Topic: Using title formatting (precompiling scripts, console output) (Read 3789 times) previous topic - next topic
Hello,
more questions.
Can't seem to understand how title formatting is done.
Here's my attempt which I made from various posts I found on this forum.
My code:
#include "SDK\foobar2000.h"
DECLARE_COMPONENT_VERSION("foo_test","1.777","blah")
const GUID myguid = { 0x000F0001, 0x3300, 0x3452, { 0x00, 0x00, 0x12, 0x10, 0xAF, 0x00, 0x45, 0xFF } };
void context_click( const pfc::list_base_const_t<metadb_handle_ptr> & p_data )
    service_ptr_t<titleformat_object> g_to_global;
    service_ptr_t<titleformat_compiler> compiler;
    compiler->compile_safe(g_to_global,"%artist%");
    for (int i=0;i<p_data.get_count();i++){
        pfc::string8 out;
        p_data.get_item(i)->format_title(NULL,out,compiler,NULL);
        console::print(out.get_ptr());
    return;
class entry: public initquit
public:
    virtual void on_init()
        console::print("plugin started");
    virtual void on_quit(){}
DECLARE_CONTEXT_MENU_ITEM (item_test,
                            "Copy artist name",
                            "foo_test",
                            context_click,
                            myguid,
                            "Copy artists")
static initquit_factory_t<entry> myinstance;
I just like listening to music
[font= "Courier New"]static_api_ptr_t<titleformat_compiler> compiler;[/font]
I actually tried that first, but the compiler throws me:
error C2664: 'metadb_handle::format_title' : cannot convert parameter 3 from 'static_api_ptr_t<t_interface>' to 'const service_ptr_t<T> &'
So I thought I needed to use the service_ptr_t template instead.
You need to pass the compiled script to metadb_handle::format_title(), not the compiler.
Also, it is recommendable to pre-allocate and reuse the output string.
titleformat_object::ptr script;
static_api_ptr_t<titleformat_compiler>()->compile_safe(script, "%artist%");
pfc::string8_fast_aggressive buffer;
buffer.prealloc(128);
console::formatter out;
for (t_size i = 0, n = p_data.get_count(); i < n; ++i) {
    if (p_data[i]->format_title(NULL, buffer, script, NULL)) {
        out << buffer.get_ptr() << "\n";
Aah, makes sense.
