Topic: WMP Tag Plus - MPEG4, Vorbis and FLAC metadata support for WMP (Read 538130 times) previous topic - next topic
Reply #325
What's the exact text of the error message that is shown when WMP is closed?
Where is the wmplayer.exe file located on your system? (you can perform a search if you aren't sure)
Please open the Start Menu, type regedit in the Search field and press Enter. In the Registry Editor, navigate to HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\App Paths\wmplayer.exe. What is the value of the (Default) entry there?
Reply #326
"Setup was unable to find Windows Media Player on this computer. Please make sure that at least version 11 of Windows Media Player is installed, this is required to use WMP Tag Plus.
C:\Program Files (x86)\Windows Media Player
The entry wmplayer.exe does not exist in that part of the registry.
Reply #327
Hmm, that entry should definitely be there when you have WMP installed. Did you perhaps use some kind of registry cleaner?
To re-add the entry, copy/paste the following into Notepad, save it as a WMP.reg file, and double-click this file to add it to the registry. Then launch WMP Tag Plus setup again - it should now find WMP and continue with the rest of the installation.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\App Paths\wmplayer.exe]
@=hex(2):25,00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,46,00,69,00,6c,00,65,\
  00,73,00,28,00,78,00,38,00,36,00,29,00,25,00,5c,00,57,00,69,00,6e,00,64,00,\
  6f,00,77,00,73,00,20,00,4d,00,65,00,64,00,69,00,61,00,20,00,50,00,6c,00,61,\
  00,79,00,65,00,72,00,5c,00,77,00,6d,00,70,00,6c,00,61,00,79,00,65,00,72,00,\
  2e,00,65,00,78,00,65,00,00,00
"Path"=hex(2):25,00,50,00,72,00,6f,00,67,00,72,00,61,00,6d,00,46,00,69,00,6c,\
  00,65,00,73,00,28,00,78,00,38,00,36,00,29,00,25,00,5c,00,57,00,69,00,6e,00,\
  64,00,6f,00,77,00,73,00,20,00,4d,00,65,00,64,00,69,00,61,00,20,00,50,00,6c,\
  00,61,00,79,00,65,00,72,00,00,00
Reply #328
I do use a registry cleaner - clearly that key is not required for WMP as it's always worked just fine - but that entry fixed the install - seems to have worked just fine. Thanks very much for your help!
Reply #329
No problem
This once again shows that registry cleaners usually cause more harm than good. Besides that, there's really no need to 'clean' the registry.
Reply #330
So can I just confirm there is still no fix for getting WMP/WMC to recognise .M4A files with ALAC audio as music and put them in the library?
And the only known fix at the moment is to rename all .M4A files containing ALAC to .MP4 (thus creating another problem that Windows Explorer recognises these files as MPEG-4 Videos?
Looking in the registry I found HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Multimedia\WMPlayer\Extensions\.alac
So I renamed an album's .M4A files to .alac
The files appeared in the music library and played. The track info was there, the album art was there, but the album info was not.
Could this be an option?
Reply #331
There already is a fix, although still in beta:
This is a known issue with WMP 12: lossless M4A files are always added to Other media instead of Music. Fortunately, I have recently been able to come up with a fix for this. The fix is included in a new beta version of WMP Tag Plus (download here).
After installing the beta, existing lossless M4A files in Other media will need to be removed from the library, and re-added (through Tools - Advanced - Restore deleted library items). When re-adding, they should now appear in Music instead.
Please give the fix a try, and let me know if it works alright. Apart from the fix, nothing has been changed in this beta version.
Reply #332
Tim you're THE MAN
Thank you.
I've uninstalled 1.2 and updated to 1.3 beta. All working perfectly.
All I need to do now is hope there will soon be a way to get WMC to play audio to a non-default audio device...
Reply #333
Hello Tim, hello everyone on this forum. Tim, this is an old question/request I'm raising : is there any chance we get support for musepack (mpc) files in WMP Tag Plus v2 I guess? Again, thanks for all the great work and the efforts
Reply #334
TagLib, the tagging library that WMP Tag Plus uses, now does support both Monkey's Audio and Musepack, which makes it possible to have a single handler for APE tags. But unfortunately, Musepack support won't make it in the upcoming 2.0 release.
Reply #335
Yes indeed the Taglib's developper site says
"Currently it supports both ID3v1 and ID3v2 for MP3 files, Ogg Vorbis comments and ID3 tags and Vorbis comments in FLAC, MPC, Speex, WavPack TrueAudio, WAV, AIFF, MP4 and ASF files. "
Well I guess I really have to learn to code now  Anyway, thanks for the good work, at least I have tags for my flacs
Reply #336
New user here, 1.3beta2, Windows 7 x64, WMP12 32bit.  I see that using WMP to create its media library works well, and that library is then used by Media Center x64, so this is great.
Regarding 64 bit support, I hope you can port to it, as most everyone I know uses Win7 x64 now, and I wouldn't count on 32 bit WMP lasting too long.  I use other programs for tag editing so no problem now.
Thank you for your work!
Reply #337
I could actually port WMP Tag Plus to 64-bit but I just don't see why I should put all the effort into doing that. Especially not with limited time and much nicer features to add. Since the 32-bit version of WMP is still included with Windows 7 x64 and even the default, WMP Tag Plus still works fine there.
Reply #338
Because many people are using win (7) x64 & WMC which is, as you know, x64 based (WMP x64) and if someone opens first the music library in WMC the tags are "gone" even if you open after that in the x86 WMP (you have to restore media library in WMP x86) .
Most of the users this days don't even bother with WMP and go directly to WMC (or foobar2000  )
P.S. Also taking in consideration how many people have asked for a x64 version ( from those which bother to  post here) I really think it's a "big"  need for the x64 version
Reply #339
Restoring the media library is overkill in this case - simply deleting the songs without tags from the library and then adding them again will give you tags in the library. WMP Tag Plus 2.0 will even be able to scan the library for songs without tags and re-add them for you. This scan will happen automatically when WMP is first launched after the plug-in's installation, but can also be run manually later on.
I know that there are issues with x64 Media Center because of lacking 64-bit support, but a 32-bit version of the plug-in is what you'll have to do with for now.
Reply #340
Hi all,
Might be a bit premature, but it seems WMP Tag Plus doesn't work in Windows 8 CP.
Very strange because it looks like WMP and WMC have not changed much but I guess you never know with MS.
WMP version is 12.0.8250.0.
Tried all the usual tricks but there is no tag data for me.
I used it in Windows 7 x86 and x64 in the past with no problems!
Anyone else tried Windows 8?
Thanks, Elton.
Reply #341
Hi all,
Thanks, Elton.
Quick update. Just tried WMPTagSupportExtender 1.4 which I stopped using ages ago because WMP Tag Plus is better, and it works. Weird.
Reply #342
Thanks for reporting this. I haven't had the chance yet to test WMP Tag Plus on Windows 8 CP, but I hope to do so this weekend or later next week. I will report my findings then.
Not very surprising as WMP Tag Support Extender only does some shallow hooking into WMP to provide tagging support. For making things like setting the duration possible, WMP Tag Plus needs to hook much deeper with the drawback that it gets more version dependent.
Reply #343
Hi Tim. Thanks for your reply.
OK, I can see this in the way WMP Tag Plus has much tighter integration. I think WMC is the best user experience for a HTPC and FLAC is critical for me to have an enjoyable music experience (die MP3, die!). So your plugin has made this possible in a seamless way. BTW, 8MC is no different to 7MC yet but it's still nice to play with Win8. Thanks for the great plugin.
I just made a donation because we all appreciate your time in developing such an excellent free tool!
Cheers, Elton.
Reply #344
Thanks for the donation Elton
Reply #345
I have just tried WMP Tag Plus on Windows 8 CP and can confirm that it's not yet compatible: an error message about a missing core component is displayed at WMP startup and there's no extra tag support at all. The final 2.0 version will be compatible, provided that this doesn't require too much work.
Reply #346
what time will the final ver 2.0 be released? I am using Win 8 CP and looking forward to your nice work in the next release. WMPPlus 2.1 can not work well without WMP Tag Plus (context to edit tag for flac file disappear)
Sorry for my bad english
Reply #347
It will be released when it's done
By the way, Windows Media Player Plus! will also require a new release to make it compatible with Window 8.
Reply #348
Thanks Tim, looking forward to it.
WMP Plus is not so critical because there are other ways to edit metadata in FLAC.
Reply #349
Just wanted to share that only the v1.3beta2 produces the error when starting WMP, v1.2 does not. But the extra tag support did not work at first.
The fix was to either manually set the files to open using WMP (through the file properties dialog) or install taglib property handler v0.3 - these were the two things I did before noticing that WMP now recognizes (at least) flac files.
