Topic: Newbie question: is my set up runing bit perfect (Read 1152 times) previous topic - next topic
I am new to this forum, so if there is any violation to the rules please let me know...
My setup
asus mainboard with on board spdif output ( onboard sound is via Vt1798B chip)
Musiland MD-10 dac
Audioengine a2 speaker
Win7
Foobar (running wasapi, 16bit)
Now i use the spdif output to feed my dac.
I have set it as my default device in win 7, and choosen 24 bit and 96Khz sample rate for my onboard sound card.
I set it up like this because i want my pc to give bitperfect sound when i listen to music with foobar, but any thing else resampled to the highest sample rate possible.
Now, when foobar is playing music, my dac shows it receive signal of 44.1Khz, any thing else from the window, like pure codec, youtune, window sound alarm cannot play when foobar is running.
when i do not use foobar, any application that make a sound make my dac shows a 96khz signal.
Now my question: is my set up bitperfect when running foobar ? it is my main concern
as Md-10 allow me to choose between 16bit mode and 24 bit mode, which should i choose?
Thanks a lot for any input
