Topic: Issues with ASX streams (Read 29302 times) previous topic - next topic
That's not a valid UTF-8, I guess.
BBC asx streams are not working, eg
http://www.bbc.co.uk/radio/listen/live/r4.asx
or
http://www.bbc.co.uk/radio/listen/live/r5lsp.asx
Errors :-
Unable to open item for playback (IWMReader::Open failed : Unknown error code (0xC00D0026)):
"http://www.bbc.co.uk/radio/listen/live/r4.asx"
"http://www.bbc.co.uk/radio/listen/live/r5lsp.asx"
Can you confirm if these are also broken asx or if this is a bug, please?
They work in WMP/VLC.
If a stream works without errors in common players, it should be considered as a bug if it doesn't work in foobar. These are web resources, Postel's law applies (within limits). This is utterly annoying for the developers, but the feature is much less useful if it only works on perfectly valid asx files.
BBC asx streams are not working...
Problem triggered by server not returning content-length, fixed for the next update, thanks for reporting.
You can download the ASX file using your web browser, save it then open the saved copy in foobar2000.
"http://tvradio.ert.gr/radio/liveradio/asx/erasport.asx"
In WMP works with no problems
Works fine here in beta2a.
Thanks for the update.
There is one problem with recommending removing support for the mslive plugin. Foobar2000 only works on this stream with the mslive plugin:
http://ordorica.org/tune.pl?station=kfi640
The stream is in asx format (wma/mms:). The link is to my script that generates a stream for ClearChannel websites (they want you to use flash).
For now I will just continue to use the mslive plugin.
I added the content type to my script:
Content-type: audio/x-ms-wma
But it made no difference for foobar.
As far as changing the ampersands, I just use a perl script to take clear channel's randomly generated strings and pass it as a simple asx file.
I guess I can regex replace their generated content.. but it works fine with other players and mslive.
I'll do it later, hopefully with a simple regex.
From http://en.wikipedia.org/wiki/Advanced_Stream_Redirector:
ASX files have MIME type video/x-ms-asf (as do ASF files).
See also: http://support.microsoft.com/kb/288102
Thanks for the MS streaming support! As we know from experience (foo_input_mslive) this is a hard task, often due to not standard compliant xml files. From the philosophy of fb2k I know you won't workaround things. Anyway, this one also doesn't work, I think the xml is alright:
http://radiodresden.stream.green.ch/radiodresden.wax
contents:
<ASX version = "3.0">
<title>Radio Dresden</title>
<Entry>
    <Ref href = "mms://stream.green.ch/RadioDresden"/>
</Entry>
</ASX>
fb2k output:
Unable to open item for playback (Unsupported file format):
"http://radiodresden.stream.green.ch/radiodresden.wax"
Peter, are you thinking about Realaudio support? Unfortunately there's quite a few real-stuff around, BBC for instance...
Fixed, thanks for reporting.
Temporary workaround: download the .WAX file, rename to .ASX, open.
Tags for MMS streams are not displayed. mslive (or WMP): displayed; foobar: not displayed. Should it be that way?
What kind of tags and not displayed where? Any specific stations where I can see this behavior?
Metadata in mms-streamed wma. Unfortunately, its our local radio, so its impossible for me to give its url to you (only screenshots - it is not really helpful, is it?).
But for example mms://fr1.101.ru/v1_1_128 (mslive at least shows NRJ as artist/title like WMP does, foobar shows nothing). And those on local server in mslive info has that string:
<HASSCRIPT> : Yes
P.S. Sorry, if I'm being dense or non-clearly understandable - my English is not too good.
Have no idea if this is helpful.
Plays for me while showing:
NRJ as %Artist%
NRJ as %Title%.
Current beta
OS: XP
terry [in dallas, tx.]
Shows artist/title as "NRJ" and copyright as "NRJ FM" here.
NRJ as %Artist%
NRJ as %Title%.
Current beta
OS: XP
it doesn't show anything for me in foobar2000 v1.0 beta 2a, works in WMP...
OS: windows 7 64bit
list of components:
Core (2009-11-27 18:56:00)
foobar2000 core 1.0 beta 2a
foo_abx.dll (2009-06-07 12:25:26)
ABX Comparator 1.3.4
foo_albumlist.dll (2009-11-27 16:59:38)
Album List 4.4
foo_audioscrobbler.dll (2008-05-13 15:36:16)
Audioscrobbler 2.3.1
foo_binpack.dll (2008-10-25 16:42:42)
BinPack Playlist Generator 1.1.0
foo_bitcompare.dll (2008-12-05 15:08:02)
Binary Comparator 1.2
foo_burninate.dll (2009-06-24 19:14:28)
Audio CD Writer 3.0.1
foo_cdda.dll (2009-11-27 16:59:28)
CD Audio Decoder 3.0
foo_chacon.dll (2008-10-05 14:28:50)
Chacon 0.0.1
foo_chronflow.dll (2008-04-14 00:16:00)
Chronial's Coverflow 0.3.0
foo_converter.dll (2009-11-27 16:59:22)
Converter 1.4
foo_discogs.dll (2009-11-20 20:07:46)
Discogs Tagger 1.22
foo_dockable_panels.dll (2007-03-28 08:19:02)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dsp_std.dll (2009-11-27 16:59:36)
Standard DSP Array 1.0
foo_facets.dll (2008-04-09 19:29:14)
Facets 2008-02-25
foo_fileops.dll (2009-11-27 16:58:42)
File Operations 2.1.2
foo_freedb2.dll (2009-11-27 16:58:44)
freedb Tagger 0.6.2
foo_grabber_python.dll (2009-02-06 12:40:15)
Lyrics Grabber Dances With Python 0.1.12 Alpha
foo_imgburner.dll (2008-10-30 16:18:15)
ImgBurner 0.3.1
foo_infospect.dll (2008-02-01 20:02:58)
Infospect 1.0.3
foo_input_alac.dll (2009-03-22 14:15:46)
ALAC Decoder 1.0.3
foo_input_monkey.dll (2009-05-01 13:40:52)
Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2009-11-27 16:59:22)
Standard Input Array 1.0
foo_jesus.dll (2009-11-20 22:41:02)
Autosave & Autobackup 6
foo_lastfm_radio.dll (2009-02-25 21:05:24)
Last.fm Radio 0.5.6b
foo_lyricsgrabber.dll (2009-02-07 06:12:47)
Lyrics Grabber 0.3.0.7 Alpha
foo_masstag.dll (2009-09-18 09:01:36)
Masstagger 1.8.4
foo_musicbrainz.dll (2009-04-10 20:27:28)
MusicBrainz Tagger 0.2
foo_navigator.dll (2007-08-04 11:36:46)
Navigator 0.63
foo_out_wasapi.dll (2009-05-19 22:45:18)
WASAPI output support 2.1
foo_playcount.dll (2009-04-29 19:09:32)
Playback Statistics 2.1.9
foo_playlist_manager.dll (2007-01-22 12:05:12)
Playlist Manager 1.0.2
foo_playlist_playback_attributes.dll (2009-08-01 13:20:06)
Playlist Playback Attributes 0.1.0 [Aug  1 2009 - 15:15:00]
foo_queuecontents.dll (2009-07-27 10:47:56)
Queue Contents Editor 0.1
foo_quicktag.dll (2008-05-01 19:39:02)
Quick Tagger 1.0.1
foo_random.dll (2009-06-30 22:06:58)
Randomized Playlist Entry 1.3.0
foo_rgscan.dll (2009-11-27 16:59:10)
ReplayGain Scanner 2.0.9
foo_run.dll (2009-06-07 14:15:18)
Run services 0.3.7
foo_scrobblecharts.dll (2007-03-31 16:36:48)
Last.fm Chart Player 0.2.3
foo_sendtodevice.dll (2008-03-14 18:37:38)
Send to Device 1.1.2 [Nov 28 2007 - 10:13:31]
foo_skip.dll (2009-01-03 17:04:18)
Skip Track 0.4
foo_softplaylists.dll (2009-11-30 23:00:00)
Soft Playlists 2009-12-01
foo_stopaftercuralbum.dll (2009-06-01 08:50:42)
foo_stopaftercuralbum 0.2
foo_textdisplay.dll (2008-07-08 18:45:26)
Text Display UI Element 1.0 RC 3
foo_texttools.dll (2009-01-17 15:00:52)
Text Tools 1.0.2
foo_ui_columns.dll (2009-08-30 15:21:36)
Columns UI 0.3.8.0
foo_ui_std.dll (2009-11-27 16:59:48)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-06-13 22:49:19)
Album list panel 0.3.5
foo_uie_biography.dll (2009-11-26 00:26:10)
Biography View 0.3.4.1
foo_uie_console.dll (2009-08-29 16:06:24)
Console panel 0.4
foo_uie_elplaylist.dll (2009-06-05 21:01:32)
ELPlaylist 0.6.5.3.3(beta)
foo_uie_graphical_browser.dll (2008-04-19 19:37:53)
Graphical Browser rev015
foo_uie_library_tree.dll (2009-07-25 01:18:14)
Library Tree 0.3.2.5b
foo_uie_lyrics.dll (2008-12-12 09:39:20)
Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_panel_splitter.dll (2009-11-26 01:03:32)
Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_playlists_dropdown.dll (2009-09-23 23:44:46)
Playlists Dropdown 0.7.6
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
foo_uie_typefind.dll (2007-10-22 21:30:44)
Typefind 0.2 beta 2
foo_uie_wsh_panel_mod.dll (2009-11-13 12:15:35)
WSH Panel Mod 1.1.11
foo_unpack.dll (2009-11-27 16:58:28)
RAR reader 1.3
ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2009-10-05 10:39:20)
File Integrity Verifier 1.1
foo_vis_shpeck.dll (2009-09-24 18:07:44)
Shpeck - Winamp vis plugins wrapper 0.3.6
foo_w7shell.dll (2009-09-05 01:22:36)
Windows 7 integration 0.2.8.1
foo_whatsnew.dll (2008-08-30 14:45:00)
Feature Watcher 1.0.6
foo_wlm.dll (2009-06-21 20:30:22)
Windows Live Messenger Notifier 1.0.8
