Topic: can't jump ahead (time) with .57 (Read 3044 times) previous topic - next topic
I get massive static or a freeze, instead...!
thanks, i advance, for the help.
___
I notice that playing with the waveout buffer has an effect: decreasing the buffer reduces the static....
win98
ap2496
as for SHN... foo_shn.dll has some "issues" with seeking (up to pb4), the next release should fix this. have patience, it should not take too long. I don't know about wav or flac though.
btw, did you inform ssamadhi97 about your problems with foo_shn.dll?
edit: I must have been sleeping  ; foo_shn was not perfect, but released versions did not produce static after seeking.
Did you try DirectSound or Kernel Streaming?
Off to trying to reproduce the bug..
I wasn't able to reproduce the problem with fb2k 0.58 .. maybe upgrade and cross your fingers
btw, foo_shn release candidate 1 is out: http://www.hydrogenaudio.org/forums/index....=27&t=7432&st=0
(got bored with calling it "public beta #" *L*)
Thanks for the replies...
all seems to be good in the hood --> .58 jumps with flac shn and wav (Which are all I care about). Thanks.
New stuff in the status bar - groovy...
ss -  it wasn't a shn problem - I was using FLAC...
