Topic: [Not My Release] EsPlaylist (Read 339759 times) previous topic - next topic
Reply #350
Can someone indicate me how can to edit  Side Info ?
Reply #351
file>preferences>EsPlaylist. on the "grouping" tab select which preset you want and then double click the entry under "preset setting".
Reply #352
@ssenna,
A suggestion, maybe it is already in your To-do list, to add bold, or italic command (as in your ElPlaylist function: $font(name,size,OPTIONS) ) for Side Info, or the Group info column...
Thanks in advance,
Decalicatan Decalicatan
Reply #353
Thanks for helping (2nd time), did not thought about double clic.
Reply #354
I can't see any tooltip when i hover things in EsPlaylist (both in Layered or Flat mode) though i enabled it in "Options -> Configure..." .
Can you post a screenshot :-?
Text  has to be clipped in order for you to see any tooltip.
Reply #355
i have a couple of problems configuring esplaylist
i tried and tried and i can't figure out certain things
maybe someone can help me
here is a visual help for me to express my problems
i'm using foobar 1.1 DUI and the latest esplaylist build
1. in playlistview when i add more columns a vertical scrollbar is automatically added when the columns don't fit the view (pls look at the picture, i dunno how to explain it better...)
that's not the case if i do the same with esplaylist
2. in esplaylist there is an empty column which i can't delete...what is it for and how do i get rid of it?
the only way so far i found was to simply drag another column over it which doesn't seem to be very elegant...
3. rating: i dunno how to add a column from scratch to esplaylist...so i chose the ratings column and configured it the same way i did with playlist view (something similar to $ifequal($meta(rating),1,$repeat(o,1),$ifequal($meta(rating),2,$repeat(●,1),)) ) but in esplaylist no rating is shown except for empty stars...so i chose another premade column (lenght i guess), did the same and the rating is shown...but in intergers and not in ●
i left the "Linked Meta-Field" blank...
4. the gap between artists is annoyingly big in esplaylist...anyway to make that gap smaller?
the same is true for tracks, which i could alter by right click > Options > Configure... > Row height
does this change the font size? i mean apparently if i change it from 22 (default) to 10 it does...but does it also change the font size if i set it to 18 (my font size for foobar) or something like 15?
5. whats the difference between right click > Options > View Style > Layered View and ... > Flat View (fixed) ?
6. is there any way to sort a playlist besides Preferences > esplaylist > Grouping > Sort-Format > Force-Sorted?
any help on any of this problems is highly appreciated!
Reply #356
EsPlaylist v0.1.3.0 (2010/10/09) released.
Changelog:
  • changed some behaviours of Searchbar.
  • added contextmenu "Search for same by".(requires setting of "Script for Contextmenu" of each searchbar mode)
  • improved drag & drop behaviour.
Download EsPlaylist v0.1.3.0
Reply #357
That's for album art, which I would have thought was the main reason people use EsPlaylist. I personally hide the column header since the fields are self explanitory.
In Layered View you can double click the heading and go up a level (e.g. for the "Album Artist / Album" preset, double clicking an album would show only the albums, then double clicking an artist would show only the artists)
Flat view shows everything at one, similar to the album list with everything expanded.
Edit > Sort
I'm not sure about the others. You might be better using Playlist View if it does everything you need.
Reply #358
i thought so...it's weird though that you can't remove that column...
removing the header unfortunately isn't an option for my...i change the sorting quite often...
the main reason for me to (ab)use esplaylist is because of the browse-mode feature...right now i have one panel locked to a sort of "now playing"-playlist which works fine
i wanted to lock another esplaylist panel to library view which doesn't quite work the way i want it to...
thx for explaining!
Edit > Sort
when the esplaylist-panel is focused all options in the edit-thingy are greyed out...
unfortunately not...i like the search (which i could kind of substitue with foo_quicksearch, but i like the esplaylist built-in better
and, as i said, the main reason for using esplaylist is the possibility to lock it to a particulary playlist wich is sadly not possible with playlist view...
anyway, thank you very much for your input
Reply #359
3. rating: i dunno how to add a column from scratch to esplaylist...so i chose the ratings column and configured it the same way i did with playlist view (something similar to $ifequal($meta(rating),1,$repeat(o,1),$ifequal($meta(rating),2,$repeat(?,1),)) ) but in esplaylist no rating is shown except for empty stars...so i chose another premade column (lenght i guess), did the same and the rating is shown...but in intergers and not in ?
3. rating: There's no need to do that!
Only use the predefined column "Rating" - here are the stars!
Do you have no TAG-field with name "Rating"? (%rating% - values 1 to 5)?
Reply #360
no, i do not use the %rating%-tag field
on the one hand because i use a (kind of) two dimensional rating system: (i like, my girlfriend likes) aka (%myrating%, %herrating%)
on the other hand because every program uses the %rating% tag in an other way...some show it, some don't, some show integers from 1 to 100, some show integers +1/2 from 0 to 5, some show symbols, some ...
there is absolutely no consistency, not even within single programs...so i made up my own tag(s) with my own range (1 and 2, respectively only 1)
in playlist view this is absolutely no problem...in esplaylist it won't work...
Reply #361
name='ruebe' date='Oct 22 2010, 16:35' post= two dimensional rating system: (i like, my girlfriend likes) aka (%myrating%, %herrating%)
Try the predefined Rating-Field, "Edit Column", Format: try %myrating% instead of %rating".
Maybe that works, maybe not...
Reply #362
that's what i did...two days ago i wouldn't work, today it does...whatever *shrug*
anyway, one problem less...
Reply #364
Request: Adding context menu commands for going up or down in groups
ex: One command goes up from an album level to artist view, and one goes back down into album, and then perhaps to view tracks.
(would be nice for making keyboard shortcuts)
Reply #365
A big thanks for this great addition.
Is it possible to have in layered view only the artwork, no text no title no anything, and in flat view the standart info (artist, album...) ?
E.
Reply #366
Can anyone tell me if it's possible to have the currently playing track highlighted in esplaylist when I double click the status bar? Currently if I double click the status bar the track will be highlighted in playlist view(which is in another tab)
Reply #367
Hi. Would it be possible to have option for refreshing the playlist after every song? I use dynamic album ratings in grouping title and it would be nice if it changed automatically when playing songs.
EDIT: Or if this is too much work, what about menu item for refreshing? I know there is one in context menu but it seems I can't assign keyboard shortcut for that :/
Reply #368
I know there is one in context menu but ... I can't assign keyboard shortcut for that
Keyboard shortcut for refreshing would be very nice.
Keyboard shortcut for changing Flat to Layered View too.
Reply #369
Glossy effect like in column ui would be very nice.
Reply #370
EsPlaylist v0.1.3.2 (2010/11/13) released.
Changelog:
  • added support for displaying tooltip in Layered view.
  • added some mainmenu commands.(View->EsPlaylist)
Download EsPlaylist v0.1.3.2
Reply #372
Hi all, my first post. 8)
I wanted to share a little script for Columns Playlist and for EsPlaylist. I made it to show in the #album column the name of the online radio or the stream, if the file relates to an folder on 'http://'. It does not work, if you are trying to access real files online and not a stream.
It will show something like this in the album column if the file relates to http: "Stream: TechnoBase.fm"
Put the code, if you use EsPlaylist, through the option 'edit this column' via right clicking the #album column. For the normal ui_columns playlist, put it where ever it belongs.  There will be NO Change if the file does not access 'http://' folders.
$if($strcmp($left(%_path_raw%,7),'http://'), 'Stream: '$if(%url%,$replace(%url%,'http://www.',' '),$puts(numbersinurl,$substr(%_path_raw%,8,$add(7,$strchr($substr(%_path_raw%,12,99),'.'))))$ifequal($get(numbersinurl),0,$replace($directory(%path%),'www.',' '),' '%filename%)),%album%)
Reply #373
EsPlaylist v0.1.3.3 (2010/11/20) released.
Changelog:
  • fixed a bug about "Go to up/down layer" commands in Flat view (fixed).
Download EsPlaylist v0.1.3.3
Reply #374
Thanks for the refresh option, works nicely! And to my next concern...
When using keyboard typing to scroll to artist scandinavian keys (åäö) don't work (nothing happens when pressed). Since I have a lot of finnish bands where these are common it's a bit annoying. Is there anything that can be done to this?
