Topic: WSH Panel Mod script discussion/help (Read 1413801 times) previous topic - next topic
Reply #2875
i'd expect the script to hang because you're not telling it when to stop. i tried the code in a browser using console.log and that also hangs.
It evaluates to a boolean... so while(int > 0) it's "true"... so stepping any positive integer by -- will become "false" when it gets to zero, or -1 depending on the boolean method... so while(i--) should stop when it reaches 0 and it does for a single while() loop, but not for a nested while().
2 = true
1 = true
0 = false
-1 = false
etc...
It should only fail if the value starts at 0 or -1... since then it will always be "false", so it becomes while(false) which will always be true. :| ...lol
Edit: answered my own problem... second loop is comparing false to false once it has passed the first sub loop... so need to re-set Y to > 0... forehead/desk, etc.
For anyone interested:
var x = list.length/count/ubound/etc;
var y = list.length/count/ubound/etc;
var z = y;
while(x--){
    //do something with x, A = B(x) etc.
    y = z;
    while(y--){
        //do stuff with x/y
Is WAY quicker than any for() loops... in my loop, when using: *.item(x).Compare(*.item(y)) ... it's easily 3 times as quick.
Also... using WSH item.compare() is quicker than fb.TitleFormat()... and slightly quicker than item(x).Path === item(y).Path... I dropped my list comparison from about 5 seconds, down to about 300ms.
Reply #2876
well that just shows how much i (don't) know.
i thought the while loop would continue below 0.
Reply #2877
2 = true
1 = true
0 = false
-1 = false
etc...[/code]
You're wrong on this one. Only 0 and -0 are considered false. All other values (1, -1, 2, -2...) are considered true. The issue with your original loop is the following: the inner loop (dependent on y) exits during the first iteration of the outer loop when y reaches 0 (and is decremented to -1). All subsequent runs of the inner loop will pick y up from -1 and go downwards, never able to reach 0 again and thus exit, resulting in an infinite loop.
EDIT: To put it simply, while(y) is equivalent to while(y != 0), not while(y > 0) (where y is an int).
Reply #2878
Hi Marc, thanks a lot for your great work over the years. I've been using the "Now Playing" panel for a while, and is it possible that the Auto Download function is not longer working? I'm aware of the changes, i.e. that downloads are slower, but that does not appear to be the issue:
Essentially, images are not being loaded unless I specifically click on "Download Artist Art", and then it's downloaded within a few seconds. But with download on automatic and without a manual click nothing is being downloaded for the length of a full song.
Reply #2879
automatic downloads are still working here. even though i had to make changes to the way my script gets images, the automatic download bit is still the same as before.
Reply #2880
I've narrowed the problem down a bit, and the problem appears to be quite specific. You are right, automatic downloads work fine when playing local files.
But I'm streaming music from my Android (via Cast To UPnp/DLNA). Automatic downloads work most of the time when manually starting a track on Google Music, but not when playing a playlist and tracks automatically change. In that case, image downloads are never triggered, but work fine when clicking on image download.
I realise this is a very specific problem. But is there something you could do about it?
Reply #2881
sorry but i have no idea how upnp works and i have no way to reproduce the scenario you are faced with.
Reply #2882
Sure, I realise this is an unusual scenario. Would it be possible to associate a keyboard shortcut to manually trigger downloads? That way I could use my remote control...
Reply #2883
Hi marc2003, I see you added AUTOPLAYLIST function to your last fm charts script, this is awesome !
Thank you for this hundred time  !
But every time I reboot or restart foobar, it's automatically on lastfm, i have to change to autoplaylist every time, I know it's not a big deal but how is it possibl to let it on Autoplaylist ?
Thanks  !
Reply #2884
@Pintu, i know it's possible to make WSH panel mod respond to key presses but it can't be global. foobar must have focus and it has to the last panel you clicked. if anything else has focus it won't work. also, i can't really build a UI to change the setting. you need to need to tell me which key you want to use and i'll try and make it work.
@jahtimes, that's a bug - well spotted! it's now fixed. right click panel>Update script.
full download: https://dl.dropboxusercontent.com/u/22801321/wsh/samples.zip
changelog: https://dl.dropboxusercontent.com/u/2280132...h/changelog.txt
Reply #2885
Thanks for the quick reply, as usual... Perfect !
Reply #2886
hi marc, I love the option to click in the charts to make playlists - makes a lot of sense. Do you think you could add an option to make normal playlists not autoplaylists though? If your library is stable there isn't much need for autoplaylists and having many of them slows down foobar noticably on startup when all the queries have to be run again. Thanks, hope you're well
Reply #2887
using autoplaylists is the only way i can create a playlist with a given artist/album/track. i suppose it might be possible to create a hack that creates an autoplaylist, copies the content to a new playlist and then removes the autoplaylist. i might have a go at that tomorrow.
Reply #2888
i've just done it now and it seems to work ok. open the editor dialog and replace the very last function....
function on_mouse_lbtn_up(x, y) {
    li.lbtn_up(x, y);
with
    if (li.lastfm_link == "autoplaylist" && li.in_range && x > li.x + li.text_x && x < li.x + li.text_x + Math.min(li.names_widths[li.index], li.text_width)) {
        fb.CreateAutoPlaylist(fb.PlaylistCount, li.names[li.index], li.queries[li.index]);
        plman.DuplicatePlaylist(fb.PlaylistCount - 1, li.names[li.index])
        plman.RemovePlaylist(fb.PlaylistCount - 2);
        fb.ActivePlaylist = fb.PlaylistCount - 1;
    } else {
        li.lbtn_up(x, y);
Reply #2889
Yeah I realised that it would require a different method completely just after I posted - thanks though this way seems to work great! I'm going to use this a lot, really appreciate it
Reply #2890
Marc, thanks a lot. F9 would be a good one, but I (or anyone else) could remap it with Autohotkey to use a different one, as long as there is some hotkey programmed.
Reply #2891
it's easy enough to change the key in the script. i just wasn't prepared to make any kind of UI to do it. just stick this in the panel somewhere.
function on_key_down(vkey) {
    if (p.metadb && vkey == 120) im.download();
Reply #2892
Marc i need your help, is it possible to tell script to open properties window in desired size? I want that most of my settings be in properties, not in the menu, so i need that window be longer than usual to be able to see all text..
It should look like this:
Reply #2893
of course not. you can open it with window.ShowProperties() and that's it. there are no options.
i suppose you could fix the size to something larger if you downloaded the source code, made adjustments and re-compiled it.
Reply #2894
Uh, not worth . I'll use menu then. Thanks..
Btw, do you know what compiler to use and what program i need to change foobar equalizer color? It's possible, it have source code somewhere on net..
Reply #2895
obviously you could do it with visual studio. i have no idea if it's possible with anything else.
Reply #2897
Excellent, that works great. I've combined it with the following AutoHotKey Script to trigger the Keypress in the Panel every time the foobar2000 window title changes (which for shows "foobar2000 - %artist%).
#Persistent
SetTitleMatchMode, 1
WinGetTitle, TitleLast, foobar2000
SetTimer, CheckChanged, 1000;Check every quarter-second
return
CheckChanged:
WinGetTitle, Title, foobar2000
If (Title <> TitleLast)
    click 1000, 200
    Send {F9}
TitleLast := Title
return
Reply #2898
Hi marc2003 !
In your autoplaylists WSH panel mod, is it possible to "SORT DESCENDING BY"
For example, in my media library search when I type : %added% DURING LAST WEEK SORT DESCENDING BY %added%
I have a playlist with most recent added album at the top of my playlist. With your autoplaylists WSH I have the most recent added album at the bottom of my playlist.
I don't know if it's possible to change this.
Sorry for bad english, hope you've understood me.
Reply #2899
Do you know if someone out there developed a script for WSH similar to foo_graphical_browser ?
I tried quickly yesterday to adapt the coverflow script made by falstaff to make it display a grind of covers instead of just one row of covers, but it seems to require quite some work, i gave up.
