Topic: HOW TO: synchronise your last.fm playback stats with foobar (Read 391121 times) previous topic - next topic
Reply #1125
this has been requested numerous times and i would consider it but it's simply not possible. last.fm only separate tracks by artist/title when it comes to fetching play counts back via their webservices.
Reply #1126
aaaah, what a shame, thanks for considering it though.
Reply #1127
Is it possible to count the playback stats for an artist or an album not only for a specific track?
Reply #1128
not with this script.
you could try this separate script which displays your last.fm artist/album/track stats for a few selected time periods like last 7 days, 1 month, 3month, overall etc....
http://marc2003.x10host.com/lastfm-charts
Reply #1129
Hey there again. I don't know what happened, but most playcounts aren't beng displaying now. Only very few tracks have them, and they seem to be totally random. I'm displaying them with $if2(%lastfm_playcount_db%,)... tried bringing them back with the heart (auto-correct disabled, just like in my profile), but nothing changed (I even didn't get the close foobar message at the end, in case that's weird).
Reply #1130
what does the console report? that always has something to say.
Reply #1131
Hello marc2003,
I've been using your awesome script for years now, but recently (I'm not sure when exactly though) I began experiencing API errors, so I thought, well maybe it's time to update the script. So I clicked on "Update script" and got an error "Last.fm Playcount Sync: HTTP error: 12029". So I thought, ok, maybe my script is old enough for updates not to work, so I googled the latest version of the script and tried to "update", I got a newer foo_customdb.dll, new marc2003 folder and a new script, restarted foobar, updated the script and had to reenter my Last.fm username & password. After that I still got the big red X, saying "User the right click to enter Last.fm password". So now every time I try to enter my password I get "Last.fm Playcount Sync: HTTP error: 12031". And "Update Script" still gets me a 12029.
As far as I understand both 12029 and 12031 would mean that I am not connected to the internets, but I surely am, because if I wasn't I wouldn't be able to write this.
Do you or anyone elso have any ideas what I could do to get the script working again?
Reply #1132
i don't remember anything unusual. i'm 99% sure it said that it succeeded. i removed the panel to reinstall it again one of these days and see how that works.
Reply #1133
can you access this page in internet explorer?
https://ws.audioscrobbler.com/2.0/
even if you normally use another browser, you need to use IE to test.
@firewater, well see how you get on. i can only help if you're more specific with the details.
Reply #1135
well it looks like you have some kind of proxy/firewall that is blocking access to last.fm? or maybe a DNS issue? if you open a command prompt, do you get any result for this command.
nslookup ws.audioscrobbler.com
also, are you on some kind of managed network or is it your home connection?
Reply #1136
That's my home connection.
Server:  ### - My Router Pseudo Domain
Address:  192.168.1.1
Address:  195.24.233.55
I have tried disabling firewall yesterday before writing the first post, so it shouldn't be a firewall problem.
Last.fm actually works, I can for example Right Click -> Last.FM -> Last.FM Love Track ... in foobar and it works, and if I type 195.24.233.55 in IE it also redirects to last.fm without problems, so it souldn't be a dns problem either.
I think it may be a problem with https because https://www.last.fm/ shows exactly the same error page in IE. On the other hand, https://google.com/ doesn't show me that error.
Well anyways, it seems to be my problem and not a problem of your script, so it probably would be better not to discuss it here.
Reply #1137
i'd have a look at the proxy settings in the internet explorer options then??
the last.fm command you're using on the context menu is provided by foo_softplaylists and that probably uses the foobar network settings found in the main preferences.
Reply #1138
Nope, proxy setting are fine and empty.
I actually asked around other people from all around the world to try and 4 of 4 guys coudn't open https://ws.audioscrobbler.com/2.0/ .
http://SSMaker.ru/1a606b11/ one of them even made a screenshot.
So it seems to be a last.fm issue in the end, isn't it?
Reply #1139
i just realised that page is not good to test with. it works on the connection i was using earlier but now i'm somewhere else, i get the same 400 bad request error - however, my last.fm script is still working here.
stick this in a fresh panel and it should open a proper page on the webservices using https.
// ==PREPROCESSOR==
// @import "%fb2k_profile_path%marc2003\common8.js"
// ==/PREPROCESSOR==
var p = new panel("test");
var l = new lastfm();
var artist = "Katy Perry";
p.run("iexplore https://ws.audioscrobbler.com/2.0/?api_key=" + l.api_key + "&method=artist.getSimilar&artist=" + encodeURIComponent(artist));
Reply #1140
It opens IE with the same goddamn error. However if I copy the same link to Firefox it gives me a proper XML response.
Reply #1141
i just noticed you mentioned the "Update script" feature not working either. that actually fetches this file over https as well. i bet it works in firefox but not IE.
https://dl.dropboxusercontent.com/u/2280132...2003/common8.js
it looks like you have https issues i can't help you with.
Reply #1142
Yep, it works in FF but not in IE. Strange thing is that all the other people I asked had the same stupid https issues.
Well, thanks for trying anyways. I'll let you people know if I get it fixed.
Reply #1143
Me again! It seems I got it to work!
First I added https://ws.audioscrobbler.com/ and https://dl.dropboxusercontent.com/ to IE white-list. It seems it did nothing.
Next I turned on TLS 1.0 in Advanced IE settings. It seems it did nothing.
Lastly I checked my PC's local time and it seemed to be a couple of seconds in the future! I ran NTP sync and voila now your script works! I could enter my password and auth with last.fm successfully! Loving/unloving tracks works too and playcounts are now updatet as they should.
However if I uncheck TLS 1.0 or remove ws.audioscrobbler from white-list it doesn't work anymore even if the time is right.
And if I try to "Update script" via context-menu I now get this: Last.fm Playcount Sync: HTTP error: -2146869244 . Well, whatever, at least everything else seems to work.
One more thing I wanted to ask. The Heart-pic is now way too large and is cut in half. In the old version I used I remember there was an option to change the image, or the image size, i can't remember the exact wording. But now even if I replace this big image with the old one it's upscaled. is there a way to make it smaller?
Reply #1144
read the text at the start of the panel??
//function takes 3 values: x, y, size. see on_size function if you want to update these relative to panel width/height
var ps = new playcount_sync(3, 0, 32);
Reply #1145
Sorry, didn't read the script, thought it would be changeable via context-menu. Many thanks for your support, you're awesome.
Reply #1146
i hope you figured out how to get rid of that white background in your screenshot. you can use the menu for that.
Reply #1147
Yep, I saw the setting, but prefer it that way though. Thanks.
Reply #1148
Damn it, it doesn't work!!!
Last.fm Playcount Sync: Playcount: completed page 180 of 180
Last.fm Playcount Sync: There were no errors reported.
Using %lastfm_playcount_db% to display it on JSPlaylist... get mostly ? and then sometimes one track shows amount, but pretty much almost none of them do...
More info:
+ I pressed Update Script and got "Download succesful. Restart foobar now?" even though I just installed it again with the latest version (and again, no blue command prompt appeared??? I removed the following files to reinstall: marc2003 folder, foo_customdb.dll, WSH data folder, WSH settings folder.
+ Loving a track still works.
+ I tried field mapping to %artist% and %album artist%
+ Console displays fine alll the way through [/s]
I have two Foobar folders (one is a backup, as I'm always changing stuff and messing it up) and on the backup one I tried to fetch playcounts one more time just to see if it worked there for some magical reason even though it's the same install and when the console finishes reporting I get the blue command prompt asking to close foobar!!! And now it works!!! So my guess is, I mistakenly updated the panel on the backup instead of my regular foobar and that's why it didn't get fixed with the reinstall... have no idea what caused it though.
Reply #1149
with 2 installs, you can copy the file named customdb_sqlite.db from folder to folder (while foobar is closed). obviously only one of them will get updated as you listen so it's up to you to keep them in sync.
