Topic: High frequencie in Björk-Jóga (Read 5150 times) previous topic - next topic
I buyed these days Björk- Greatest hits (the one with the strange cover on it) and i love the disc.
Every single song one masterpiece of its own, if you can like the sound of Björk.
But there is some strange thing, that keeps me busy: In the song "Jóga", at a later stage of the song, i think i hear some strange high frequencie in the background.
On CD and on FLAC copy.
Just for the healthy of my mind: Do anyone hear the same as is? Audacity shows me a strange peak at 20390 Hz, who i think that it could be.
Pick one:
  • Synthesizer.
  • Heavily distorted, flanged, and reverbed guitar.
  • Heavily distorted, flanged, and reverbed violin.
I wouldn't be surprised, either, to find an electronic musician like Björk intentionally using comparable or identical filtering artifacts, as they are found in low bit rate compression, as a supplement effect for portions of her mixes.
ok, so i´m not mad at all  thanks
You can probably rule out a guitar just given Bjork's anti guitar bias.
The album that song came from (Homogenic) is primarily a string octet with much of the electronic sounds being processed/distorted Icelandic nature sounds --- geysers, eruptions etc...
Synthesizer
Some older analog synths produce a pretty obscene amount of HF noise, so this is quite likely. I've found this is especially true of many older modular synths which Björk probably uses.
