msls31 loaded at 71B60000h - 71B8A000h
ntmarta loaded at 71C80000h - 71CA1000h
WLDAP32 loaded at 76870000h - 768B5000h
IEFRAME loaded at 6E1F0000h - 6EC6F000h
OLEACC loaded at 71230000h - 7126C000h
msxml6 loaded at 6F990000h - 6FAE7000h
winhttp loaded at 74320000h - 74378000h
webio loaded at 742D0000h - 7431F000h
WS2_32 loaded at 74DE0000h - 74E15000h
NSI loaded at 76F40000h - 76F46000h
credssp loaded at 743E0000h - 743E8000h
mswsock loaded at 74510000h - 7454C000h
wshtcpip loaded at 74800000h - 74805000h
wship6 loaded at 743D0000h - 743D6000h
mlang loaded at 715B0000h - 715DE000h
DNSAPI loaded at 74550000h - 74594000h
IPHLPAPI loaded at 744D0000h - 744EC000h
WINNSI loaded at 74500000h - 74507000h
rasadhlp loaded at 743C0000h - 743C6000h
fwpuclnt loaded at 740F0000h - 74128000h
apphelp loaded at 71430000h - 7147B000h
WININET loaded at 74E20000h - 74F14000h
Normaliz loaded at 74DC0000h - 74DC3000h
profapi loaded at 71C70000h - 71C7B000h
explorerframe loaded at 71620000h - 7178F000h
DUser loaded at 71540000h - 7156F000h
actxprxy loaded at 70170000h - 701BE000h
ieproxy loaded at 70140000h - 7016B000h
Stack dump analysis:
Address: 768CB727h (KERNELBASE+B727h), symbol: "RaiseException" (+58h)
Address: 76F9E1CCh (ntdll+2E1CCh), symbol: "RtlInitUnicodeString" (+164h)
Address: 76F9DF32h (ntdll+2DF32h), symbol: "RtlAllocateHeap" (+ACh)
Address: 01535C14h (foobar2000+1A5C14h)
Address: 01535C38h (foobar2000+1A5C38h)
Address: 01535C58h (foobar2000+1A5C58h)
Address: 73F5270Fh (shared+270Fh), symbol: "uBugCheck" (+20h)
Address: 73F68068h (shared+18068h), symbol: "uFormatSystemErrorMessage" (+DAD7h)
Address: 73F6E5D8h (shared+1E5D8h), symbol: "uFormatSystemErrorMessage" (+14047h)
Address: 01440774h (foobar2000+B0774h)
Address: 014C8B3Dh (foobar2000+138B3Dh)
Address: 0147CB15h (foobar2000+ECB15h)
Address: 01534F94h (foobar2000+1A4F94h)
Address: 014DC8E0h (foobar2000+14C8E0h)
Address: 0147D195h (foobar2000+ED195h)
Address: 014DF8DBh (foobar2000+14F8DBh)
Address: 72DE9FC3h (foo_uie_esplaylist+19FC3h)
Address: 72E17855h (foo_uie_esplaylist+47855h), symbol: "foobar2000_get_interface" (+13105h)
Address: 72E148D6h (foo_uie_esplaylist+448D6h), symbol: "foobar2000_get_interface" (+10186h)
Address: 755F6941h (USER32+16941h), symbol: "gapfnScSendMessage" (+979h)
Address: 75610155h (USER32+30155h), symbol: "DdeQueryStringW" (+6D7h)
Address: 755F6901h (USER32+16901h), symbol: "gapfnScSendMessage" (+939h)
Address: 755FCD1Ah (USER32+1CD1Ah), symbol: "GetWindow" (+21Ah)
Address: 01535CB4h (foobar2000+1A5CB4h)
Address: 72DFE1B0h (foo_uie_esplaylist+2E1B0h)
Address: 755F6F8Fh (USER32+16F8Fh), symbol: "IsThreadDesktopComposited" (+95h)
Address: 755F701Bh (USER32+1701Bh), symbol: "GetWindowLongW" (+2Eh)
Address: 755F7027h (USER32+17027h), symbol: "GetWindowLongW" (+3Ah)
Address: 72E177ACh (foo_uie_esplaylist+477ACh), symbol: "foobar2000_get_interface" (+1305Ch)
Address: 72DFE346h (foo_uie_esplaylist+2E346h)
Address: 755F9B79h (USER32+19B79h), symbol: "PostThreadMessageW" (+D0Bh)
Address: 755F6238h (USER32+16238h), symbol: "gapfnScSendMessage" (+270h)
Address: 755F68EAh (USER32+168EAh), symbol: "gapfnScSendMessage" (+922h)
Address: 755F6899h (USER32+16899h), symbol: "gapfnScSendMessage" (+8D1h)
Address: 75600AB0h (USER32+20AB0h), symbol: "FillRect" (+110h)
Address: 75600AD6h (USER32+20AD6h), symbol: "CallWindowProcW" (+1Bh)
Address: 72BA450Eh (COMCTL32+3450Eh), symbol: "DPA_Sort" (+18Dh)
Address: 72BA463Dh (COMCTL32+3463Dh), symbol: "DefSubclassProc" (+92h)
Address: 72BA44F4h (COMCTL32+344F4h), symbol: "DPA_Sort" (+173h)
Address: 755F71BEh (USER32+171BEh), symbol: "GetWindowLongW" (+1D1h)
Address: 72C9720Eh (COMCTL32+12720Eh), symbol: "Ordinal234" (+B5h)
Address: 72BA45F1h (COMCTL32+345F1h), symbol: "DefSubclassProc" (+46h)
Address: 72B9FA37h (COMCTL32+2FA37h), symbol: "ImageList_GetIcon" (+2A4h)
Address: 72B9F9FBh (COMCTL32+2F9FBh), symbol: "ImageList_GetIcon" (+268h)
Address: 72BA46E1h (COMCTL32+346E1h), symbol: "DefSubclassProc" (+136h)
Address: 72BA469Dh (COMCTL32+3469Dh), symbol: "DefSubclassProc" (+F2h)
Address: 75565689h (GDI32+15689h), symbol: "DeleteObject" (+0h)
Address: 755F7177h (USER32+17177h), symbol: "GetWindowLongW" (+18Ah)
Address: 72B9F7FDh (COMCTL32+2F7FDh), symbol: "ImageList_GetIcon" (+6Ah)
Address: 755F72F1h (USER32+172F1h), symbol: "GetDC" (+ABh)
Address: 76F800E6h (ntdll+100E6h), symbol: "KiUserCallbackDispatcher" (+2Eh)
Address: 76F80070h (ntdll+10070h), symbol: "KiUserApcDispatcher" (+48h)
Address: 76FA2432h (ntdll+32432h), symbol: "RtlReleaseSRWLockShared" (+29h)
Address: 75601BAEh (USER32+21BAEh), symbol: "SetFocus" (+15h)
Address: 71992554h (foo_ui_std+A2554h)
Address: 71992C68h (foo_ui_std+A2C68h)
Address: 719923E9h (foo_ui_std+A23E9h)
Address: 71994BAAh (foo_ui_std+A4BAAh)
Address: 76FA243Dh (ntdll+3243Dh), symbol: "NtdllDefWindowProc_W" (+0h)
Address: 719ABD28h (foo_ui_std+BBD28h), symbol: "foobar2000_get_interface" (+12458h)
Address: 719DE6A0h (foo_ui_std+EE6A0h), symbol: "foobar2000_get_interface" (+44DD0h)
Address: 718FD980h (foo_ui_std+D980h)
Address: 755F7182h (USER32+17182h), symbol: "GetWindowLongW" (+195h)
Address: 76FA247Bh (ntdll+3247Bh), symbol: "RtlDllShutdownInProgress" (+11h)
Address: 75601E83h (USER32+21E83h), symbol: "DestroyWindow" (+15h)
Address: 72DDEEA6h (foo_uie_esplaylist+EEA6h)
Address: 72DDECDEh (foo_uie_esplaylist+ECDEh)
Address: 72E08040h (foo_uie_esplaylist+38040h), symbol: "foobar2000_get_interface" (+38F0h)
Address: 72E1791Bh (foo_uie_esplaylist+4791Bh), symbol: "foobar2000_get_interface" (+131CBh)
Address: 72DF91F3h (foo_uie_esplaylist+291F3h)
Address: 72DFBE11h (foo_uie_esplaylist+2BE11h)
Address: 72E17A2Dh (foo_uie_esplaylist+47A2Dh), symbol: "foobar2000_get_interface" (+132DDh)
Address: 72DE9809h (foo_uie_esplaylist+19809h)
Address: 72E1EB9Ch (foo_uie_esplaylist+4EB9Ch), symbol: "foobar2000_get_interface" (+1A44Ch)
Address: 72DE2BD3h (foo_uie_esplaylist+12BD3h)
Address: 72E1F2E4h (foo_uie_esplaylist+4F2E4h), symbol: "foobar2000_get_interface" (+1AB94h)
Address: 72E180B9h (foo_uie_esplaylist+480B9h), symbol: "foobar2000_get_interface" (+13969h)
Address: 72DE8F65h (foo_uie_esplaylist+18F65h)
Address: 72E2A704h (foo_uie_esplaylist+5A704h), symbol: "foobar2000_get_interface" (+25FB4h)
Address: 72DEB796h (foo_uie_esplaylist+1B796h)
Address: 72E1EBBCh (foo_uie_esplaylist+4EBBCh), symbol: "foobar2000_get_interface" (+1A46Ch)
Address: 72E1EE74h (foo_uie_esplaylist+4EE74h), symbol: "foobar2000_get_interface" (+1A724h)
Address: 72E1EBF4h (foo_uie_esplaylist+4EBF4h), symbol: "foobar2000_get_interface" (+1A4A4h)
Address: 72E1ECD4h (foo_uie_esplaylist+4ECD4h), symbol: "foobar2000_get_interface" (+1A584h)
Address: 72E1EE18h (foo_uie_esplaylist+4EE18h), symbol: "foobar2000_get_interface" (+1A6C8h)
Address: 72E1F430h (foo_uie_esplaylist+4F430h), symbol: "foobar2000_get_interface" (+1ACE0h)
Address: 72E1F458h (foo_uie_esplaylist+4F458h), symbol: "foobar2000_get_interface" (+1AD08h)
Address: 01535B40h (foobar2000+1A5B40h)
Address: 72E19A78h (foo_uie_esplaylist+49A78h), symbol: "foobar2000_get_interface" (+15328h)
Address: 72DEA9D2h (foo_uie_esplaylist+1A9D2h)
Address: 72E1EBACh (foo_uie_esplaylist+4EBACh), symbol: "foobar2000_get_interface" (+1A45Ch)
Address: 72E1EBD8h (foo_uie_esplaylist+4EBD8h), symbol: "foobar2000_get_interface" (+1A488h)
Address: 72E1EE64h (foo_uie_esplaylist+4EE64h), symbol: "foobar2000_get_interface" (+1A714h)
Address: 730682F2h (foo_uie_wsh_panel_mod+182F2h)
Address: 72DEA7E3h (foo_uie_esplaylist+1A7E3h)
Address: 72E19A9Ah (foo_uie_esplaylist+49A9Ah), symbol: "foobar2000_get_interface" (+1534Ah)
Address: 72DEFC3Ah (foo_uie_esplaylist+1FC3Ah)
Address: 72DEF876h (foo_uie_esplaylist+1F876h)
Address: 01435BE1h (foobar2000+A5BE1h)
Address: 01538352h (foobar2000+1A8352h)
Address: 72E1ED98h (foo_uie_esplaylist+4ED98h), symbol: "foobar2000_get_interface" (+1A648h)
Address: 01432E9Bh (foobar2000+A2E9Bh)
Address: 014DB5A2h (foobar2000+14B5A2h)
Address: 014416A7h (foobar2000+B16A7h)
Address: 01538353h (foobar2000+1A8353h)
Address: 014FEF18h (foobar2000+16EF18h)
Address: 014DCCD8h (foobar2000+14CCD8h)
Address: 013B796Ah (foobar2000+2796Ah)
Address: 014FEF20h (foobar2000+16EF20h)
Address: 01505EA4h (foobar2000+175EA4h)
Address: 013B9E50h (foobar2000+29E50h)
Address: 01500520h (foobar2000+170520h)
Address: 01502E00h (foobar2000+172E00h)
Address: 0150F38Ch (foobar2000+17F38Ch)
Address: 014E3028h (foobar2000+153028h)
Address: 013B7B1Fh (foobar2000+27B1Fh)
Address: 01401732h (foobar2000+71732h)
Address: 014DB0F1h (foobar2000+14B0F1h)
Address: 014018C1h (foobar2000+718C1h)
Address: 01401830h (foobar2000+71830h)
Address: 014D8EF8h (foobar2000+148EF8h)
Address: 01515058h (foobar2000+185058h)
Address: 755F7D31h (USER32+17D31h), symbol: "LoadStringW" (+11Fh)
Address: 755F7E92h (USER32+17E92h), symbol: "GetMessageW" (+0h)
Address: 756F1199h (kernel32+11199h), symbol: "SetLastError" (+0h)
Address: 013FDE99h (foobar2000+6DE99h)
Address: 755F7DFAh (USER32+17DFAh), symbol: "DispatchMessageW" (+Fh)
Address: 013FDFC1h (foobar2000+6DFC1h)
Address: 013FEE72h (foobar2000+6EE72h)
Address: 014FB7E8h (foobar2000+16B7E8h)
Address: 0150D968h (foobar2000+17D968h)
Address: 0150D94Ch (foobar2000+17D94Ch)
Address: 00383539h (foo_input_ofr+13539h), symbol: "foobar2000_get_interface" (+BD29h)
Environment:
App: foobar2000 v1.1.2
OS: Windows 6.1.7600 x64
CPU: Intel® Xeon® CPU E3110 @ 3.00GHz, features: MMX SSE SSE2 SSE3 SSE4.1
Audio: Speakers (USB Audio DAC )
UI: Default User Interface 0.9.5
Components:
Core (2011-01-22 00:03:02 UTC)
foobar2000 core 1.1.2
foo_albumlist.dll (2011-01-22 00:01:28 UTC)
Album List 4.5
foo_burninate.dll (2010-01-18 15:10:44 UTC)
Audio CD Writer 3.0.2
foo_cdda.dll (2011-01-22 00:01:02 UTC)
CD Audio Decoder 3.0
foo_chacon.dll (2010-08-16 08:30:12 UTC)
Chacon 3
foo_converter.dll (2011-01-22 00:00:36 UTC)
Converter 1.5
foo_fileops.dll (2011-01-21 23:59:40 UTC)
File Operations 2.1.3
foo_freedb2.dll (2011-01-21 23:59:42 UTC)
freedb Tagger 0.6.3
foo_input_alac.dll (2010-08-31 12:55:58 UTC)
ALAC Decoder 1.0.6
foo_input_monkey.dll (2010-08-16 08:30:22 UTC)
Monkey's Audio Decoder 2.1.4
foo_input_ofr.dll (2008-11-29 07:48:04 UTC)
OptimFROG Lossless/DualStream Decoder 1.21b
foo_input_std.dll (2011-01-22 00:00:58 UTC)
Standard Input Array 1.0
foo_input_tak.dll (2010-08-16 08:30:52 UTC)
TAK Decoder 0.4.4
foo_input_tta.dll (2010-11-02 03:45:18 UTC)
TTA Audio Decoder 3.2
foo_playcount.dll (2010-10-12 15:40:04 UTC)
Playback Statistics 3.0.1
foo_r128scan.dll (2011-01-31 01:40:03 UTC)
EBU R128 Gain scanner 1.20
foo_rgscan.dll (2011-01-22 00:00:36 UTC)
ReplayGain Scanner 2.0.9
foo_run.dll (2010-08-16 08:31:16 UTC)
Run services 0.3.7
foo_ui_std.dll (2011-01-22 00:00:58 UTC)
foo_uie_esplaylist.dll (2011-01-23 10:54:46 UTC)
EsPlaylist 0.1.3.6.2
foo_uie_wsh_panel_mod.dll (2011-01-13 18:22:54 UTC)
WSH Panel Mod 1.4.2
foo_vst.dll (2011-01-08 17:36:22 UTC)
VST 2.4 adapter 0.8.0.1
Recent events:
cddb request via http: http://tracktype.org/~cddb/cddb.cgi?cmd=cd...6.3&proto=6
cddb response: 200 classical 08123f14 Various / Best Violin 100
found match: classical 08123f14 Various / Best Violin 100
cddb response: 210 classical 08123f14
Saving foobar configuration... OK
Opening track for playback: "D:\Music\ByArtist\Nicola Benedetti\(2009) Fantasie\03. Introduction and Rondo Capriccioso in A Minor.m4a"
Last.fm submission: Scrobbled 1 track(s)... OK
Last.fm submission: Now playing... OK
Reply #433
@Ssenna: The crash report in zradu's post was actually posted by me with some more information in this thread. Please take a look.
Reply #434
I released the new version.
I'm not 100% sure whether the crash is fixed.
Reply #435
I tested it, seems like it's fixed. Thanks.
Reply #436
With 0.1.3.6.3, if I switch to a theme that uses ES Playlist from one that uses a regular playlist, it is blank. I have to choose the theme a second time for the tracks to appear. Same thing if I switch from a theme that uses a regular playlist to one that uses ES Playlist.
Switching between themes that all use ES Playlist works fine still. It did not happen with 0.1.3.6.2. Is it just my machine? Thanks.
Reply #437
Maybe it is not a bug of EsPlaylist.
(it seems to be a problem of "Playlist Tab".  related topic)
Reply #438
EsPlaylist v0.1.3.7(2011/02/19) released.
  • added edge style.(ContextMenu->Options->Configure->Edge style)
  • some minor changes.
[/li][/list]
Download EsPlaylist v0.1.3.7
Reply #439
ssenna thank you for replying. I think you are right, it is something else causing it. It is does not happen every time, and it has happened with 0.1.3.6.2 also. Just installed 0.1.3.7. The edge styles are very nice, and it is not happening right now. Must be something on my machine. Thank you for this great playlist.
Reply #440
I want to change the color of the ratings inside the column to yellow. Can someone please provide me the code?
Reply #441
You can't change text color without using Columns UI which is something you probably don't want to get into, as it would mean replacing your entire user interface. Learning to customize Columns UI is a pretty big project...
Reply #442
wrong. EsPlaylist has full $rgb support inside default UI.
however, this isn't even relevant to Bryter's question. this component has it's own special rating column which not only displays stars but allows you to set ratings by double clicking them. you can't change the colour of these stars.
Reply #443
That sounds cool  Maybe you could explain how to use it? A little while ago I spent a few hours plowing through all the info on $rgb() I could find, but to no avail. I even asked somewhere on this board but ended up with the conclusion above.
Reply #444
first of all i'm going to assume you know how to use RGB colour codes? $rgb(255,0,0) is red for example....
if you want to change everything in the column to one colour, you simply put the colour code at the start
$rgb(255,0,0)%artist%
or maybe you want to put 2 fields in one column with different colours.
$rgb(255,0,0)%artist%$rgb() %title%
notice the 2nd $rgb has no colour specified so all it's doing is resetting the colour back to default.
but if i wanted the title to be blue, i could do this...
$rgb(255,0,0)%artist%$rgb(0,0,255) %title%
Reply #445
It's working fine - I wonder how I could not have figured it out before
Reply #446
I am pretty sure that below is not possible, so it is a feature request rather I think...
OK, the problem is that in layered mode, for large groupings (like 1st letter of artist), everything that is displayed is large, empty tile with one letter inside. I could of course make tile smaller, but then on album level grouping, where I would like to see a cover, I would have to make tile bigger again (not to say that I would need to display headers before in my setup) :/
So, my suggestion is as follows:
Enable displaying groups in layered mode as group headers (that means group name with a line; the same way a group header is displayed now), one item per line.
That means, that display for grouping A-Z / Album Artist / Album would be as follows (layered view, display focused group only) :
>Top level
A-----------------
B-----------------
C-----------------
>Drill down A (fe. double click)
A-HA------------
ABBA------------
Atomic Kitten---
>Drill down ABBA (fe. double click)
Now you see the standard tiles
Reply #447
I like this extension a lot, but I have a few issues with it that. If they seem reasonable please consider rectifying these points in future releases.
Columns
  • Cannot associate a column with a particular playlist. Like grouping, please add "enable only on", "disable only on", or "enable on all playlists" for columns.
  • Cannot add (more than twelve) columns.
  • Cannot sort by clicking a column.
  • It might be more intuitive or user-friendly to put column preferences in the Preferences windows > EsPlaylist > Columns tab. Similar to the way Columns UI handles column preferences.
Inline editing
If inline editing is enabled, the ability to double click a track to play it is disabled. I don't understand why this has to be either-or. In my opinion it should parallel the inline editing behavior of the operating system. A slow double click executes inline editing, a fast double click executes (plays) the track.
Reply #448
@ssenna,
A few suggestions for your excellent component
- to be able, in the View menu, to select between Follow Active Playlist / Follow NowPlaying Playlist / Browse Library  (Then I could add a button in my layout with PSS to switch between them, or add keyboard shorcuts)
- Now we can use the search bar to create a playlist with the result of the query, maybe to add the possibility to "create an autoplaylist"
Thanks in advance,
Decalicatan Decalicatan
Reply #449
I definitely second that motion (which is to say yes, that would be great ). Now one has to use Library View or the regular search in order to create autoplaylists - I would like to be able to rely only on Facets and EsPlaylist.
