Topic: multiple files to multichannel ogg vorbis? (Read 6302 times) previous topic - next topic
I am trying to merge multiple stereo ogg vorbis files into a single multichannel ogg vorbis file using only command line Linux tools.
From what I understand, oggenc requires a multichannel input.  I have used sox -M to create a multichannel wave file, but oggenc doesn't like it:
Warning: INVALID format chunk in wav header.
 Trying to read anyway (may not work)...
Skipping chunk of type "fact", length 4
ERROR: Wav file is unsupported type (must be standard PCM
 or type 3 floating point PCM)
ERROR: Input file "combined_newsox.wav" is not a supported format
Audacity will read it fine, however.
Using sox to create the multichannel ogg, the output sounds horrible.
Any suggestions?
Any suggestions?
2 options i found when trying to do this,
1. use besweet http://besweet.notrace.dk/  sometimes this works wonderfully, tho it can be a royal pain in the ass at times to.
2. make a multi Chanel wav file, THEN convert to ogg using latest greatest aotuv
good luck, this kinda stuff is alwase a pain in my arse when i try and do it
Thanks for the reply.
I ended up using sox to merge to a multichannel aiff file, and oggenc seems to handle that fine.  I've done limited testing, but so far, all seems well.
