Topic: FLAC fuckup (Read 3449 times) previous topic - next topic
FLAC fuckup
I haven't heard anybody else mentioning this. I've experienced a quite annoying playback bug with FLACs in Foo since it's birth and doesn't seem like it's solved yet. When transporting yourself within a FLAC and you accidently move outside the file XP (& 2000?) first slows down to the speed of frozen molasses (even the mouse can't be moved properly) & then crashes windows. Further description of the bug:
1. Start up a FLAC, let's imagine it's 3:00
2. Use whatever key assigned for transporting yourself ahead either one minute or 5 seconds until you've reached 2:56 or just listen to the song until you're there.
3. Now transport yourself ahead 5 seconds. As there's only 4 seconds left of the song the bug is introduced.
It works just as well to place yourself at ie. 2:15 and use whatever key assigned to move one minute ahead. Well, you get the idea...
This is a nasty bug & happens me at least some time every day when fiddling to fast with the keys. Please just don't say the flac lib is fuct, I already know that is the general consensus.
FLAC fuckup
known bug in flac libraries
FLAC fuckup
This is fixed in CVS, it's a bug in libFLAC.  The workaround is for the caller to cap the target seek sample to total_samples-1 (total_samples is in the STREAMINFO metadata block).
Josh
FLAC fuckup
That sounds promissing (but who am I to judge). Is there a chance you might be able to fix it Peter?
FLAC fuckup
added fix in 0.58
FLAC fuckup
Big thanks for fixing this bug! Now there is no reason for me not to play flacs with Foobar.
FLAC fuckup
added fix in 0.58
Thank you lots and lots!
