Topic: Database Search (Read 225052 times) previous topic - next topic
Database Search
Reply #75
I am not interested in case sensitive search because I search a number. Your 'trick' works perfectly for me, thanks a lot!
Database Search
Reply #76
Does anyone know if there is any way to search a specific field using this plug-in -- other than changing the search string?
If it's not possible to do this currently, could foosion please implement something to that end -- it may be easiest to just add another pulldown list to the database search window (not the configuration window) that would store different search strings.
Database Search
Reply #77
If you're using 0.7x: use the quicklist (described in one of my previous posts).
if you're using 0.6x: use 0.7x.
Database Search
Reply #78
thanks, foosion!
Database Search
Reply #80
Just had to say thanks for this really useful plugin.
Database Search
Reply #81
hello..!
i got a problem. when i'm changing the default "search in" from database to playlist, and restart fb2k, the "search in" is set to database :/ it isnt saved?
and.. is it possible to add as the default action "play now" ?
thx for reply's
and sorry for the bad english *g, bye..
Database Search
Reply #82
hello..!
thx for reply's
What's wrong about the "Play" command? This is present in 0.11.1, it was possibly already introduced in 0.11.0 - I can't remember that.
Database Search
Reply #83
hello..!
thx for reply's
Play isn't on the default action list.
Database Search
Reply #84
Oops, my fault. I apparently added this in an internal build, that I did not upload. It is now on the server as version 0.11.2.
download
Database Search
Reply #85
The new play function is great, I directly replaced my hotkey for search to point to database search
One thing though, the "search in" setting isn't saved after restart of foobar.
Database Search
Reply #86
download
Database Search
Reply #87
Great! I had tested the database searches but didn't find them too useful without the "play" action. With large playlist and complex formatting string the default search really was not usable.. Thanks again, this is going to be used a lot.
Database Search
Reply #88
foo_dbsearch 0.11.3
- removed "Remove from database" from context menu
- selected search domain is now remembered
- fixed small multithreading bug that could crash the program
- added search domain "All playlists"
I'm currently doing some internal rearrangements in this plugin, some of which of have made it into this release, like new interfaces for the search domains. Because of this, you'll have to redownload foo_copynpaste, if you want to search in the clipboard. I've had some problems recompiling foo_history, so you can't search the history for now.
<edit>
I almost forgot this: you can use %_playlist_name% to get - tada! - the name of the playlist an item is from. This works when searching in "Playlist" and "All playlists".
</edit>
Database Search
Reply #89
is there a highlight function so that whatever I select on the searchbox is selected on the playlist?
Database Search
Reply #90
oh yeah that would be nice for "follow cursor".. :>
Database Search
Reply #91
No, currently not. I'll consider this for the next release.
Database Search
Reply #92
I too would love to have it save the search in field.
Database Search
Reply #93
hi,
i really like your plugin  just one thing, that is bugging me (i browsed the topic roughly, don't know if something like that has been asked before)
right now i do this: search for e.g. the name of an artist, hit tab, hit ctrl + a, hit enter. could you make a hotkey available, that sends the results of the current search to the playlist, even if i didn't select the results?
regards; ilikedirt
Database Search
Reply #94
hi,
Yes, It has been asked for.
regards; ilikedirt
OK, I give in.  But the hotkey won't be configurable, so I'm asking you (and the others), if the following would do:
1) Shift-Enter for "Add to playlist"
2) Control-Enter for "Send to playlist..."
Database Search
Reply #95
foosion,
Those hotkeys sound cool to me...
How do you feel about saving the "search in" field?
Database Search
Reply #96
If you're talking about the "Search in" submenu in the contextmenu, that should already work (it does for me). On the other hand, if you're refering to the dropdown list with formatting strings, this setting will also be saved in the new version. (This was rather a bug, as the setting is already saved, but it is reset everytime the plugin starts  ).
Database Search
Reply #97
Yea, I was referring to the dropdown list with formatting strings.  Can't wait for the new version.
Thanks for the very cool plugin by the way.
Database Search
Reply #98
yes, sounds fine to me
Database Search
Reply #99
foo_dbsearch 0.11.4
- added hotkeys Shift-Enter (adds all items to the playlist) and Control-Enter (executes "Send to playlist..." with all items). use them in the input box.
- some general commands where moved to foo_utils:
  "Add to playlist", "Insert into playlist", "Send to playlist", "Play"
see this site for download links: http://www.stud.uni-karlsruhe.de/~uzbs/fb2k/html/
