Topic: Brian Eno's "On Land" CD has a freqency cutoff (Read 4164 times) previous topic - next topic
Ok, I just bought (supposedly) the original master CD of Brian Eno's "On Land" off of amazon, and I am seeing a cutoff at about 20khz on the spectogram
Can anyone else who thinks their CD is original confirm this cutoff?
I can.
me too
In case you're interested...I have the remastered version of On Land and it does *not* appear to have the 20khz cutoff.
(i.e. the blue stuff goes all the way to the top of the graph.)
I wonder why you wonder. Many CDs have  this cutoff. It may be a result of resampling to 44.1kHz for the CD master. Many resamplers set a steep lowpass filter starting at ~20kHz.
Yeah, and that sort of constant lowpass is fairly uncommon for lossy codecs anyway.
I once poked around my CD collection and noticed that all CD's released before mid-90's had 20kHz cutoff.
Teemu
Ok, I didn't know that..
Would that mean whoever did the remastering decided to add extra noise to the audio?
In a way...it's most likely very low-level noise that got pushed up to the top of the audio band as a result of noise shaping employed when the 24-bit master got dithered down to 16 bits for CD release.
