Topic: Multiple "Facets"? (Read 1907 times) previous topic - next topic
Multiple "Facets"?
Hey all....Have been using Foobar and facets for a while now, but thanks to my tiny screen resolution I can't have all three columns up at once and display the full length of album/artist names.
So I decided to make three tabs, first has Genre, second Artist, third album.
The problem I have is if i select an artist and go to the album tab it doesn't change, and still displays all the albums in my library. Is there a way so that it will change in each tab?
Thanks in advance
Multiple "Facets"?
Each facet element works as "stand-alone", so you won't be able to filter multiple facets that are located in different tabs.
Multiple "Facets"?
You can configure facets to show each "window" horizontally instead of vertical - Maybe that will help?
