Topic: [intended behavior]Tries to play files on non-present locations (Read 10841 times) previous topic - next topic
Re: [intended behavior]Tries to play files on non-present locations
Would that be doable with a hook? Or would it require an input that actually lies and says the file is readable, just to report the ERROR tag?
@kode54, unfortunately I'm not coder (maybe a little on BASIC... :) )
I think @Case and You know how implement that better.
I don't like this idea. If a file is corrupted trying to tag it either fails or makes any problems in the file worse. If a file doesn't exist you can't tag it. Can't you just remove your corrupted files so that they don't bother you again?
....Can't you just remove your corrupted files so that they don't bother you again?
In case of a playlist with radio stations with for example :
Unable to open item for playback (Network error): "http://streaming206.radionomy.com/A-RnB-FM-WEB1"
I don't want to remove that radio station b/c sometimes the radio station stream is down temporarily.
 ;) @LL25255252, you don't imagine how i glad of your support!
For example in attachment (playlist with many radio stations stream and some items mark as playback error!)
Maybe not for Stop on Error component (or TAG edit), but fb2k must have that exactly.
@Case, a lot of time has passed and fb2k got a lot of good changes. In this regard, let me return to the following issues that were earlier:
1. stop playback of dead radio streams
That said I took a look at the problem and unfortunately my component can't help here. The callback I use is called only after the core has tried opening the stream for 20 seconds and given up. It's up to Peter to improve the behavior here.
2. the ability to indicate playlist elements that have errors
maybe with the current interface fb2k is it possible to implement for the Stop on Error component?
@Case,
I did not notice in which version the behavior of the fb2k was changed but at least between versions 1.5.1 and 1.4. there is a difference.
For version fb2k1.4, when an error occurs, the fb go to play the next playlist item.
For version fb2k1.5.1, when an error occurs, the fb does not go to the next item of the playlist, but again tries to play that item.
Perhaps now there is an opportunity to improve the Stop on Error component for streaming items.
For testing, here is a "dead" link:
http://textville.net/chiptune.ogg?1:kjzAkNr1v8
Please take a look at this issue again.
Reply #32
Sergey77:  I have Foobar 1.5.1.  When I try to play a stream in my playlist that is not working, after the error message appears Foobar does jump to the next station on the list, but does not start to play it until I double-click it.  In Prefs/Playback/Other, I have checked "Stop playback after the current track", and NOT checked "Reset the above when stopping."  Try those settings.
@sveakul, thanks for your answer and advice, I will use it. This works well for the streams. For other items of the playlist, I will need to disable this option.
But I once again tested the clean versions of fb2k and I must say that the behavior, that I mentioned earlier in versions 1.4 and 1.5.1, is the same. Sorry for the hurried conclusions.
