Topic: Playlist Search is broken... (Read 1934 times) previous topic - next topic
when i use tab or $char(9) repeatedly in my display list string, it break the playlist search feature.
Here's a workaround...
Since search only searches the first column, you can add all the fields you want to be searched, but make them invisible.  If you're using columns with $char(9), it won't affect the relative width of the column.
Here's what I did...
//playlist bg color normally and selection color when selected makes it invisible
$puts(INVIS,FFE4CA|808080)
then make the columns...ex. the first column only shows the artist in the playlist, but search will search and show artist - title (album).
$num(%_playlist_number%,4)
808080|FFFFFF| $caps2(%artist%) $get(INVIS) - %title% '('%album%')'$repeat($char(9),3)
808080|FFFFFF| $if(%title%,$caps2(%title%),%_filename%)$repeat($char(9),3)
808080|FFFFFF| $caps2(%album%)$repeat($char(9),3)
808080|FFFFFF| $if(%date%,$num(%date%,4),$get(INVIS)'0000') 808080|FFFFFF| $if(%tracknumber%,$num(%tracknumber%,2),$get(INVIS)'00') 808080|FFFFFF| [%genre%]$repeat($char(9),2)
808080|FFFFFF|$if($greater($len(%_length%),4),%_length%,$get(INVIS)'0'%_length%)
