Topic: Basic questions on service instantiation and templates (Read 4787 times) previous topic - next topic
Hi, I just started with component developing and I have some  questions/problems.
I decided I would try to make a plugin that would simply spam the console, but I don't understand how I should instance/tell foobar that it should call my class that inherits from main_thread_callback. My code looks like this:
#include "SDK\foobar2000.h"
#pragma comment (lib,"shared.lib")
DECLARE_COMPONENT_VERSION("foo_sample","7.77","Yup, working!");
class Foo_sample: public main_thread_callback
public:
    virtual void callback_run();
void Foo_sample::callback_run()
    console::print("Hey?");
class iq : public initquit {
    virtual void on_init()
        console::print("foo_sample says hello!");
static initquit_factory_t<iq> inst_iq;
Next question is how I can use inst_iq to do things.
I just like listening to music
You need to use the main_thread_callback_manager service through a static_api_ptr_t to add_callback your main_thread_callback implementation.
service_ptr_t<main_thread_callback> p = new service_impl_t<Foo_sample>;
static_api_ptr_t<main_thread_callback_manager>()->add_callback(p);
Thanks, I'll come back with more questions later since I find all this template and service stuff confusing (to be fair I haven't worked very much with templates, should maybe give myself a crash course a bit further in the subject).
For example, how do I know if to create a static api pointer or a service pointer?
From the SDK documentation (just the brief comment):
Helper template used to easily access core services.
Autopointer class to be used with all services. Manages reference counter calls behind-the-scenes.
