Topic: Flac and Masstager (Read 3211 times) previous topic - next topic
Flac and Masstager
No, it's not a padding issue because I add 32KB (overkill) of padding and the tags are changed instantaneously with Tag.
However with foobar it takes ages and there's lot of HD activity, so it seeems it rewrites the entire file.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
Flac and Masstager
You wouldn't have the id3v2 plug loaded would you...seems that an earlier version may make excess temp files.
Flac and Masstager
yes, I had the Id3v2, unloading it solved the problem, weird.
Flac and Masstager
If you get the newest version (still .666) ...the problem is gone btw
