Topic: Wavelet-transform based audio codec (Read 5341 times) previous topic - next topic
Has anyone heard about any wavelet-transform based audio codec?
I know two still-image codecs and one video codec, but have not heard about audio codecs yet. for some reason I believe that wavelet-transform will do a good job for audio. (in particullar, will introduce less pre-echo)
edit: typos
AdaptedWave
http://www.adaptedwave.com/
Unfortunately, the site is gone. There used to be lots of information there and some demo samples. Seems that they will return soon. (hopefully)
thanks.
but I wanted to see something working (to steal some ideas and compare achivements  )
i would ROCK of wavelets could do the same to audio encoding that it did with still images.
The jpeg2000 is far superior to plain jpeg.
Sven Bent - Denmark
Do you have any links to any tests done, JPEG VS JPEG2?
I also think that new methods for achieving transparent lossy audio coding are not necessary just gifted engineers for very fine-tuning.
I've seen some examples of Jpeg2000 vs normal JPEG, and beside some extra features like transparancy etc, imho the quallity of the format isnt much better. But it depends on your taste. Its like an Ogg-Vorbis vs MusePack tradeoff: the artifacts Jpeg2000 creates at lower quallity are less severe, but at higher quallity imho normal jpeg rules.
just my 2 cents, altough not really on topic ;-)
about that topic, should efforts indeed not be put on the current encoders, instead of new ones? exept when they are really superior...
[span style=\'font-family:Arial\'][span style=\'color:red\']Life Sucks Deeply[/span][/span]
JPEG2000 is not really more efficent than JPEG/JFIF for low compression (if you want image without visual artifacts).
But for highly compressed pictures, jpeg2000 is better than old jpeg. So it is depending on what you are targetting.
A drawback of jpeg2000 is the arithmetic coding.
why is this a drawback? doesn't it work fast enough on most modern hardware?
Arithmetic coding rocks !  I wonder why the lamers over at Intel haven't yet introduced 1-2 new instructions to speed it up ?
Because it is quite hard to implement, it is strongly patended (holders agreed to give free licensing for use in jpeg2000), and it is quite slow (problem for embedded devices running on dsp).
But regarding compression, it is a powerfull tool.
It takes only some thought, a few hours and 30-50 lines of code to implement your own form of bitwise arithmetic coding.
With bitwise coding, and a given predictor, you can encode any data in the (asymptotically) optimal way..
Arithmetic coding cannot be patented, only some of its implementations can. If someone tried to patent the concept, then the patent is not valid.
Yes, too bad it's a bit slow..  but with the current machines, I don't think that's a big deal anymore (except for video probably).
there are patent-free opensource implementations. like this.
and it seems that speed won't be an issue at the time when jpeg2000 will be widely adpoted
Actually, the great issue about speed concerns the predictor, not the coder itself.
Patents have to include both predictor and coder, thus with your own predictor, you should be safe.
Here's a fixed version of the link from X-Fixer:  http://datacompression.info/ArithmeticCoding.shtml
I do not think that you can implement a jpeg2000 encoder without falling into IBM patents. The fact that some implementation are free of use regarding the code copyright does not change anything regarding the patents.
(but IBM has agreed to offer free license agreement for use in compliant products).
Speed is still a problem for embedded devices, as is something needs more processing power to be done, it means reduced battery life.
But I think that we are really getting off-topic.
I think Intel's Indeo audio codec is wavelet-based.
Intel being Intel, there are probably a few dozen Indeo technical spec sheets and white papers buried deep in the bowels of their humongous web site.
Yes, range coding comes very close to arithmetic coding in compression, is much faster, and is believed to be patent free.  There are some papers and code here and here (this is actually the implementation that is used in Monkey's Audio).
Josh
sorry no link for a REAL objective test.
but i have test myself. but onyl with hi-res pcitures (1400x1400)
i i hav teste with 11 cd covers i have scanned by the following way
Scan in 600dpi (hardware)
cut it to 2800x2800
lite blurre effekte (to remove scale effect)
resample to 1400x1400
save as jpeg/jpeg2k at around 350kbytes
jp2k gives visual MUCH better quality here.
i did it in PSP 7.04
Sven Bent - Denmark
Intel sold all their audio and video codecs to Ligos.
http://www.ligos.com/indeo.htm
You won't find any info on Indeo at Intel's site, except links to Ligos' site.
And I believe you won't find any techinfo at Ligos' site either.
Regards;
Roberto.
yes, that's what I've actually meant. rangecoding is also used in La (I believe), PPMd (used in WinRAR and 7-Zip also) and (almost?) any other PPM or BWT archiver (e.g. bzip).
also, I've tested LureWave codec a while ago (not exactly a jpeg2k, but they are doing a jpeg2k codec now afaik). it gave a lossless compression somewhat worse than PNG, but lossy mode was really better than JPEG (for same filesizes on good quality) and the artifacts were less annoying ("loss of details" instead of "blockness" and "Gibbs effect").
if anyone is interested in real comparasion (and ready to provide test data) I guess I still can do it. though, real jpeg2k test would be more interesting
back on topic: I don't believe that Indeo uses wavelets, because it's rather old and generally... sucks.
Nothing really beats PNG in lossless RGB encoding og RGB pictures
There are not many other formats supporting more then 32bits color. or 8 bit alpha channels.
and the compression factor is the best for lossless.
Sven Bent - Denmark
Re: Wavelet-transform based audio codec
WebP does beat PNG as it's straight outta '90s so as its homepage. PNG uses zlib to compress which is very old. WebP uses more advanced techniques for compressing losslessly, it also beats JPEG in lossy compression (tech used for lossy compression is similar to the VP8 codec).
https://developers.google.com/speed/webp/docs/compression
well it was more than 15 years since that comment, so...
some ANC'd headphones + AutoEq-based impulse + Meier Crossfeed (30%)
Yeah, and if you use a better PNG encoder, it a file will be a bit smaller (still lossless).
BTW, JPEG XL is coming. And it seems very promising. It has lossless mode also.
(by the way, that part of that message which says that WebP beats JPEG in lossy mode is also incorrect, because lossy WebP is only possible to use with chroma subsampling, and with many images this never allows it to achieve visually lossless result at ANY quality parameter, while JPEG can scale to nearly lossless if you let it use enough bits)
