Topic: CELT 0.6.0 is out (Read 11651 times) previous topic - next topic
CELT 0.6.0 is out
I'd like to announce version 0.6.0 of CELT, a very low delay audio codec for high-quality VoIP. This release includes many quality improvements, including better stereo coupling, better handling of transients, and better handling of highly tonal signals. In addition, packet loss robustness has been improved through the optional use of independent (intra) frames. CELT now supports a larger dynamic range, suitable for encoding 24-bit audio (float version only). There is also a very early VBR implementation. Note that 0.6.0 is not bit-stream compatible with older releases.
CELT 0.6.0 is out
Hmm, maybe update  samples page with samples made with 0.6.0... Currently, there are samples made with 0.3.2.
CELT 0.6.0 is out
Just to let everyone know that 0.6.1 is out. The main change is some improvements to the stereo code. Get it from the usual place.
CELT 0.6.0 is out
So the plan is embedding this into devices?
