Topic: Graphical bug with 0.58 (Read 3521 times) previous topic - next topic
If I try to resize INFO tag windows, there's a big bug :
[span style='font-size:14pt;line-height:100%']BEFORE RESIZE : [/span]
[span style='font-size:14pt;line-height:100%']AFTER RESIZE : [/span]
Checked with 0.57 : no problem. I'm on 98SE - sorry for colors.
Can someone reproduce it ? I've just reinstall the OS yesterday.
I get the same problem, also on win98SE.  Probably it would be easiest just to not make the window resizable.
stripe/ben
Doesn't occur on Win2k.
I need want this resizing feature. It works with the 57 first versions of foobar ; I don't see any reason to remove it just because a little coding or compiling error.
I need to resize this window if I want to see a limpid disposition of some informations (opera mostly) :
[span style='font-size:14pt;line-height:100%']BEFORE RESIZE[/span]
fixed in 0.58b
We are the bork. Your software bugs will be added to our own. Resistance is futile.
I thank you.
