Topic: Good MPC Tagger (Read 21475 times) previous topic - next topic
Good MPC Tagger
Now if it would just let me do ID3V1 and APEV2 on my mp3/mpc/ogg/whatever files.
Seems like there is no program right now that will let me do ID3V1 and APEV2 on an mp3.
Maybe this one will soon.
Thanks,
David
Good MPC Tagger
It seems that Tag will do this. I just tested it on an MP3: I used "--force ape2", then tagged with a 40-character-long Artist field (a test, because ID3v1 would normally truncate a field that long). Put it in Foobar, and the whole artist field shows up. File info shows APEv2 tag formatting.
However, I prefer using Frontah, quite possibly the best encoding frontend on the planet. Unzip it, go to Settings -> Tagging -> Advanced, and tell it to apply APE tags to MP3. Then you can use Frontah's cool GUI to edit tags.
Good MPC Tagger
Warrior,
This seems to be a partial solution. I can set fronta up as you described, edit a tag but not change anything. When I save it, voila, I have ID3V1 and APEV2. Heaven. Now, if I could figure how to do it as a batch instead of a file at a time.
I use Tag&Rename most of the time. The ID3V1 comes from FREEDB. I would like to then batch populate the APEV2 tag with the info from ID3V1.
Oh, and I would like fries with that.
Thanks,
David
Good MPC Tagger
Turbo,
Thanks for your input. This program has some VERY nice file rename capabilities. It does not seem to support APEV2 tags though.
Thanks,
David
Good MPC Tagger
Read the history log and you will see that support mpc fully. I use it every day and supports apev2!.  Enjoy it!
Good MPC Tagger
Turbo,
The log indicates
"Add the APE format (*.ape, *.mpc, *.mp+) at the music-type of TagRename."
This doesn't indicate V1 or V2, and it does not work for MP3 files.
Thanks,
David
Good MPC Tagger
OK, on mp3s I think apev2 is not supported, just for mpc and ape. Sorry.
Good MPC Tagger
Warrior,
Frontah does have batch-tagging capability. Go to Settings -> Tagging, and enter the formatting for your filenames. If you have more fields to enter, ones that aren't in the filename, double-click the "Additional tag items" box below the filename formatter, and enter your custom tags. Then go back to the main window and choose "Tagging" from the leftmost menu icon-set.
I'm also a fan of Tag&Rename; I like its interface and its ease-of-use, and I used it to organize my big MP3 collection. I also use Tag often, because it's quick to use from the command-line and pretty powerful.
Good MPC Tagger
I'm not sure how the tagging programs use CDDB/FREEDB with MP3's; I thought you could only use those programs when you had the original CD. Anyway, perhaps one solution would be to make big long filenames for all your files, with the filename including all the data you need to tag the file. Example: Artist - Album (Genre/Year) - Tracknumber - Title.mp3. Then you can use Frontah, or Tag, or whatever, using that filename structure, to tag all your files at once. If you're just now ripping your MP3's, this strategy might be quick and easy.
Good MPC Tagger
To use FreeDB you need to calculate a hash value from the offsets of the tracks and their total length. So if you just can guess the offset of the first track it is easy to calculate the hash exactly from OGG:s or MPC:s. MP3 is a bit more tricky since it adds a number of samples when you compare the decoded file with the original.
I believe that most cd use the minimum offset possible for the first track, so guessing that doesn't have to be so difficult either. But I'm not very sure on this part.
I think it would be interesting to have a feature like this in TAG. How do you think?
Good MPC Tagger
Sometimes Warrior,
I may have to name a child after you. That was the last piece of the puzzle. I had already changed the option to put both ID3V1 and APEV2 tags on MP3 files, but i didn't do the obvious. Hit the BIG icon up top. Thanks man.
Peace,
David
Good MPC Tagger
Wow ddrawley, that's quite an honor!
You're welcome! I noticed that Frontah doesn't always have the most obvious interface (I figured out how to use it mostly by accident), but once you get it, it's very quick and easy.
@ErikS: thanks for the FreeDB explanation. This would indeed be a neat feature for Tag, although it doesn't seem like it would be a trivial feature to add... but how would I know, I'm no programmer.
Good MPC Tagger
I love
Dapyx
Try it!
g
Jeova69
I've never met anyone who tried a joint but
didn't inhale.
(H. Marks)
Good MPC Tagger
after asking the author of Tag & Rename he stated to me that after the final release of version 3, that he is working on APE v2 Tags for MPC files, and it will be in the next release after the final of version 3
Good MPC Tagger
I wrote a email to the author of Flexible Renamer, who corrected a bug that read the wrong track number (real track number + 1) from APEv2 Tags. Now everything works fine (v.7.20) and FlexRename is my program of choice for renaming mpc files according to their APEv2 tags.
Good MPC Tagger
tag.exe is the best TAGGER (not renamer) i think. it just does anything
Good MPC Tagger
I don't think Frontah is as good a frontend as the MPC Batch Encoder when it comes to musepack because it only lets you choose -q4.0 through -q7.0 and doesn't let you add other options like --xlevel. Or is there a way to do this that I haven't found?
Happiness - The agreeable sensation of contemplating the misery of others.
Good MPC Tagger
rpop,
When you activate the Musepack button at the upper left of the Frontah window, you'll see a dropdown menu on the right labeled "Additional parameters"; you can type any command in there that you like, provided that your version of mppenc will accept it.  In my experience, settings typed in there will supersede the quality slider setting, and "--xlevel" can be added.
If you want to check after encoding that everything went OK, just look at your stderr file. I typically redirect it in Settings > General to a file named EncodeLog.txt.
Good MPC Tagger
The only reason I use separate tagger is because of non-ANSI UNICODE characters. And Case's tag does not support them    What's the best tagger that supports UNICODE? I use Foobar to tag my mpc files...
Good MPC Tagger
Great news! i really love this program, no other tagger is as powerful as Tag&Rename. Its only misgiving is that... it doesn't support mpc and ogg. But that is repaired, all good
Good MPC Tagger
well finally Tag and Rename supports APE v2 Tags
I redid my entire mpc collection last night and it now looks all sweet
