Topic: WMA files not playing (Read 4524 times) previous topic - next topic
The player won't play SOME of the WMA files. I get this error message:
Unable to open item for playback (IWMSyncReader::OpenStream failed : Unknown error code (0xC00D0BBD)):
Other players (such as WMP) can play it. Does anyone know why this might be? On a side note this music is something I ripped, using WMP, from a CD I bought. Not so sure if that's relevant but... yeah...
That means your WMA files are DRM protected, which is not supported by foobar2000.
You need to re-rip them with copy protection disabled.
Oh, thank you very much ^^
im getting the same error here for 4 or 5 albums with no DRM .. (well lets say drm was removed:)
Location not parsable: "F:\A_Z\Joy Division\Substance\Transmission.wma", reason: IWMSyncReader::OpenStream failed : Playback of DRM-protected files is not supported (0xC00D0BBD)
Apparently it wasn't, at least not completely.
Anyway, it's not some foobar2000's excuse, that error code comes from the system WMA decoder it uses.
