Topic: %playback_time% doesn't work with the "Copy" command (Read 1337 times) previous topic - next topic
Hello.
%playback_time% doesn't work with the "Copy" command's textual output. It only works with "Copy names". Is it intended?
Edit: I just realized I've posted this in the wrong category. Would a moderator mind moving this to the Support section please?
I don't know if it's intended, but you are copying a track, not a track with current playback position, right? (Yes, I know you can say the same for the "Copy name(s)" command, just saying that it doesn't make much sense from this standpoint.)
On another note, what's %playback_time% good for there? A "now playing" text to paste to IRC or whatever IM? I find it hard to imagine somebody cares about the detail that you've already played 37 seconds from the song.
I don't know; there's probably a reason it works with "Copy names".
