Topic: padding aac frames / fill element (Read 4628 times) previous topic - next topic
hi,
I am trying to create a mp4 file with an aac audio stream.
I need to have constant sized samples. it is from a live stream. mp4 format forces me to either have constant size or predict size of each frame.
I tried to add padding to each aac frame using a fill element but vlc can't read it correctely (sound is distorted) and it says :
[00000446] faad decoder warning: PCE shall be the first element in a frame
this is a sample result file : http://dl.free.fr/vFYOpT7JK
can somebody give me some hints ?
thanks for your help.
You put the fill element right after each frame? That is wrong, you need to put it before the ID_END marker, otherwise it will indeed be the first element of the next frame.
oops...  seems logical to put it before id_end.
I will try it. thanks.
you were right. thank you menno!
hi,
I have some issues on the aac stream to find the ID_END. the aac frames are not aligned with 0 which means I can't just take the 3 last bits set to 1.
I can't find any other solution than entirely parsing the aac stream to find the ID_END. If you have any alternative solution, I will take it.
