Topic: foobar2000 v1.0 beta 6 (Read 48855 times) previous topic - next topic
Reply #50
You can't rearrange it. It's been stated several times that this is how the context menu will work.
Reply #51
While running Foobar2000 1.0 beta 4 I was getting some BSODs under Win 7 64bit-- I'm not 100% sure if Foobar is causing it but (I've run Memtest & done full surface scans of all my drives to rule out a hardware problem) it's been running each time it has happened which so far has been 3 times.  Unfortunately Windows isn't creating crash dumps so I haven't been able analyze them for the cause.  My theory is that the problem is related to either FLAC playback or the new monitoring function of the Media Library (which works amazingly well by the way!).  I have foobar monitoring my Music folder and I'm often downloading new music via bittorent that gets indexed while partially downloaded-- could that be the source of the problem?  I've just updated to beta 6 and so far the problem hasn't happened again.  Overall excellent work on this new release and the media library monitor is something I've been wanting for years.  One other question-- is there a list anywhere of skins that are compatible with v1.0?
Reply #52
Bug fix: Incorrect sorting of the "Duration" column in Default UI.
although that issue was fixed in beta4, using queries in media library search is still broken.
Change your query to ALL SORT BY %length_seconds%. The behaviour you're reporting is not necessarily incorrect.
Reply #53
when I'm trying to upgrade to 1.0 all my settings're getting lost
my total playtime, settings of components etc...
Reply #55
Programs running in user mode can't cause BSODs. The cause is either hardware problem or driver bug or occasionally even an OS bug. I'd suspect sound card drivers if you only see them with foobar. Especially if you use some other output mode than Direct Sound.
Reply #56
I'm installing new version on top of the one. I do not uninstall the old one
But I lose all my settings
Reply #57
ADv, what is the version you are upgrading from? And did installer show any warning messages?
Reply #58
Then you're going to have to provide more details.
For example:
Are you installing in portable mode or standard mode?
If standard: What is the location of your configuration files? (fb2k Preferences->General) Does changing this solve things?
elevatorladylevitateme
Reply #59
DUI spectrum. With the number of bands set at 80 (or less) cpu usage is low at 0-1%. With 160 bands selected the cpu usage rises hugely to >30%. XP SP3. This is in normal mode (i.e. not full screen). This is not really a big deal to me, but as I noticed the issue I thought I would point it out.
Reply #60
Moderation: Discussion about the new multimedia keys behaviour in 1.0 betas split [a href='index.php?showtopic=77581']here[/a].[/size]
Reply #61
I was very pleased to hear that 1.0 will support relative paths for media library. I have played around with this feature, and it seems that even for relative libraries, playlists do not use relative paths so that if the drive letter changes all my playlists break. Any thoughts?
Reply #62
[quote author=q-stankovic link=msg=676892 date=1262461589]I noticed the changes of edit menu: It is no longer related to playlist view but to focused element ...
Is the benefit of this newly added feature higher than the price (frustrating annoyment)?[/quote]
Excuse my tone - it seems i was a little bit frustrated.
If the change of edit menu functionalty (not remarkable in CUI!) is not the beginning of further planned changes could then this new feature be optional?
Reply #63
You are the first one to report such a problem. Please post your component list, as available in Preferences > Components > [copy] button in the top-right corner.
here it is
Core (2009-12-28 17:13:46)
    foobar2000 core 1.0 beta 6
foo_albumlist.dll (2009-12-28 17:11:48)
    Album List 4.4
foo_cdda.dll (2009-12-28 17:11:48)
    CD Audio Decoder 3.0
foo_converter.dll (2009-12-28 17:11:42)
    Converter 1.4
foo_dsp_std.dll (2009-12-28 17:11:56)
    Standard DSP Array 1.0
foo_fileops.dll (2009-12-28 17:10:46)
    File Operations 2.1.2
foo_freedb2.dll (2009-12-28 17:10:50)
    freedb Tagger 0.6.2
foo_input_std.dll (2009-12-28 17:11:30)
    Standard Input Array 1.0
foo_rgscan.dll (2009-12-28 17:11:30)
    ReplayGain Scanner 2.0.9
foo_ui_std.dll (2009-12-28 17:12:02)
    Default User Interface 0.9.5
foo_uie_panel_splitter.dll (2009-12-10 00:16:12)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_unpack.dll (2009-12-28 17:10:34)
    RAR reader 1.3
    ZIP/GZIP reader 1.0
Reply #64
Try with removing foo_uie_panel_splitter. You actually don't have any benefit from it, because it works only with Columns UI, which you don't have installed.
Reply #65
Is there a roadmap for 1.0 or just whenever it is done?
Reply #66
No, but Peter mentioned somewhere (in this thread?) that it will be one of the last betas as most problems should apparently have been fixed.
Reply #68
I would like to use this version of foobar (thank you Peter by the way for that great jewellery) but is it safe to rip/convert with it?
For the rest, I'm not scared of this beta as long as it doesn't touch to my tags!
Reply #69
@fbuser, thanks, but i had the problem before. i have that component since my last lousy attemp to theme fb2k
so its not that.. even if i install a new fresh beta 6 from right here, it would be the same.. personally it doesnt bother me, but this is a whole community and i want to help it improve, so may other not have the issues i have
P.S. there is some foobar log thing.. should it turn it on if it logs something and then paste the data here?
Reply #70
I have encountered a somewhat minor thing that bugs me when I switched to the 1.0 beta 6: before (i.e. 9.6.9), when I dragged an item from any playlist into the message window in Miranda (instant messenger), it would open the sending dialogue; however, with the new version it simply copies the artist and title as simple text into the message box.
Is there any way to change this back to normal, maybe even a setting that I just haven't stumbled across yet?
Thanks very much in advance.
Reply #71
Instead of having a separate Now Playing plugin, I've always bound a global hotkey to [context/playing] Copy. To spiff things up a little, I've also edited the Options>Advanced>Display>Legacy>Copy field to include a progressbar. This has stopped working as of the 1.0 betas, as the %playback_time% variable has stopped working. Actually, all variations of %playback_time% has stopped working (seconds et. al.) as well.
Now, here's the peculiar part. %playback_time% seems to be working everywhere except for the legacy fields, but everything else works in the very same fields where %playback_time% fails to return a value.
