Topic: Problems decoding specific AC3 file (Read 1597 times) previous topic - next topic
cannot convert ac3 to wav (using foo_ac3 0.9.3), with beta2 worked fine.
i get this Information popup:
Could not load info (Sharing violation) from:
"D:\Downloads\Torrent\1.wav"
closing the Information popup shows th Converter Status Report:
1 out of 1 tracks converted with major problems.
Source: "D:\Downloads\Torrent\1.ac3"
  An error occurred while writing to file (Unsupported format or corrupted file) : "D:\Downloads\Torrent\1.wav"
  Conversion failed: Unsupported format or corrupted file
ac3 file is ok, tested with ac3fix.
it writes a wav file of 0:00.640 (30720 samples) size is 122924 bytes.
Playback is ok.
Edit: Cannot covert in any format (FLAC, MP3)
LAME 3.100.1 -V0
Later EDIT: the problem is only with that specific file. other ac3-s work just fine.
LAME 3.100.1 -V0
Does ac3fix verify checksums? foo_ac3 certainly does, and fails outright on any frames where the checksum fails.
