Topic: USing metadb_handle_ptr (Read 2536 times) previous topic - next topic
Hi all,
I'm trying to get the path from every file selected in the current playlist.
So far, I managed to add a context menu item :
DECLARE_CONTEXT_MENU_ITEM (foosync_SendToUsb_menuitem,"Send to USB", "FooSync", send_to_usb, myguid, "Sends the selection to foo_sync's usb drive")
and using both visual studio debug and foosion's doxygen, I wrote this code in the callback function :
void send_to_usb( const pfc::list_base_const_t<metadb_handle_ptr> & p_data )
    const char* info;
    for (t_size i=0;i<p_data.get_count();i++)
        file_info_impl myInfo;
        p_data[i]->get_info(myInfo);
        for (t_size j=0;j<myInfo.info_get_count();j++)
            info=myInfo.info_enum_name(j);
  return;
Now the first part work, i.e, if I select some songs in my plalist, right click, then click on FooSync then Send to USB, the code goes to my function  send_to_usb.
But now I'm kind of stuck because:
- the debugger refuses to break inside the loop (that loop : for (t_size i=0;i<p_data.get_count();i++) {...})
- it breaks at the last curly bracket, with i having a really weird value, as if it was uninitialized.
I'm probably doing something wrong here. Actually I'm not sure of what I'm doing at all...
As I understand so far, the p_data parameter contains a list of metadb_handle_ptr. I assumed that I have one metadb_handle_ptr per selected item in the list, is this right ?
Now, if I try to look (in the debugger) what's the value of p_data.get_count(), it tells me that the member function doesn't exist !!! Which is weird because of course it does .
Sorry if it's a bit confusing, but I'm myself a bit confused here.
My goal here is to get the path and file name of every selected entry in the playlist.
Any help would be much appreciated.
D.
Yes.
(...) p_data.get_count(), it tells me that the member function doesn't exist
Probably because it's declared as pure virtual in the pfc::list_base_const_t interface class.
Use metadb_handle::get_path() then. The filename can be extracted with pfc::string_filename_ext.
By the way, metadb_handle::get_info_locked() should be preferred to avoid copying data around.
Also, make sure to check return values, info might not yet be known.
Awesome ! Thanks again ! The trick was to use get_size() instaed of get_count()
I publish the corrected code (without the checks) :
{   const char* path;
    unsigned int i;
    for (i=0;i<p_data.get_size();i++)
        path=p_data[i]->get_path();
  return;
I'll implement some checks, as you suggested.
Moderation: Removed useless full quote of the preceding post.
Considering that get_size() is implemented as the following, I kind of doubt that that was the cause. Remember, just because it appears to not be broken, that doesn't mean it is remotely correct.
inline t_size get_size() const {return get_count();}
Mmmh you're right. And it's probably not the only mistake I made in my code. But at least the component works, on my computer.
If some one wants to use it :
http://www.hydrogenaudio.org/forums/index....=76277&st=0
(source is included, and distributed under gpl, so if you want, feel free to modify it or improve it)
