Topic: Tremor's mdct backward function (Read 10400 times) previous topic - next topic
Hi to all,
I'm trying to understand the Tremor's code that implements the iMDCT.
First of all.. Does it implement iMDCT throught a mechanism of rotation and FFT? I'm not sure of it..
If it's true.. where does implement the presorting?
Then.. the parameter "n" defines the dimension on witch the iMDCT is calculated (I know that the range on witch n is defined could be only between 64 and 8192 , multiples of 2).  Is it the input's array dimension?
Thanks for answers
It does not.  FFT based iMDCTs are very easy to spot since they nearly all look the same.  See mdct.c in ffmpeg (or the unrelated but nearly identically written mdct.c in libfaad) for good examples of these.
Correct.  Its the input array's dimension (number of frequency domain samples), typically 256 or 2048 for vorbis.
So.. what does implement?? How is it implemented?
I thought that it was following the algorithm to implement a MDCT thorugh an FFT in the reverse way...
Check the comments in the code.  The author gives a reference for his particular MDCT.  Unfortunately, its a book which I've never bothered to track down so I can't say anything specific about it.  However, if you search for IMDCTs, you'll see that theres quite a few different algorithms out there for computing them (though the FFT method is most popular).
The forward and backward MDCTs are nearly identical, and are extremely simple.  Most are just a few lines of code for rotations, then an FFT, then a few more lines of code for post rotations.  The algorithm in Tremor is clearly quite different since its both very long and has no FFT
Hmmm,    ,  actually the mdct_backward function in Tremor's mdct.c file does implement an FFT.  I see bitreverse, butterfly etc methods, all the building blocks of a good old Fast Fourier Transform:
http://www.dspguide.com/ch12/2.htm
If you can pick out a DFT in there, then good work!  But don't assume that just because theres butterflies and bit reversal that its an FFT.  The MDCT is itself a discretized Fourier transform, so it can be computed using much the same decomposition methods.
Hi to all,
Thanks for answers
i am working on MDCT Backward of tremor's code.
i need to replace this to Duhamels algorithim.
can u plz help me out by any suggesstions or inputs??
i need to replace existing MDCT to duhamels FFT  so as to increase the performance.
Thanks a lot.
Regards,
Ruchi
Thanks a lot.
I tried several FFT based IMDCTs in place of tremor's and all were slower.  You will need a very fast FFT algorithm to beat Tremor.  Lately I've been working on a slit radix version, but I have no idea if its going to be any faster
If you want to try, take a look at one of the mdct.c files mentioned above and use your own FFT.
