Topic: WSH Panel Mod script discussion/help (Read 1415276 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #550
Here is default UI theme
@Falstaff: Also some lyrics aren't shown. I can't find reason why - same release, same tag scheme etc., but for some tracks lyrics are shown while for others not
Reply #551
gimme the lyrics file (if embedded lyrics, paste them in a .txt) that doesn't work, to check what's wrong with it.
*waits*
PS: maybe (if embedded lyrics) it's due to the TAG name used for the lyrics, not handled by my script ? I only check for %LYRICS%, %LYRIC%, %UNSYNCED LYRICS% and %UNSYNCED LYRIC% ...
Reply #552
Falstaff, those lyrics doesn't have CRLF separator, so line was too long perhaps?
For timestamped lyrics there are some issues. Valid format by your script is [mm:ss.cc]
- it will fail, if lyrics have millisecond [mm:ss.uuu]
- or if minute digit isn't padded with zero [m:ss.cc]
- or if any kind of lyrics have square brackets in it "["
So maybe you should check if string inside square brackets has ":" separators and separated parts are numbers. Maybe just translate any possible time stamp to 00:00.000 and then process it. Like if time stamp is m:ss then you quickly process it to mm:ss.000 and go
edit: perhaps even ":" as centisecond separator instead ".", can be found in some online services providing LRC. It shouldn't be too hard to consider all this different scenarios
Reply #553
hmm, weird LRC timestamp format btw ... but the script have to handle them, so ok, i'll try to include this schemes in bext version
Reply #554
your work is the best!!  But it doesn't read (or load) the lrc file in the file's folder.  for exam:" leka - trable is a friend.lrc"in the leka folder.
can you make it happen. because my lrc almost all exist with "lrc file" style
http://cid-7c6fa1eb8fb8f2b7.photos.live.co...%E5%9B%BE00.png
Reply #555
as said in the comments of the script, "- This WSH script get lyrics from TAG first then from local file in foobar2000\lyrics\ "
be sure that your lrc files are stored in ...\foobar2000\lyrics\ or just change this path by yours in the script ... AND the filename must be <artist> -<Track_title>.lrc (it's the syntax to respect for .lrc read from disk (generated by Lyrics Show panel 2, i used the same), but you can change the syntax from the script too if your is slightly different ==> in your screenshot, there is a blank char just after the "-", not in my syntax, so add a blank char in the script line 649
or wait for my fix, i will handle more filenames syntax to fit with more schemes
Reply #556
you didn't understand me
my music is under
"H:\music\Sarah\"
"H:\music\Michael Jackson\"
"H:\music\Westlife\"
"H:\music\Simon & Garfunkel\"
"H:\music\Carpenters\"
one artist's musics and lyrics are in one folder.
so how i write the code?
i try to write a code
var lyrics_dir =fb.Titleformat("$replace($replace(%path%,%filename_ext%,),\,\\)");
but it doesn't work,please help me
ps:the road in wsh is "\\"or "\“?
Reply #557
sorry, my bad.
let me check this and include that path as default too...
Reply #558
The samples that come with WSH Panel contain a script sample which lets you blur a text object and use that as a glow effect. Could someone with more experience in graphics programming explain to me how exactly this script works ?
Can this be applied to an image like a bitmap or png ?
- Simply defining an image as "img_to_blur" does not seem to have an effect.
Could this if the above works also be animated with a timerinterval object ?
Thanks for help.
Reply #560
Vertical scrollbar
After some (laborious) studies, I have finally written a script that you may find useful.  It's a file to import in your script to easily define a viewport in the WSH window, with a vertical scrollbar that the user can use to scroll the content of a bitmap vertically.  Keyboard and mouse scrolling are also supported (but are optional).
r0lZ
I am trying to use our scrollbar script with buttons in it.
I'm succeeding in defining the buttons (i'm using tooltip_buttons.js) I can use them,
but i can't see the buttons that are outside the view you start with, before you scroll.
I'm guessing the y-coordinate of the buttons should move also when you scroll,
but i can't seem to find where you defined it.
<3 f00
Reply #561
sorry, my bad.
when your modified work shows?
i really like this "lyriks" wsh code.
I will go to home , soon. Please hurry , thank you very very very very much
Reply #562
sorry, my bad.
// Paths
var metadb = fb.IsPlaying ? fb.GetNowPlaying() : false;
var lyrics_dir = fb.Titleformat("$replace($replace(%path%,%filename_ext%,),\,\\)").EvalWithMetadb(metadb);
g_lyrics_filename = artist.Eval() + " -" + title.Eval();
g_lyrics_filename = artist.Eval() + " - " + title.Eval();
Reply #563
// Paths
[s]var metadb = fb.IsPlaying ? fb.GetNowPlaying() : false;[/s]
var metadb = fb.IsPlaying ? fb.GetNowPlaying() : fb.GetFocusItem();
function on_playback_new_track(info) {
    g_playtimer && window.KillTimer(g_playtimer);
    pos = 0;
    g_scroll = 0;
    g_is_scrolling = false;
    get_lyrics();
    change_focus();
    if (g_lyrics_status > 0) {
        g_playtimer = window.CreateTimerInterval(PLAYTIMER_VALUE);
Reply #564
To hejiame
Lyriks 1.0 (build 20101012.0815) - a WSH lyrics module by Br3tt
then it displays them (scrolling)
- It handles TXT and LRC format (sync handled), but not the LRC Enhanced format
(it translates eLRC to a normal LRC text)
- Comments, Blank lines, Info lines are ignored.
- Manual Scrolling possible with the mousewheel (double click on the panel to re-center on the active line)
- Requirements :
  1) foobar2000
  2) WSH Panel Mod component
  3) this script in a WSH panel
  4) Optional: a lyrics grabber (i.e: Lyric Show Panel by hidding the panel, foo_lyricsDB, ...)
- Some settings are available by using the panel Properties (right click on WSH panel -> Properties)
- This script don't make any changes to your files and write nothing on your system.
It's just a read&display data script.
// Text formatting function
function StringFormat() {
    var h_align = 0,
        v_align = 0,
        trimming = 0,
        flags = 0;
    switch (arguments.length) {
        // fall-thru
    case 4:
        flags = arguments[3];
    case 3:
        trimming = arguments[2];
    case 2:
        v_align = arguments[1];
    case 1:
        h_align = arguments[0];
        break;
    default:
        return 0;
    return ((h_align << 28) | (v_align << 24) | (trimming << 20) | flags);
StringAlignment = {
    Near: 0,
    Centre: 1,
    Far: 2
var lc_stringformat = StringFormat(StringAlignment.Near, StringAlignment.Centre);
var cc_stringformat = StringFormat(StringAlignment.Centre, StringAlignment.Centre);
var rc_stringformat = StringFormat(StringAlignment.Far, StringAlignment.Centre);
// IO Mode
var ForReading = 1;
var ForWriting = 2;
var ForAppending = 8;
// Paths
if (metadb){
else{
var lyrics_dir = "C:\\"
//fb.trace(lyrics_dir);
lyrics_folder_exists();
// new object
sentence = function () {
    this.type = null;
    this.timer = 0;
    this.text = "";
    this.total_lines = 0;
    this.ante_lines = 0;
function RGBA(r, g, b, a) {
    return ((a << 24) | (r << 16) | (g << 8) | (b));
// ================================================/ TF
var len_seconds = fb.Titleformat("%length_seconds%");
var elap_seconds = fb.TitleFormat("%playback_time_seconds%");
var artist = fb.Titleformat("$replace(%artist%,'/','_')");
var title = fb.Titleformat("%title%");
var lyrics = fb.TitleFormat("[$if2(%LYRICS%,$if2(%LYRIC%,$if2(%UNSYNCED LYRICS%,%UNSYNCED LYRIC%)))]");
// ================================================/ Declarations
var g_font = gdi.Font("segoe ui", 12, 0);
var g_playtimer;
var ww = 0,
    wh = 0;
var g_fso = new ActiveXObject("Scripting.FileSystemObject");
var g_file = null;
var g_tab = Array();
var g_scroll = 0;
var g_lyrics_filename;
var g_lyrics_status;
var focus = 0;
var focus_next = 0;
var g_plainbg_colour;
var g_ovbg_normalcolour;
var g_ovbg_highlightcolour;
var g_txt_normalcolour;
var g_txt_highlightcolour;
var g_txt_shadowcolour;
var centiemes = 0;
var g_is_scrolling = false;
var g_multi_balise = false;
var g_balise_total;
var g_balise_char_offset;
var g_tab_length;
var midpoint;
var pos;
// ================================================/ Settings
var PLAYTIMER_VALUE = window.GetProperty("Timer value in ms [10;100]", 10);
var LINE_HEIGHT = window.GetProperty("Line height [20;30]", 24);
var TEXT_SHADOW = window.GetProperty("Text shadow (true/false)", true);
var PLAIN_COLOR_BG = window.GetProperty("Plain colour background (true/false)", false);
var DITHER = window.GetProperty("Top & Botom dither (true/false)", true);
var H_PADDING = window.GetProperty("Horizontal padding [0;20]", 20);
var TXT_ALIGN = window.GetProperty("Text alignment (left/center/right)", "center");
var LIGHT_BG = window.GetProperty("Light background", true);
var DEBUG = false;
var DEFAULT_OFFSET = 29;
// START
function on_size() {
    var k;
    ww = window.Width;
    wh = window.Height;
    // exit test on useless calls made (wsh tweak)
    if (!ww && !wh) return true;
    midpoint = wh / 2 - LINE_HEIGHT / 2;
    // colours
    g_plainbg_colour = RGBA(140, 200, 250, 255);
    g_ovbg_normalcolour = RGBA(000, 000, 000, 130);
    g_ovbg_highlightcolour = RGBA(020, 100, 240, 130);
    g_txt_normalcolour = RGBA(200, 200, 210, 255);
    g_txt_highlightcolour = RGBA(255, 255, 255, 255);
    g_txt_shadowcolour = RGBA(000, 000, 000, 150);
    if (fb.IsPlaying || fb.IsPaused) {
        g_scroll = 0;
        get_lyrics();
        change_focus();
        k = g_tab[focus].ante_lines * LINE_HEIGHT;
            pos = midpoint - k;
        } else {
            delta = (g_tab[g_tab.length - 1].ante_lines + g_tab[g_tab.length - 1].total_lines);
            pos = (wh / 2) - (delta * LINE_HEIGHT / 2);
function on_paint(gr) {
    PLAIN_COLOR_BG && gr.FillSolidRect(0, 0, ww, wh, g_bgcolour);
        show_lyrics(gr, g_tab, pos);
        DEBUG && gr.GdiDrawText(g_lyrics_status.toString(), g_font, g_normalcolour, 5, 5, ww, LINE_HEIGHT, DT_TOP | DT_LEFT | DT_WORDBREAK | DT_CALCRECT | DT_NOPREFIX);
    DITHER && gr.FillGradRect(0, 0, ww, 11, 90, g_txt_shadowcolour, RGBA(0, 0, 0, 0));
    DITHER && gr.FillGradRect(0, wh - 11, ww, 11, 270, g_txt_shadowcolour, RGBA(0, 0, 0, 0));
function on_mouse_lbtn_dblclk(x, y, mask) {
    on_size();
function on_mouse_leave() {
    window.Repaint();
function on_playback_time(time) {
    // at each new seconde, centiemes is reset to 0 (Increment on timer every 100ms)
    centiemes = 0;
    if (g_lyrics_status == 0) {
        if (elap_seconds.Eval() == 3) {
            on_size();
        window.Repaint();
    pos = 0;
    g_scroll = 0;
    get_lyrics();
    change_focus();
// fb.trace(lyrics_dir);
function on_playback_seek(time) {
    var k;
        g_scroll = 0;
        change_focus();
        pos = midpoint - k;
        window.Repaint();
function on_playback_stop(reason) {
    if (reason == 0) {
        // Stop
        window.Repaint();
function on_mouse_wheel(delta) {
        if (delta > 0) {
            pos = (pos >= midpoint) ? pos : pos + LINE_HEIGHT;
        } else {
            pos = (pos <= (wh / 2 - g_tab_length * LINE_HEIGHT)) ? pos : pos - LINE_HEIGHT;
        window.Repaint();
function on_timer(id) {
    var t1 = elap_seconds.Eval() * 100 + centiemes;
    var t2 = len_seconds.Eval() * 100;
    var p1, p2;
    if (t1 > t2 - 100) {
    if (g_playtimer) {
        if (g_playtimer.ID == id) {
            if (!g_is_scrolling && t1 >= g_tab[focus_next].timer) {
                p1 = g_tab[focus].ante_lines * LINE_HEIGHT;
                p2 = g_tab[focus_next].ante_lines * LINE_HEIGHT;
                g_scroll = p2 - p1;
                change_focus();
                g_is_scrolling = true;
            if (g_scroll > 0) {
                pos--;
                g_scroll--;
                window.Repaint();
            } else {
            centiemes = (centiemes > 98) ? 0 : (centiemes + 1);
function show_lyrics(gr, tab, posy) {
    var i, k;
    var text_colour;
    var txt_align;
    gr.SetTextRenderingHint(5);
    gr.SetSmoothingMode(2);
    switch (TXT_ALIGN.toUpperCase()) {
    case "LEFT":
        txt_align = lc_stringformat;
        break;
    case "CENTER":
        txt_align = cc_stringformat;
        break;
    case "RIGHT":
        txt_align = rc_stringformat;
        break;
    default:
        if (posy >= 0) {
            LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy - wh / 2), ww, Math.floor(wh / 2), g_ovbg_normalcolour);
    } else {
        LIGHT_BG && gr.FillSolidRect(0, 0, ww, wh, g_ovbg_normalcolour);
    for (i = 0; i < tab.length; i++) {
        if (Math.round(posy) >= (LINE_HEIGHT * -4) && Math.round(posy) < wh) {
            if (i == focus && g_lyrics_status == 1) {
                text_colour = g_txt_highlightcolour;
            } else {
                } else {
                    text_colour = g_txt_normalcolour;
                LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy), ww, (tab[i].total_lines * LINE_HEIGHT - 0), (i == focus && tab[i].text.length > 1 && g_lyrics_status == 1) ? g_ovbg_highlightcolour : g_ovbg_normalcolour);
            TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1 + H_PADDING, Math.floor(posy) + 0, ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
            TEXT_SHADOW && gr.DrawString(tab[i].text, g_font, g_txt_shadowcolour, 1 + H_PADDING, Math.floor(posy) + 1, ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
            gr.DrawString(tab[i].text, g_font, text_colour, 0 + H_PADDING, Math.floor(posy), ww - H_PADDING * 2, (tab[i].total_lines * LINE_HEIGHT), txt_align);
        posy = Math.floor(posy + LINE_HEIGHT + ((tab[i].total_lines - 1) * LINE_HEIGHT));
    if (g_lyrics_status > 0 && posy <= wh) {
        LIGHT_BG && gr.FillSolidRect(0, Math.floor(posy), ww, Math.floor(wh), g_ovbg_normalcolour);
function grab_timer(tab, str, count, timer_prec, balise) {
    var tminutes, tsecondes, tcentiemes;
    var balise_type = -1;
    var i;
    var redo = 0;
    var f_sentence = new sentence;
    var b = balise - 1;
    while (balise_type < 0) {
        if (g_lyrics_status == 1 && balise > 0) {
            if (str.substring(0, 1) == "[") {
                tminutes = str.substring(1 + (b * g_balise_char_offset), 3 + (b * g_balise_char_offset));
                tsecondes = str.substring(4 + (b * g_balise_char_offset), 6 + (b * g_balise_char_offset));
                // balise type test [99:99] or [99:99.99]
                if (str.substring(6, 7) == "]") {
                    balise_type = 1;
                    tcentiemes = 0;
                } else {
                    balise_type = 2;
                    tcentiemes = str.substring(7 + (b * g_balise_char_offset), 9 + (b * g_balise_char_offset));
                switch (str.substring(1, 2)) {
                case "0":
                    f_sentence.type = "ly";
                    f_sentence.timer = Math.round(tminutes) * 60 * 100 + Math.round(tsecondes) * 100 + Math.round(tcentiemes) - DEFAULT_OFFSET;
                    f_sentence.text = remove_enhanced_balises(str.substring(g_balise_char_offset * g_balise_total, str.length));
                    break;
                case "1":
                    break;
                case "2":
                    break;
                case "3":
                    break;
                default:
                    // technical info (not displayed)
                    f_sentence.type = null;
                    f_sentence.timer = 0;
                    f_sentence.text = "";
            } else {
                // no balise ==> line is set as a comment (as a blank line)
                if (count == 0) g_lyrics_status = 2;
                balise_type = 0;
                f_sentence.timer = timer_prec;
        } else {
            f_sentence.type = "tx";
            // check if it's not finally a synch lyrics (lrc) with some first lines with no timestamp!
                    g_lyrics_status = 1;
                    g_balise_char_offset = 7;
                } else if (str.substring(9, 10) == "]") {
                    g_balise_char_offset = 10;
                } else {
                    balise_type = 0;
                    f_sentence.text = str;
            } else {
                balise_type = 0;
        redo++;
    return f_sentence;
function load_file(filePath, fileName) {
    var tab = Array();
    var fline = new sentence;
    var count = 0;
    var enr = 0;
    var str = "";
    var balise;
    var delta;
    g_file = open_file(filePath, fileName, ForReading);
    g_balise_shift = 0;
    while (!g_file.AtEndOfStream) {
        str = g_file.ReadLine();
        g_balise_total = 0;
        if (g_lyrics_status == 1) {
                    balise = 0; // b = # of balise
                    while (str.substring(balise * 7, balise * 7 + 1) == "[") {
                        balise += 1;
                } else {
                    while (str.substring(balise * 10, balise * 10 + 1) == "[") {
                        balise += 1;
                g_balise_total = balise;
            } else if (enr == 0) {
                g_balise_total = 1;
        } else {
            g_balise_total = 1;
        if (g_balise_total > 1) g_multi_balise = true;
        else g_multi_balise = false;
        // str loop for each balise found for it ==> occurs created in the array
        for (balise = 1; balise <= g_balise_total; balise++) {
            fline = grab_timer(tab, str, count, (count > 0) ? tab[count - 1].timer : 0, balise);
            if (fline.type != null) {
                tab.push(fline);
                count++;
        enr += 1;
    close_file(g_file);
    // if file read is empty, set lyrics as not found to avoid script errors
    if (count == 0) {
        g_lyrics_status = 0;
        g_tab = load_track_info();
        return g_tab;
    } else {
        // add a default last sentence with a timer maximum (for ease of use focus line search method)
        tab.push(new sentence);
        tab[count].type = "ly";
        tab[count].timer = 9999999;
        tab[count].text = "---";
        tab[count].total_lines = 1;
        tab[count].ante_lines = tab[count - 1].ante_lines + tab[count - 1].total_lines;
        return sort_tab(tab);
function parse_tag(tag) {
    var t_tab = Array();
    var i, j, count;
    j = 0;
    for (i = 0; i < tag.length; i++) {
        if (tag.charCodeAt(i) == 10) {
            t_tab.push(tag.substring(j, i));
            j = i + 1;
    return parse_line(t_tab);
function parse_line(tagtab) {
    var tab = Array();
    var count = 0;
    var enr = 0;
    var str = "";
    var balise;
    var delta;
    g_balise_shift = 0;
    for (enr = 0; enr < tagtab.length; enr++) {
        str = tagtab[enr];
        g_balise_total = 0;
                        balise += 1;
                } else {
                        balise += 1;
                g_balise_total = 1;
        } else {
            g_balise_total = 1;
                tab.push(fline);
                count++;
    if (count == 0) {
        return g_tab;
    } else {
function load_track_info() {
    var tab = Array(new sentence, new sentence, new sentence, new sentence);
    var count = 0;
    tab[count].type = "tx";
    count++;
    tab[count].text = artist.Eval();
    count++;
    tab[count].text = title.Eval();
    count++;
    count++;
    return calc_lines(tab);
function open_file(filePath, fileName, ioMode) {
    var fileInst = null;
    var bool = file_exists(filePath + fileName);
    if (bool) {
        fileInst = g_fso.OpenTextFile(filePath + fileName, ioMode);
    return fileInst;
function close_file(fileInst) {
    fileInst.Close();
function read_file(fileInst) {
    var line = fileInst.ReadLine();
    return line;
function folder_exists(folderPath) {
    var fso, bool;
    bool = fso.FolderExists(folderPath);
    return bool;
function file_exists(filePath) {
    var fso, bool;
    bool = fso.Fileexists(filePath);
    return bool;
function lyrics_folder_exists() {
    var fso;
    var bool = 1;
    if (folder_exists(lyrics_dir) == false) {
        fso.CreateFolder(lyrics_dir);
        bool = 0;
    return bool;
function get_lyrics() {
    var i = 0;
    var nbl = 0;
    var delta;
    var tag;
    var bool_tag = false;
    // reset lyrics tab
    if (g_tab.length > 0) g_tab.splice(0, g_tab.length);
    pos = midpoint;
    focus = 0;
    window.Repaint();
    // check TAGs
    tag = lyrics.Eval();
    if (tag.length > 0) {
        bool_tag = true;
        if (tag.substring(0, 1) == "[") g_lyrics_status = 1;
        else g_lyrics_status = 2;
    } else {
        // check files
        if (file_exists(lyrics_dir + g_lyrics_filename + ".lrc")) {
            g_lyrics_filename = g_lyrics_filename + ".lrc";
        } else {
            if (file_exists(lyrics_dir + g_lyrics_filename + ".txt")) {
                g_lyrics_filename = g_lyrics_filename + ".txt";
            } else {
    // if lyrics found
        if (bool_tag) {
            g_tab = parse_tag(tag);
        } else {
            g_tab = load_file(lyrics_dir, g_lyrics_filename);
        // console dump of the memory tab loaded
            for (i = 0; i < g_tab.length; i++) {
                //fb.trace("line #"+i+" = "+g_tab[i].text + " / "+g_tab[i].timer + " / "+g_tab[i].total_lines + " / "+g_tab[i].ante_lines);
    } else {
    if (g_lyrics_status == 2) {
        for (i = 0; i < g_tab.length - 1; i++) {
            g_tab[i].timer = i * Math.floor(len_seconds.Eval() * 100 / g_tab.length);
function change_focus() {
    var i, j;
        // search line index just after actual timer
            if (g_tab[i].timer > t1) break;
        focus_next = i;
        focus = (i > 0) ? i - 1 : 0;
        // now i check if there are more than one line with the same timer as focus one & if found, i take it as new focus 'cause it's the first (not a blank line)
        if (focus > 0) {
            for (i = 0; i < focus; i++) {
                if (g_tab[i].timer == focus) {
                    focus = i;
                    break;
function calc_lines(ctab) {
    var i, j;
    var padx = 0;
    g_tab_length = 0;
    for (i = 0; i < ctab.length; i++) {
        // calc sentence #lines to display / window.width
        if (ctab[i].type != null) {
            var tmp_img = gdi.CreateImage(ww - (H_PADDING * 2) - padx, 100);
            var gp = tmp_img.GetGraphics();
            var lineh = gp.MeasureString(ctab[i].text, g_font, 0, 0, ww - (H_PADDING * 2) - padx, wh).Height;
            ctab[i].total_lines = (lineh / LINE_HEIGHT) > Math.floor(lineh / LINE_HEIGHT) ? Math.floor(lineh / LINE_HEIGHT) + 1 : Math.floor(lineh / LINE_HEIGHT);
            ctab[i].ante_lines = 0;
            for (j = 0; j < i; j++) {
                ctab[i].ante_lines += ctab[j].total_lines;
            CollectGarbage();
        g_tab_length += ctab[i].total_lines;
    return ctab;
function sort_tab(tab2sort) {
    var tab = Array();
    var i, j;
    var tmp = new sentence;
    var smallest = 0;
    for (i = 0; i < tab2sort.length; i++) {
        for (j = i; j < tab2sort.length; j++) {
            if (tab2sort[i].timer > tab2sort[j].timer) {
                tmp = tab2sort[i];
                tab2sort[i] = tab2sort[j];
                tab2sort[j] = tmp;
        tab.push(tab2sort[i]);
    tab = calc_lines(tab);
    return tab;
function remove_enhanced_balises(str) {
    var i;
    var chr1, chr2;
    var new_str = "";
    for (i = 0; i < str.length; i++) {
        chr1 = str.substring(i, i + 1);
        if (i + 10 <= str.length) chr2 = str.substring(i + 9, i + 10);
        else chr2 = null;
        if (chr1 == "<" && chr2 == ">") {
            i = i + 9;
        } else {
            new_str = new_str + chr1;
    return new_str;
Reply #566
samples updated:
http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip
thumbs2: added "cycle" image mode. default is off but can be set to 5, 10 or 20 seconds.
new script: themed toolbar buttons. can be seen here on this old screenshot. clicky
how they look depend on your windows theme - they don't work on windows classic. XP luna and aero/basic in vista/7 work fine as should all 3rd party themes.
Reply #567
sorry, my bad.
[00:32.13]?????????????
[00:37.96]?????????
[00:42.72]
[02:05.69][00:43.23]?????????
[02:10.61][00:47.96]?????????
[02:15.86][00:53.24]?????????????
[02:21.08][00:58.55]?????????
[02:26.04][01:03.72]
[03:08.01][02:26.39][01:04.13]????????????
a huge problem?the Blank lines can't show up
e.x.when it is [00:42.72][02:26.04][01:03.72]
check it
Reply #571
update!
Lyriks 1.1 (build 20101020.1225) - a WSH lyrics module by Br3tt
- This WSH script get lyrics from TAG first then from local file in Music folder then in foobar2000\lyrics\ and finally it displays them (scrolling+sync)
- It handles TXT and LRC format (sync handled), but not the LRC Enhanced format (translated to simple LRC format)
- exotics timestamps are now handled (like [9:99], [99:99.999], [9:99.999], [99:99:999] ...)
- filenames supported are : <%artist%> -<%title%>.lrc (or .txt)  AND <%artist%> - <%title%>.lrc (or .txt)
- Comments, Blank lines (no timestamp) and Info lines (ar:, ti, ...) are ignored.
- Requirements :
  1) foobar2000
  3) this script!
- This script don't make any changes to your files and write nothing on your system, except the creation of the folder foobar2000/lyrics if not found
Get it from here:
http://pastebin.com/LPyVy09c
Quick Changelog:
- exotic timestamps => converted to my default : [99:99.99]
- lyrics in music folder ckecked
- blank lines not displayed on multi-timestamp lines => fixed
- tweaks...
*waits for feedback*
Reply #572
I love you Falstaff!!!!
Reply #573
So i bit the bullet and been trying to use code with WSH panel. It's at least far better than the old ways and also far more flexible. I picked up the simple bio script in marc2003 sample pack and modified it a little into this (basically it supports cache life time and I changed the last.fm button feature a little). I hope someone can help me with the flashing tooltip problem. Thanks and marc2003, you were great with these examples to help me pick up using this component.
Reply #574
Me too  You are great
May I not leave you loose, but suggesting another feature? - If user clicks on timestamped lyrics row then seek the track to that position. I know you can do it, as you've made WSH seekbar among other things, but don't know what you think about it?
