Topic: foo_wave_seekbar (Read 820193 times) previous topic - next topic
foo_wave_seekbar
Reply #1225
Dario, Manchesterer: Unlike in what version? 0.2.32? 0.2.31? 0.2.ancient? Kind of hard to pinpoint what might've gone wrong, if anything, if there's no baseline version to compare against. Give me something to work with here, previously working versions, OSes, components installed, frontend used, anything. Is the console so blank and boring that you both omitted it?
I'm not psychic, you know.
As for "second track displays the first waveform", the previous displayed waveform remains until the next one can be retrieved, IIRC.
Stay sane, exile.
foo_wave_seekbar
Reply #1226
I got no problems with latest (.33) version of wave_seekbar even with files that are played through problematic foo_input_zxtune. Everything seems to be OK.
foo_wave_seekbar
Reply #1227
@Zao
- troublesome version is 0.2.33 (as stated in my previous post)
- previously working version - 0.2.29
- OS - Win 7 Pro 32 bit and Win XP Pro 32 bit
- frontend used: GDI
- console - nothing unusual:
  Opening track for playback: "D:\MUSIC\xxx\xxx.mp3"
  Wave cache: finished analysis of "D:\MUSIC\xxx\xxx.mp3"
- wavecache.db is 20 MB
- space on disk - a lot
- memory usage - 48 MB
- components installed:
Core (2013-02-13 11:26:10 UTC)
    foobar2000 core 1.2.3
foo_abx.dll (2009-06-07 21:25:26 UTC)
    ABX Comparator 1.3.4
foo_ac3.dll (2012-08-29 15:57:04 UTC)
    AC3 decoder 0.9.7
foo_cdda.dll (2013-02-13 11:24:22 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2013-02-13 11:24:22 UTC)
    Converter 1.5
foo_cuefilter.dll (2010-12-08 03:01:26 UTC)
    CUE Playlist Filter 0.1.7.0
foo_dsp_std.dll (2013-02-13 11:24:44 UTC)
    Standard DSP Array 1.2
foo_dsp_vlevel.dll (2012-07-16 15:18:22 UTC)
    VLevel 20080302.0
foo_fileops.dll (2013-02-13 11:23:12 UTC)
    File Operations 2.2
foo_flv.dll (2012-12-29 07:00:00 UTC)
    Flash Video Decoder 0.9.6
foo_input_amr.dll (2009-03-06 05:20:06 UTC)
    AMR input 1.1.1
foo_input_dvda.dll (2010-12-08 03:01:26 UTC)
    DVD-Audio Decoder and Watermark Detector 0.4.1
foo_input_la.dll (2010-12-08 03:01:26 UTC)
    Lossless Audio(La) decoder 0.01
foo_input_monkey.dll (2012-04-20 19:24:30 UTC)
    Monkey's Audio Decoder 2.1.6
foo_input_ofr.dll (2010-12-08 03:01:26 UTC)
    OptimFROG Lossless/DualStream Decoder 1.21b
foo_input_shorten.dll (2010-12-08 03:01:26 UTC)
    Shorten decoder 0.4.2.2
foo_input_std.dll (2013-02-13 11:23:54 UTC)
    Standard Input Array 1.0
foo_input_tak.dll (2012-09-25 17:04:20 UTC)
    TAK Decoder 0.4.5
foo_input_tta.dll (2010-12-08 02:57:36 UTC)
    TTA Audio Decoder 3.2
foo_jesus.dll (2011-04-18 18:34:28 UTC)
    Autosave & Autobackup 10
foo_lnk.dll (2010-01-08 02:57:56 UTC)
    Shell Link Resolver 1.3.1
foo_masstag.dll (2009-09-18 08:01:36 UTC)
    Masstagger 1.8.4
foo_menu_addons.dll (2010-01-16 09:18:34 UTC)
    Menu Addons 1.4.2
foo_midi.dll (2012-12-31 12:25:22 UTC)
    MIDI synthesizer host 1.186
foo_navigator.dll (2012-12-15 13:46:44 UTC)
    Navigator 0.8
foo_playcount.dll (2011-07-13 18:47:18 UTC)
    Playback Statistics 3.0.2
foo_quicksearch.dll (2012-10-30 16:50:06 UTC)
    Quick Search Toolbar 3.4
foo_rgscan.dll (2013-02-13 11:24:30 UTC)
    ReplayGain Scanner 2.1.2
foo_run.dll (2010-12-08 03:01:26 UTC)
    Run services 0.3.7
foo_shutdown.dll (2010-12-08 03:01:26 UTC)
    Foo Shutdown 0.9.3
foo_taskbar_playback_progress_bar.dll (2012-06-17 13:49:14 UTC)
    Taskbar Playback Progress Bar 1.1.3
foo_ui_columns.dll (2011-02-28 06:23:00 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2013-02-13 11:23:58 UTC)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2010-12-08 03:01:26 UTC)
    Album list panel 0.3.5
foo_uie_explorer.dll (2010-12-08 03:01:26 UTC)
    Explorer Tree 2.04.8
foo_uie_lyrics3.dll (2012-11-07 15:39:48 UTC)
    Lyric Show Panel 3 0.3.6 beta 5
foo_uie_panel_splitter.dll (2009-12-10 07:16:12 UTC)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2009-09-24 07:44:46 UTC)
    Playlists Dropdown 0.7.6
foo_uie_vis_channel_spectrum.dll (2010-12-08 03:01:26 UTC)
    Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2010-03-07 17:24:48 UTC)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel_mod.dll (2012-10-16 00:45:20 UTC)
    WSH Panel Mod 1.5.6
foo_verifier.dll (2010-12-08 03:01:26 UTC)
    File Integrity Verifier 1.1
foo_wave_seekbar.dll (2013-03-25 23:47:50 UTC)
    Waveform seekbar 0.2.33
foo_wave_seekbar
Reply #1228
Remember when you update the component to never hand-pick any files from the archive, let the component preferences pane install it as a whole.
Also, how large are your wavecache.db files, and do you have sufficient space on that disk? What kind of memory usage do you have when running?
Stay sane, exile.
foo_wave_seekbar
Reply #1229
Manchesterer: Could you please try with each of the following versions, to see if there's one inbetween 0.2.29 and current that introduces the problem:
0.2.29
0.2.30
0.2.30.1
0.2.31
0.2.32
0.2.33
Stay sane, exile.
foo_wave_seekbar
Reply #1230
0.2.29    OK
0.2.30    OK
0.2.30.1  OK
0.2.31    No waveform, console OK
0.2.32    No waveform, console OK
0.2.33    No waveform, console OK
- testing OS - Win XP Pro 32 bit
- all the rest - see my previous post
- installed via preferences pane
- wavecache.db deleted each time between installs
foo_wave_seekbar
Reply #1231
I would recommend you few that encounter this no-waveform problem should run 0.2.29 until I've gotten around identifying the root cause.
For you all that do not exhibit the problem, 0.2.33 should be the preferred version, as the ones in-between are in a bit of flux.
Note that in general there is no guarantee that a downgrade will work and retain your settings, as the settings code only assumes compatibility one way. If you're one of the few that needs to roll back temporarily, ensure that you set the Downmix Display setting to "as-is" or "downmix to mono" to avoid configuration parse problems with 0.2.29.
Stay sane, exile.
foo_wave_seekbar
Reply #1232
One thing I just noticed: My waveform is working fine. I'm using the downmix to stereo option. Either this or the keep as-is option work fine. However, when I choose downmix to mono the waveform disappears. Maybe this info is helpful?
edit: @marc2003 Doh, that was the cause. Never mind the above...
foo_wave_seekbar
Reply #1233
^are you sure you have front center (mono) selected in the channel display order list?
foo_wave_seekbar
Reply #1234
Maybe others, who have problems with displaying also have selected "downmix to mono" and "center" unchecked    ?
I got some kind of idea. Just idea and, not the "feature request". How about possibility of storing created waveform into file's metadata? That would be something similar to metadata that is present in AIFF files from Beatport. All AIFF files from Beatport contain an image, which is just waveform of whole file. Maybe there's someone who would like to have possibility to add such image to their files? That would require just a checkbox in preferences ("add waveform image to file's metadata), 2 fields for setting resolution - that fields that currently are shown in Advanced Preferences, option to choose which type of embedded image should be used (front/back/disc/artist/icon) plus maybe option to set compression/type of image (.bmp/.png/.jpg).
foo_wave_seekbar
Reply #1235
Apart from the rather hardcoded "screenshot" functionality, I have not had any plans on doing anything of the sorts.
As for "storing things in the tags", I've pondered storing the actual waveform in them for consumption by external tools and by the seekbar itself, but it hasn't really been much of need for such a thing.
Stay sane, exile.
foo_wave_seekbar
Reply #1236
@Zao
About this no-waveform problem with version 0.2.33,  I don't know of this has already been said but when this happens (and it happens to me very randomly) , all I have to do is to select another frontend, then the waveform appears and to re-select my previous frontend (direct3D) and it's ok.
Maybe this can help to find the issue.
Anyway, thanks for this great component.
Decalicatan Decalicatan
foo_wave_seekbar
Reply #1237
I assume that this is something else than the usual "won't see changes until a waveform is ready or you poke it with a stick" problem, which is a fundamental artifact of the architecture.
Stay sane, exile.
foo_wave_seekbar
Reply #1238
You assume right
Usually the waveform (for a song played for the first time, I mean) is ready in less than 1second.
The no-waveform issues I have met this week (for the first time), I become aware of them when I maximize foobar2000 to read infos about the now playing song and most of the time more than 1 minute has been played (enough for me to be curious about the song  )
foo_wave_seekbar
Reply #1239
Can you implement a selection cursor option that is negative color, like the text cursor in word?? On a song where theres a lot of white or black It's hard to see the cursor position even if I change it to another color. Thanks!
foo_wave_seekbar
Reply #1240
i'm also having problems with the last update - no waveform is displayed (win7-x64, foobar 1.2.4)
Later Edit: After deleting the wavecache.db it displayed the waveform.
Later Edit: It seems that it selectively display the waveform. Reverted back to 0.2.30.1 - the same problem. back to 0.2.30 - OK
foo_wave_seekbar
Reply #1241
The sky is the limit if you use the Direct3D frontend, like in this ancient screenshot -- you just need to learn how to program shader effects
As for finding and fixing the mystery of the ghostly waveforms, that's something that won't be solved until after the easter week, I'm way too stuffed with candy and relaxation (and not at my machine) to solve it.
Stay sane, exile.
foo_wave_seekbar
Reply #1242
There is an option on the waveform seekbar to "shade played". I like this feature as you can see from a distance how far through the track you are.
The problem is, the shade is so close to the normal color that it is difficult to see how far along is it.
My question is, is it possible to darken the shade of the part played?
foo_wave_seekbar
Reply #1244
Thanks Andreas! That did it.
foo_wave_seekbar
Reply #1245
I had the same problem as Dario described on page 49. The bug appeared after I updated from 0.2.29 (or .28, I don't know now) to 0.2.33. I fixed it by disabling the "Store analyzed tracks in mono" option in Preferences -> Advanced -> Tools -> Waveform Seekbar. I had the option enabled because I thought it would save me some HD space as I am using mono-downmixed waveforms anyway.
foo_wave_seekbar
Reply #1246
Zao
Your Waveform Seekbar (occasionally) fails to manage tracks which flow into each other without gaps.
Here is a failure from my foobar2000:
foo_wave_seekbar
Reply #1247
Hi Tom. I also store the waveforms in mono. I will update the component to the latest version, disable that setting (while still displaying a downmixed-to-mono waveform), and see if everything is alright. Thank you.
EDIT: Everything is working well now. Both downmixed and left as-is waveforms show no problems.
foo_wave_seekbar
Reply #1248
Zao
Your Waveform Seekbar regularly refuses to refresh its display when there are no gaps between one track and the next.
This problem only happens when using Direct 3D 9.0c; the problem does not exist when using GDI.
Post #1247 shows a screenshot of the (Direct 3D) problem.
Is there something you can do about this?
foo_wave_seekbar
Reply #1249
derty2, I just played Pink Floyd "The Dark Side of the Moon" and noticed no problems whatsoever. Please, make sure that "Store analyzed tracks in mono" is turned off under Preferences -> Advanced -> Tools -> Waveform Seekbar.
