Topic: RIAA EQ comparation between Audacity EQ (FIR) w/ RIAA preset and 2nd o (Read 15088 times) previous topic - next topic
Audacity 1.2.6
Normalization and Amplification done using Audacity features.
24-bit/48kHz (wma) samples:
1 - no RIAA - [attachment=5340:1.wma]
2 - Audacity EQ w/ RIAA preset - [attachment=5341:2.wma]
3 - Audacity EQ w/ RIAA preset + Normalization (< -3.0 dB) - [attachment=5342:3.wma]
4 - Audacity EQ w/ RIAA preset + Amplifying (< -0.0 dB) - [attachment=5343:4.wma]
5 - IIR filter (< -1.0 dB) - [attachment=5344:5.wma]
6 - IIR filter (< -3.0 dB) - [attachment=5345:6.wma]
Examples/instructions to make IIR type RIAA EQ implementation can be found @ http://jiiteepee.fortunecity.com/riaafilter/index.html
Juha
Meanwhile, 3 years later, in a galaxy far, far away:
The Audacity samples sound wrong to me - too much treble and not enough bass.  I have done some experiments of my own which support this.  Maybe this is fixed in Audacity 2.x
How did you calculate your IIR filter parameters please?
I am an independent software developer (VinylStudio) based in UK
I have not been here for long so haven't seen this query.
IIR filter coefficients came from Robert Orban http://www.dsprelated.com/showmessage/73300/3.php and Scott Wurcer.
My new RIAA pages are here - http://jiiteepee.tripod.com/riaa.html
Juha
OK, thank you.
Yes, they have improved the preset in 2.x.
Here are new files for my comparison (All recorded using ESI DuaFire and 24/44.1 (files 1-3 through fixed flat phono input, 4 through line input)):
[attachment=7856:01-01-Fl...410_0041.mp3]
[attachment=7857:02-02-ES...410_0041.mp3]
[attachment=7858:03-03-Fl...410_0041.mp3]
[attachment=7859:04-04-Pr...410_0041.mp3]
Here's the final comparison:
[attachment=7860:01_CD_rip.mp3]
[attachment=7861:03_2nd_o..._IIR_VST.mp3]
[attachment=7862:04_FIR_E...Audacity.mp3]
[attachment=7863:05_TerraTec_iVinyl.mp3]
Steep HP @20Hz was used for all 4 samples.
  Yes, they have improved the preset in 2.x.  Here are new files for my comparison (All recorded using ESI DuaFire and 24/44.1 (files 1-3 through fixed flat phono input, 4 through line input)):  [attachment=7856:01-01-Fl...410_0041.mp3]  [attachment=7857:02-02-ES...410_0041.mp3]  [attachment=7858:03-03-Fl...410_0041.mp3]  [attachment=7859:04-04-Pr...410_0041.mp3]
Additionally one file for comparisons, which is done using convolution w/ RIAA impulse response data (source file is the same as for the others).
[attachment=8194:05-05-Fl...315_1148.mp3]
Forgot to link the IR file(s) used in that sample file #05-05
