Topic: FLAC to MP3 (Read 9290 times) previous topic - next topic
FLAC to MP3
What is the best way to convert FLAC files to MP3?
I am considering using foobar2000, but I have LAME 3.90.3, which I use with Exact Audio Copy (and prefer to stay with). In foobar2000, do I have to enter any special parameters? I tried converting a FLAC file at V2 190kbps, but got well below 190kbps. When I use this LAME version with EAC, I always get around 192kbps and higher. Are the later versions of foobar2000 compatible with LAME 3.90.3? Do I have to modify any settings?
FLAC to MP3
You don't have to configure foobar at all to transcode with the V settings.  Just tell foobar where you stuck lame.exe and it's ready to go.
You encoded one track and got less than 190, that's not unusual.  It's VBR.  Try encoding some metal and watch in jump well over 190, well at least with lame 3.98.
And you can configure foobar to take whatever, version, encoder you want.
FLAC to MP3
Thanks,
Tho I think I may just convert to WAV using foobar, then use Exact Audio Copy to compress to MP3 using my older LAME version. It's an extra step, but gives me piece of mind.
FLAC to MP3
You do know that doing it that way you will lose any tag information?
FLAC to MP3
Thanks,
What extra piece of mind? If you tell EAC to rip to MP3/FLAC it'll rip to a temporary WAV file anyways....as pdq said, you'll lose tagging info with WAV.
FLAC to MP3
why don't you use dbpoweramp?
FLAC to MP3
Thanks,
That I can get the exact specifications I want with using LAME 3.90.3. I have EAC set up to use this version as MP3 encoder. So I convert FLAC to WAV using foobar2000, then compress the WAVs to MP3 using EAC. The later versions of LAME use different/new parameters, which is recognized by foobar2000, but when I tell foobar2000 to use LAME 3.90.3, I'm not sure if this older version of lame uses these same parameters?
FLAC to MP3
Why don´t adapt the parameters in Foobar? With your old lame version in use?
Right click on File / Convert / .../ MP3
Choose Output Format to mp3 then click on the right side the three points - change Encoder to custom and there you go :-)
Foobar just sends the commands to the encoder and feed him with .wav pieces.
FLAC to MP3
The LAME transcoder settings on foobar2000 is designed for LAME 3.97 (-V 2 --vbr-new). You will need to add a custom encoder if you wish to use LAME 3.90.3.
Here is my personal LAME 3.90.3 command line for foobar2000:
-S --noshist --alt-preset standard - %d
FLAC to MP3
[a href='index.php?showtopic=61511']Reflacer[/a] will perform the conversion from FLAC to MP3, and keep them in synch
FLAC to MP3
i know this is an old post but dbpoweramp is great and widely considered one of the best
