Topic: Database Search (Read 197296 times) previous topic - next topic
Database Search
Thanks for the quick fix.  =]
Database Search
sorting string not work fine:
copy "display sting" in "sorting string" , "use diplay string for sorting" is not used.
enter query
logically we must obtain the same diplay result, but in reality it is not sorted alphabetical
however the result is correct
sorry for my poor english
win98 se
foobar 0.6 b7
DB Search plugin 0.6 ansi
Music is my first love.
Database Search
enter query
Damn typo caused results not to sorted at all, when "Use display string for sorting" was disabled.  While greatly improving the speed, this was not the intended behaviour. foo_dbsearch 0.6 update2 does not have this problem, and is now available for download.
Database Search
now your component work fine.
you have only to work at increase speed, correct with my duron 1.1 and my 1000 mpc files, but surement slow with 10000 files and 500 mhz processor...
thank you for your database search
Database Search
foo_dbsearch is very flexible - just think of all the things you can do with separate search/display/sorting strings and the new special fields (show entries that matched all/any words, sort by number of hits, ...). the searching code is also quite simple, which is good for maintenance.
this comes at a price though, and this price is speed...
EDIT: use a separate, but empty sorting string. when you have many entries in the result list, this greatly increases speed
ok, a more practical approach would be to make your formatting strings as simple and short as possible.
Database Search
i love your component!
Database Search
me too! if you want anything...my house...my car...my sister...just ask!
Seriously, many thanks, you and Curious George keep up the good work.
Database Search
Reply #32
foobat 0.6 b11:
ERROR (CORE) : Failed to load DLL: foo_dbsearch.dll, reason: Wrong version number; this component appears to have been built with outdated version of foobar2000 SDK and needs to be recompiled with newer version in order to load; please contact author of this component to obtain an updated version of this component.
Database Search
Peter broke the component compatability apparently, so the version number got bumped up.  All the third-party plugins will need to be recompiled against the newest SDK.
edit:
Both Meta Search and (I think) Database Search will need to be re-worked a bit.  Some functions were dropped from the new SDK.
Database Search
Reply #34
idea:  add delay before performing a search
with 200gigs of mp3s search on my slowl 1ghz machine it
takes approximatelly 1minute per character, usually I dont
search just for mp3s that have one specific letter/character
so maybe delay the search by a fraction of a second to let
me type rest of the search?
If not that, change so that it starts a search once character
limit is met (ie: 3 chars entered required for minimum
search)
/apz,  Life is like an analogy.
Database Search
Reply #35
Uncheck 'Update search results when query changes' and press enter after you've written the whole thing you're going to search.
Database Search
Reply #36
That's exactly the right thing to do in this situation. An option to delay the start of the search will not be added.
Database Search
Reply #37
feature request :
use playlist font for database search, or choose font.
it is hard to make ?
Database Search
Reply #38
I don't think there's any way to use the playlist font (or I would have made foo_shizzle do just that), but it's not a big deal to add a selectable font.  foosion probably just hasn't gotten around to that yet.
Database Search
Reply #39
if it's not a big deal to add a selectable font...
foosion ?
Database Search
Reply #40
Actually, I just remembered something.  He's using an owner-drawn list-box, so it might be more trouble.  I'm not sure.
Database Search
Reply #41
Well, I'm not using an ownerdrawn list box anymore. In fact, official versions of the plugin never had it. It didn't work on XP, do you remember?  I guess it's not that hard to make the font configurable (there is some helper in the SDK, IIRC). I just don't know when I'll get around to do it, so please be patient.
Database Search
Reply #42
Well, just check out the albumlist for a quick, extremely simple example.
I guess I misunderstood about the owner-draw listbox.  I thought a fixed version of it had made its way into the latest releases.
Database Search
Reply #43
I already knew about this, but thanks for the hint anyway. I will be at my parents' house until Easter Monday, so I won't be working on any fb2k plugin.
Unfortunately not, but if it had worked, there would probably exist a special version with color codes as an easter egg by now.
Database Search
Reply #44
foo_dbsearch 0.9 public test
Important things first: This version is still for Foobar2000 0.6x. There is no updated documentation, however most of the documentation for foo_dbsearch 0.8 still applies (query syntax, options, ...). The changes are mainly centered around the GUI. So toy with it, and try to break it
If anything is unclear, do not hesitate to ask.
download link: foo_dbsearch-0.9.zip
from the change log:
[0.9]
2003-06-26
- upgraded to 0.667 sdk
- added custom list control
- made color codes work in display string
- experimental: enhanced color codes for background color:
  "<text>@<bg>|<sel_text>@<sel_bg>}"
- multiple search domains: integrated are the database and the playlist,
  more possible via plugins
- separated user-defined filter from display string
- removed context menu hack
- renamed %_total_tokens% and %_matched_tokens% special fields to
  %_total_keywords% and %_matched_keywords%
- added configuration for (default) colors
- basic help in configuration (to be enhanced)
@mods: Please move this thread to the 3rd party forum. Thanks.
Database Search
Reply #45
Not a big issue, but the colors won't change before a restart of foobar. Could this be fixed?  Otherwise this looks really good, keep up the good work!
Database Search
Reply #46
Can't reproduce, colour changes in the config are applied to the search result window immediately here (fb 0.667, winxp)
Can you please try to describe the problem and what you're doing more accurately?
Database Search
Reply #47
That's weird, I tried it again and now it works fine
Database Search
Reply #48
Changing the font while the search window was open, did neither redraw the result list nor was the line height updated. Fixed.
Database Search
Reply #49
without contest menu hack , "open directory"  isn't  useful: can you remove from context menu?
