Topic: FLAC & Tagging (Read 3370 times) previous topic - next topic
FLAC & Tagging
I ripped a lot of albums to FLAC with EAC using --tag="Track"="%n".
It should have been --tag="Tracknumber"="%n".
How can I batch rename this tag in all my FLACs?
Just one other question: I want to convert FLACs to MP3, and I've been using Speek's All2Lame. How do I get it to write ID3V2 tags as well as ID3V1?
FLAC & Tagging
Notepad/Edit/Replace...
FLAC & Tagging
I don't know if you were serious or not  but it doesn't work. I edited it with TextPad and it breaks the FLAC file.
Surely there's something that can remove tags and add tags?
FLAC & Tagging
And no, you can't do it in notepad. You could do it in a hex editor but you would have to know what you are doing. But that's getting OT, just follow the links.
FLAC & Tagging
I'm sure when it was suggested to edit the tags with notepad, the person meant to export the vorbis comments first (using --export-vc-to=file), do the editing, then import the comments back into the file (using --import-vc-from=file).  This will work, although you'll have to do it for each file individually, and if you have many files, this certainly won't be very efficient.
FLAC & Tagging
you may be able to use the masstagger in foobar for this.  i don't have flac files so no clue whether it will work.
