Controls not working 2003-03-10 23:43:46 i just downloaded foobar.. and i saw that in DSP, volume control was active? wht does it do? i dont see any volume control bar in main window?secondly i tried changing the reverb and xbass options but nothing happened.. should i get the extra plugins available on site to get them to work?3rd.. there was a post abt a new UI of foobar.. can somebody mirror tht.. cuz tht server seems to be dead.last.. in shortcuts, at the bottom the KEY and GLOBAL SHORTCUT checkbox... wht are they for? i thout it was for acctivating foobar window .. so that ZXCV keys can work normally. but that global key never gets saved.
Controls not working Reply #1 – 2003-03-11 01:04:14 1: while in main window hit + or - to control volume. Or double click the volume area on the bar for a volume slider.2: You have to enable reverb and simple bass in DSP Manager before the controls will work.3: The other UI is a hack, and is not supported by the fb2k developer, and is generally frowned upon.4: if you check global ...select a function in bottom area of the screen, click in the key text box...select a key combination and then click the "add" button. It will you allow you to perform that function while fb does not have focus. Last Edit: 2003-03-11 01:05:00 by Bamral
Controls not working Reply #2 – 2003-03-11 06:05:39 [deleted] Last Edit: 2015-08-27 21:27:02 by TrNSZ
