Topic: foo_autoupdate (Read 45154 times) previous topic - next topic
foo_autoupdate
Yeah, I've added yet another proper version detector.
foo_autoupdate
@OP: Does your component support proxy server? I'm behind a proxy and I get
[Autoupdate] I/O error: Could not connect to host
when I try to use this component.
foo_autoupdate
Uses foobar2000 settings from Preferences > Networking.
foo_autoupdate
Thanks, never used stuffs on the page you mentioned.
foo_autoupdate
Nice component.
Little bug: Component: Last.fm Radio, Installed: 0.5.7e, Latest: 0.5.7d.
foo_autoupdate
Reply #30
I see, added comparator for another version format.
foo_autoupdate
feature request: it would be nice if the update window didn't kick me out of a full screen game while playing.
foo_autoupdate
Small bug : version detection with EsPlaylist.
Screenshot from the problem :
Also it would be great to have an option to ignore beta or alpha versions.
Opus 96 kb/s (Android) / Vorbis -q5 (PC) / WavPack -hhx6m (Archive)
foo_autoupdate
Reply #33
Thank you Yirkha, the EsPlaylist bug is fixed now.
foo_autoupdate
Reply #34
I have the same error
Ok, but here, i have just the buffer or proxy. And if i change, same error.
I allow all rights to foobar with the firewall.
foo_autoupdate
Reply #35
Hmm yes, that sucks.
Mostly caused only by the shaddy "community" data source...
Is it really "Could not connect to host"? At least I see multiple successful requests from your IP address on the server, even today at 20:23 CET etc., so I don't know, maybe something else is interfering on the way.
foo_autoupdate
Reply #36
new versioning scheme: Custom Database 0.1.0
- installed: 0.1.0_beta1
- latest: beta1
of course, it's the same vesion
foo_autoupdate
Reply #37
OK, I've amended the parsers.
foo_autoupdate
Reply #38
Got this
[Autoupdate] I/O error: Bad Request (400)
today, but it went fine afterward. Server was being maintained I guess.
foo_autoupdate
Reply #39
There is an error logged from your IP address, the request got mangled somewhere on the way or whatever. There are a few such cases each day...
foo_autoupdate
Reply #40
EsPlaylist version checking is still problematic:
foo_autoupdate
Reply #41
[Autoupdate] I/O error: Invalid content signature.
any idea what this means? Yirka will you take over the other updater or implement it into yours or further your plugin in light of the recent development?
foo_autoupdate
Reply #42
and Seekbox and Podcatcher, and many components ignored or unknown
The following components are ignored or unknown:
Album List (4.4, bundled)
CD Audio Decoder (3.0, bundled)
Channel Mixer (0.9.6.5, unknown)
Chronial's Coverflow (0.3.0, unknown)
Remote Control (1.1.1, unknown)
Converter (1.4, bundled)
Locate Covers (0.06, unknown)
CUE Playlist Filter (0.1.7.0, unknown)
Database Search (1.4, unknown)
Discogs Tagger (1.23, newer)
bs2b (3.1.0, unknown)
Crossfeed (1.1.1, unknown)
Noise Sharpening DSP (1.0.0, unknown)
Loudspeaker Equalizer (1.0.1, unknown)
Add Noise DSP (0.0.4, unknown)
SoX Resampler modified (0.5.4.1 mod, unknown)
Surround Pan (1.3, unknown)
Standard DSP Array (1.0, bundled)
2ch to 6ch (1.1, unknown)
Crossover (0.38a, unknown)
Extended Variables (0.3.1, unknown)
File Operations (2.1.2, bundled)
freedb Tagger (0.6.2, bundled)
Standard Input Array (1.0, bundled)
TTA Audio Decoder (2.4.4, unknown)
MusicBrainz Tagger (0.2, unknown)
Navigator (0.64, unknown)
Normal Previous (0.1, unknown)
Playlist Attributes (0.2.2 [Nov 16 2009 - 20:33:31], unknown)
Playlist Revive (0.2, unknown)
Playlist Sorter (0.1.9, unknown)
Preview Custom (1.0.1, unknown)
Enqueue Random (0.4, unknown)
Randomized Playlist Entry (1.3.0, unknown)
ReplayGain Scanner (2.0.9, bundled)
Stop After Queue (0.1, unknown)
Stop on Current (0.4, unknown)
foo_stopaftercuralbum (0.2, unknown)
Default User Interface (0.9.5, bundled)
Bookmarks (0.3.0, unknown)
ELPlaylist (0.6.7.0(beta), unknown)
Graphical Browser (rev015, unknown)
Lyric Show Panel (0.3.3.9 [Dec 12 2008 - 17:39:01], unknown)
Panel Stack Splitter (0.3.8.3(alpha), unknown)
Quick Search Toolbar (2.8l, unknown)
Tabbed Panel Modified (0.2.8, unknown)
Track info panel mod (0.8.0 beta [Jan 5 2007 - 13:36:12], unknown)
Channel Spectrum panel (0.17.2, unknown)
Peakmeter Spectrum Visualisation (0.2.0.0 beta, unknown)
WSH Panel Mod (1.3.2, newer)
Archive Reader (1.3, bundled)
Playlist Tools (0.6.2 beta 6, unknown)
Components versions viewer (0.4, unknown)
foo_autoupdate
Reply #43
Maybe the EsPlaylist author should consider putting the version number into the component version field instead of adding it to the component name field. That would make it easier for foo_autoupdate - or even *gasp* users.
foo_autoupdate
Reply #44
I can see the proper component version in Peferences->Components page.
so, I'm not sure but version info at DECARE_COMPONENT_VERSION macro seems to be correct.
foo_autoupdate
Reply #45
Sorry then, I forgot I was looking at a screenshot of foo_autoupdate, not of the standard components page.
foo_autoupdate
Reply #46
I  have same error Yirka as Ravensoft , [Autoupdate] I/O error: Invalid content signature.
foo_autoupdate
Reply #47
Sorry about the occasional nonsensical versions and similar problems - again, it's caused by the fact that the data are collected from a human-generated textual log at the xrea.jp site and deducing component name and version from that with all the variance is not quite easy. The relevant regex is already ugly enough... /^(.*?) v?((?:[0-9]+\.)*[0-9a-z]+(?: beta ?\d+| dbg| alpha| beta| prebeta|\(prebeta\))?|\d+-\d+-\d+|\d+/\d+/\d+)$/i
Information about components which are in the official component repository are fine 100% (AFAIK), contain more information etc.
Also as you might have been noticed (I hope you were! ), I released version 1 of the component today, featuring mostly fixes for the most annoying problems people have encountered - see the website for details.
Regarding further development, there are no big plans for the same reason as stated in the foo_component_manager thread. But as I already said, I'm not going to pull it any time soon either. The whole system has the advantage that it works even without me caring - for the last month or so, I didn't really have much time to do anything with it, yet it happily reported updates for me. And I guess it did for you too.
foo_autoupdate
Reply #49
updated to the new version and...
so not working for me still...
