Topic: %autonumber% command wont work (Read 2526 times) previous topic - next topic
Hello,
Im trying to convert some NSF files to mp3, everythings going fine until I want to convert them, although every file is a different song, they all have the exact same name. I've tried highlighting all of them, right clicking, going to properties, then using the masstagger? to autonumber all the tracks but when I high apply or ok, foobar gives me errors for every file saying that the file isnt supported, and when I try to use %autonumber% %totaltracks% it wont autonumber the tracks and all i get is a blank.mp3 name. I've also tried %tracknumber% %totaltracks% and get the same problem. Any help would be appreciated, thanks.
in the converter dialog, you can use
%list_index% - %filename%
in the "Name format" input.
Thank you so much!  It worked like a charm C:
i forgot to mention, you could use
$num(%list_index%,2)
to add leading zeros
01
02 etc
Where did you get the idea of an %autonumber% field?
Is this (wrongly) documented somewhere?
I found that suggestion when i was roaming google...I believe it was on wiki somewhere =/
and thanks marc ^^ I am now enjoying nes music woo
hmm o.o while I have you guys, anyone know if foobar can convert miniusf/USF and miniGSF/GSF files to mp3? I tried, but its not even reading them =/
